Compressor - Big Red - Service
Submitted: Sunday, Oct 12, 2008 at 00:12
ThreadID: 62467 Views:1950 Replies:2 FollowUps:2
I have had my "Big Red" for over 10 years - Should it be serviced and is there someone in Perth who can do them - does not appear to be anything wrong but I dont want to risk it going Phutttt...... (it does overheat and cuts out) Is there such a thing as a service kit
Reply By: Member - Paul C (NSW) - Sunday, Oct 12, 2008 at 01:05
When I bought mine about 6 years ago, I was told no need to service them. A big part of the reason for going with the Big Red was that they are fully repairable. ie All parts can be replaced. I would imagine there is a service kit. In the instruction manual there was a full list of components with part nos.
If the unit is cutting out it normally maens it can't achieve the pressure required. Tried filling a 30L receiver with my Big Red but it continually cut out at around 90psi in the tank. Thank god for the overload.
What is causing it to overload?
Paul
AnswerID: 329424
Follow Up By: Trekkie (Member - WA) - Sunday, Oct 12, 2008 at 01:23
Paul Thanks - It has overheated and usually a wet towel placed over the pump fixes the problem (the compressor is in the engine bay and gets a bit hot anyway) Do you know who the Australian distributors are
FollowupID: 596814
Follow Up By: Member - Paul C (NSW) - Sunday, Oct 12, 2008 at 01:43
Got mine through 4x4 Megastore. From memory they are made by Thomas Industries in the States. I know the manual is out in the shed. Just moved house so it would take a while to find it!
Try cleaning the inlet filter before you go any further. The cover plate should unclip pretty easy. You will probably find that there are a series of dirty dots on the filter which line up with the cover plate. Rotate the filter or cover plate by a couple of degrees and see if this helps.
Paul
FollowupID: 596815
Reply By: Member - Dennis P (Scotland) - Sunday, Oct 12, 2008 at 06:48
Hi Trekkie,
Just googled 'big red compressor' and got quite a few Aussie sites, too many to cut and paste.
Might be worth your while having a look.
Good luck,
AnswerID: 329431
