power aerial 80 series mast and rope replacement
Submitted: Saturday, Oct 11, 2008 at 11:30
Bev
Has anyone done this . The rope has broken and we are having an issue getting something to grip it to pull it out . Wire isn't working .
There are instructions in gregorys to remove the aerial leads but not how to get at the base of the mast . ie where do we get into the body to get at the rope so we can pull it out please
Is there an easy access point please
Bev
Reply By: Member - George (WA) - Saturday, Oct 11, 2008 at 11:38
Have you tried the 'Up-Down' switch for the aerial. The 'Up' position should eject tne last broken bit of rope
329331
Follow Up By: Bev - Saturday, Oct 11, 2008 at 12:04
Yes we have tried the up button but the motor just whirs and nothing comes up The mast has been taken out ok.
596705
Reply By: donk - Saturday, Oct 11, 2008 at 12:12
If the drive cable is broken normally you have to remove the assy,disassemble it & remove the broken section of the drive cable
Regards Don
329335
Reply By: Member - 120scruiser (NSW) - Saturday, Oct 11, 2008 at 13:07
As stated you have to remove the body and it is in behind the metal inner guard. A mongel of a job. Bend the guard back, remove the aerial body, and dismantle it. You will then have to bend the guard back into place.
329337
Follow Up By: Bev - Saturday, Oct 11, 2008 at 16:34
Thankyou for that guess there is no easy way and it will be a mongrel of a job
596732
Reply By: kev.h - Saturday, Oct 11, 2008 at 18:46
If the drive motor was going down at the time it broke it has wound the broken part into the housing
Check the length difference between new and old if its less than 300 mm there is usually enough room in the housing to accomodate it as
well as the new one ( the broken piece will simply spring out and sit against the outside of the housing)
Feed the new one in move it up and down a couple of times if it works thats fine
Even though the service people at your toyo dealers will tell you its a big job, and charge like a scrub bull, thats what they do
Kev
329368
Follow Up By: Bev - Saturday, Oct 11, 2008 at 19:01
unfortunately there was only 4inches came out with the mast so I guess most of the length about a meter? will still be in there
596756
Follow Up By: kev.h - Saturday, Oct 11, 2008 at 23:56
O.K. in that case only option is to dismantle it, Sorry
Kev
596807
