coil spacers
Submitted: Saturday, Oct 11, 2008 at 23:49
Member - Roger S (WA)
Hi everyone would appreciate some opinions on putting 50mm coil spring spacer on the rear and 30mm coil spring spacers on the front of a GQ as a cheap
suspension upgrade and to counter the rear sagging. The vehicle has already had a 50mm
suspension lift from standard.
Reply By: Member - BUNDY BOY (WA) - Sunday, Oct 12, 2008 at 00:14
hi Roger if its sagged in the rear or like me you carry weight all the time.......just whack 50mm in the rear ;
it will pick it up a good bit ...and will extend your time till you need taller or heavier springs.....
mine lasted 18 months till they started to sag again.but i do a lot ow
miles with weight ....am now going tray back springs with poly air bags
Bundy
329419
Reply By: Member - Tony B (QLD) - Sunday, Oct 12, 2008 at 07:35
Roger. If
the springs are sagging, basicly they are not doing the job as they are designed to do. I see no point of raising a dead spring. If it already has the 2" lift then
the springs must be after market? I would recommend no less than to go and get
the springs reset. I have not done this for a while but do the homework and some of these
places will be able to put them back up under your car retempered better then new at a very reasonable cost. I also recommend airbag load assist
suspension - link is
http://www.airbagman.com.au/ great product, great price and you will never sag the rear again. Cheers Tony.
329434
Reply By: MAVERICK(WA) - Sunday, Oct 12, 2008 at 09:02
for an even cheaper way go and see any of the after market
suspension people around
perth - smile really really nicely - and get a set of gu springs for $0 and put them in. they are just scrapped but make a cq go upwards. rgds
329444
Reply By: Member - Shane D (QLD) - Sunday, Oct 12, 2008 at 15:19
I would just replace/get heavier coils, they are cheap if you look around.
sooner or later you will have to do the job anyway.
Shane
329503
