Rust pitted rifle bore
Submitted: Saturday, Oct 11, 2008 at 22:19
ThreadID: 62460 Views:6810 Replies:11 FollowUps:4
Gidday
Had an aquaintance call in the other night to show me an issue he had with his rifle. Which turned out to be a rusting bore.
The rifle has'nt been used for quite some time, and after a bit of talk I found out he keeps it in a locked box which is subject to high moisure conditions each week.
I got the cleaning kit out and gave it a fair scrubbing, but there is still rust pitting in the bore.
Anyone know of a product that will clean this up? I use Kleen Bore but it's not working in this case.
PS The first Mexican Fly came in to say Gidday today. LOL
Kim
Reply By: Dennis Ellery - Saturday, Oct 11, 2008 at 22:38
40 years ago as a Nasho in the army - we would occassional run a pullthrough with steel wool inside the barrel - but the army frowned on it. In Vietnam there was no limit on your ration of condoms. Once it was cleaned and oiled we then put a condom over the end of it (the barrel) to keep the dirt and moisture out.
AnswerID: 329408
Follow Up By: Kim and Damn Dog - Saturday, Oct 11, 2008 at 22:50
Gidday Dennis
Agree, I keep a cap on the end of the barrel these days.
Kim
FollowupID: 596798
Reply By: Willem - Saturday, Oct 11, 2008 at 22:49
Yep run a wire brush through it OR fire a couple of rounds...that should clean the rust out....lol
AnswerID: 329409
Follow Up By: Kim and Damn Dog - Saturday, Oct 11, 2008 at 23:02
Willem
We're not talking about a Nissan...!
Although, when I think about it, a wire brush and a couple of rounds would probably fix up any Nissan.
LOL
Kim
FollowupID: 596799
Reply By: The Rambler( W.A.) - Saturday, Oct 11, 2008 at 23:27
Kim,
As you probably know many people keep firearms in a locked cabinet enclosed in a gun bag which is zipped up with no air to breathe.This is the worst thing you can do in a tropical or humid climate which will quickly lead to rust or corrosion both inside and outside the barrel. It maybe ok in a dry type of climate but better of keeping firearms upside down in the cabinet so as to reduce any moisture gathering within the barrel.In my opinion if rust or corrosion has already set in Iwould seek professional advice if it is a valuable firearm as home remedies can make the situation worse.
AnswerID: 329412
Follow Up By: Kim and Damn Dog - Saturday, Oct 11, 2008 at 23:57
Gidday Rambler
I have'nt seen a case like this before. At the end of the day it's his own fault for not maintaining the rifle.
It would be a brave man firing a round from the barrel. I've tried every trick in the book that I know of to clean it.
Have to agree with you. It's probably time for him to consult a gun smith.
Kim
FollowupID: 596808
Reply By: Member - Redbakk (WA) - Saturday, Oct 11, 2008 at 23:45
What calibre is it.....smooth bore(shotty) or 22 rimfire ...ok....but I would be having it checked by a gunsmith if it is a centrefire
AnswerID: 329413
Follow Up By: Member - Redbakk (WA) - Saturday, Oct 11, 2008 at 23:49
In my cabinet I have two 60 watt globes in series ( they half glow) and this keeps the guns nice and dry....also the globes last a long time...like a year or longer.
FollowupID: 596806
Reply By: Flywest - Sunday, Oct 12, 2008 at 00:04
Bronze bristle brush on a cleaning rod - and soaked in Hoppes number 9 solvent.
Add a pull thru patch to the end of the bristle brush and keep replacing the patch until it comes out clean...and the rust / pitting is gone as best you can.
Where is the bulk of the pitting and rust? is it immediately in front of the chamber ie, the throat of the rifled bore immediately ahead of the chamber?
What cal rifle?
I once had a guy in a similar sit with a old lee enfield that had been rebarelled down to a .22 hornet round, some of the very old mercuric primers from old days had eroded the throat area badly so we did what we could and I ran up some mild hand loads to test her out - it hadn't been fired in anger for many years.
Put a target on a hay bail - and fired a shot from 100 yards into the centre..
Couldn't see a hole with the binocs - so we walked down to the hay bale - to see 5 separate holes spread all over the paper! Yikes!
The projectile had disintegrated mid air - it was definitely beyond time for a re-barrel again.
It s not uncommon in high powered rifles that have seen 5 or 6 thousand rounds or more to develop an area of throat erosion just ahead of the chamber, where the hot gasses of combuston and particles of as yet unburnt cellulose exit the cartridge, as the gasses expand all the way down the barrel behind the accelerating projectile specially with double base powders.
Such throat erosion will effect accuracy - as the barrel develops quite a noticeable whip cycle as it returns to battery - since it has to centeralise the projectile to line up with the axis of the bore - because the projectile exits the cartridge neck into the area containing the void of throat erosion - and then has to be lined up to the remaining true axis of the bore as it accelerates down the rest of the bore which still has rifling lands intact.
Anyway - the advice about having a gunsmith look at it is sound.
There are a couple different methods used to make the rifling lands (button rifling and Madrell rifling) and a couple methods of attaching a barrel to an action (pinned or screw threaded) and each affect accuracy and each can be cheaper or dearer depending what make of rifle it is and if you want to keep it original.
Good luck - I'd get good advice from a gunsmith if I were your mate.
AnswerID: 329418
Reply By: Member - Bucky (VIC) - Sunday, Oct 12, 2008 at 06:14
Kim
What calibre ?
If it's that rusty, you maybe better using it as a garden stake.
I have resurrected a couple of old mausers, to reasonable condition, by soaking them in diesel for about 3-4 weeks, to soften thing up, and then giving them a bloody good scrubbing.
There are lots of good barrel conditioners, and copper solvents out there. Hoopes products are probably the best. You maybe need an aggressive one first, and scrub like the peverbial !. Dry patch it out. Have a look up the barrel.
If you can clean the rust out, and oil it up, run more patches thru it till they come out clean.
Have another look down the barrel, and make up your mind then.
If in doubt, take it to a gunsmith.
Bucky
ps let us know how you went !
AnswerID: 329429
Reply By: Krakka - Sunday, Oct 12, 2008 at 09:47
Just get a new barrel fitted, a rusty , pitted bore is only good for a garden stake as previously mentioned.
Krakka
AnswerID: 329450
Reply By: Member - Willie , Sydney. - Sunday, Oct 12, 2008 at 12:38
Kim,
The barrel is pitted .There is no way to undo what has happened as far as I know.
You should be able to get rid of the rust in the "pits", but the pits remain the problem .
Willie
AnswerID: 329477
Reply By: Member No 1- Sunday, Oct 12, 2008 at 16:00
you could try a extended version (you will need to make it) lead remover like these which are available in australia ...let me know if interested and i'll find the link for you
AnswerID: 329510
Reply By: Kim and Damn Dog - Sunday, Oct 12, 2008 at 17:49
Thanks for the replies.
I'll print this sting and pass it on to the Fella.
PS The rifle is a CZ 30-06.
Kim
AnswerID: 329531
Reply By: Moose - Monday, Oct 13, 2008 at 14:58
G'day Kim
Get your mate to post on here too: www.australianhunting.net/
I would suggest that if truly pitted the barrel is stuffed.
Cheers from the Moose
AnswerID: 329666
