How many degrees on compass?
Submitted: Monday, Oct 13, 2008 at 17:29
OldMike2
The compass on my Navman GPS appears to have 256 degrees in a full circle. I thought a compass had 360 degrees on it.
If travelling north it shows 0 degrees.
If I deviate a bit to the left it reads 255 degrees.
If I head south it reads 128 degrees.
Now I am sure somebody knows the answer, but I don't.
Mike
Reply By: Member - Tony B (QLD) - Monday, Oct 13, 2008 at 17:36
OldMike. I SUGGEST YOU MIGHT HAVE STARTED THE EVENING DRINKS A BIT EARLY TODAY ;-). Either that or your GPS is not picking up enough satalites, or you are not moving enough for it to work out which direction you are travelling. Cheers Tony
329690
Reply By: darrell.QLD - Monday, Oct 13, 2008 at 17:48
Are you anywhere near
BATHURST?????????????????????
329692
Reply By: VH-GU4 - Monday, Oct 13, 2008 at 18:06
Most definetly is 360 degrees in a compass. Some thing is not wright with your GPS. Does it do this all the time or part time?
329695
Reply By: Member - Fred G (NSW) - Monday, Oct 13, 2008 at 18:14
Oh dear...looks like your compass has lost some degrees LOL Check on Ebay, they usually have some cheap ones on there
ROTFLMAO
329696
Reply By: equinox - Monday, Oct 13, 2008 at 18:59
Just multiply your bearing by 1.40625
329705
Reply By: Notso - Monday, Oct 13, 2008 at 19:35
Maybe degrees have depreciated as
well as our dollar??
329718
Reply By: Willem - Monday, Oct 13, 2008 at 19:35
Mike
I can't believe you asked that question ...hahahaha
Your Navman is Dead, Kaput, Finis, Passed away. Bin it and buy a new one.
329719
Follow Up By: Member - Doug T (NT) - Monday, Oct 13, 2008 at 19:58
Willem
What would you expect from a navman, it don't even earn a capitiol letter for the name.....lol
597160
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 14, 2008 at 14:40
"Your Navman is Dead, Kaput, Finis, Passed away. Bin it and buy a new one."
LOL!
Bereft of life! If you hadn't stuck it to the windscreen, it'd be pushing up f***ing daisies!!!
597307
Reply By: OldMike2 - Monday, Oct 13, 2008 at 20:49
Well, now that youve all had a good laugh, let me explain a bit.
The unit can"see" 12 satellites; It can tell we a re going N,S,W,E.
But when you go to the GPS detail page, it shows latitude and longitude OK; just the heading in degrees is strange.
It follows the Sensis maps OK (as far as they are ok) and finds my way around strange urban areas. I don't need it in the bush much as it is hard to get lost there.
So, it is not a compass as such, just a heading.
Oh
well; just follow the sun then,
Mike
329736
Follow Up By: equinox - Monday, Oct 13, 2008 at 22:16
Mike,
I think it is displaying in units of "binary radians".
Is there a setting that you can change the units from "binary radians" to "degrees"?
597216
Follow Up By: Frank_Troopy - Tuesday, Oct 14, 2008 at 11:18
Mike,
I reckon that Equinox is right on the money. The binary radian system is designed such that the full circle can be represented in one byte, thus a maximum of 256. This is the number of binary radians in a full circle.
As is usually the case with this
forum, the answer is normally there somewhere if ones prepared to ignore all the rubbish.
Cheers Frank.
597283
Reply By: Robnicko - Monday, Oct 13, 2008 at 22:05
Mike,
Well I guess it wont work on roundabouts.
Rob
329758
Reply By: KennyBWilson - Tuesday, Oct 14, 2008 at 08:15
it must be set for magnetic north and not true north..... hahaha
329795
Reply By: Ray - Tuesday, Oct 14, 2008 at 08:47
Wasn't it all changed when we went metric?????
329800
Reply By: beelzebug - Tuesday, Oct 14, 2008 at 10:42
All of this frivolity, is it really helping this poor chap?
Maybe I should cancel my non-existent
membership to this site.
LOL
beelzebug
329813
Reply By: Boobook2 - Tuesday, Oct 14, 2008 at 11:15
Sounds like a bug
329818
Reply By: Michael ( Moss Vale NSW) - Tuesday, Oct 14, 2008 at 13:50
Are you currently in the Bermuda Triangle?? Michael
329840
