Charcoal Canister
Submitted: Monday, Oct 13, 2008 at 09:17
ThreadID: 62503 Views:2051 Replies:1 FollowUps:1
Hi all,
Is there any maintenance that needs to be done on these canisters? I have an 80 series and there is nothing in the owners manual or the aftermarket manual on these.
Rob
Reply By: Supercalafreakinawesome- Monday, Oct 13, 2008 at 22:41
Hi Rob,
As no one has replied yet, I'll give it a go. I know very little about them but my 100 series manual suggests that Toyota Service centres are supposed to check the operation of the canister - and the hoses /pipes etc every 50,000km.
(I seem to remember my old 1983 Nissan manual suggested replacement every 100,000k)
- "check for internal damage and clogging -if necessary clean with compressed air or replace"... is one thing mentioned in the manual.
The info is a bit too long winded to copy into here but it looks like they test it by measuring air flow and vacuum through the canister on a meter etc.
I have read that there is a likelihood of fuel smell under bonnet and in cabin if the canister is clogged or hoses/pipes cracked. Apparently its likely that the hoses/pipes with crack before the canister gets clogged.
Hope this helps
AnswerID: 329771
Follow Up By: Robnicko - Tuesday, Oct 14, 2008 at 09:06
Thanks for the reply.
Rob
FollowupID: 597266
