High Country - Corryong to Omeo Feedback
Looking to undertake this trip Jan 09 with camper trailer. Anyone no if this is a difficult trip? Also, any info on camping at Davies Hut would be greatly appreciated.
Cheers, Gavin.
Reply By: Crackles - Monday, Oct 13, 2008 at 21:18
Gavin the road from Corryong to Omeo via Benambra is easy & could tow a semi trailer that way if you wish ;-) Was there another route in particular you were after details on?
Cheers Craig..........
AnswerID: 329742
Follow Up By: gavjan1 - Monday, Oct 13, 2008 at 21:37
Thanks Craig....cracking response!! Not thinking of going via Sassafras Gap though. We were actually thinking of going via Mt Misery Trail, Davies Plain Track, Tom Groggin, Mt Pinnibar Track, Wild Boar Track then onto Wheeler Creek logging Trail. Any ideas what this would be like?
FollowupID: 597195
Follow Up By: Crackles - Monday, Oct 13, 2008 at 22:09
Agree with Peter's response below. In dry conditions an experienced driver with a well set up vehicle could complete that route without too much heartache. I'm an advocate though for setting up a base for camper trailers & day tripping unladen in the High Country. Both track & weather conditions change often & with little warning. Cheers Craig...........
FollowupID: 597213
Reply By: Steve - Monday, Oct 13, 2008 at 21:33
gav - I don't mean to hijack your thread mate (maybe this might shed more light on yor query) but I'd like to ask Cackles if the road beyond Granite Flat (heading south) is ok to tow nearly 2000kg of offroad van? I'd like to get to a reasonably uncrowded spot next Easter, preferably by a river. We are totally self-sufficient re: energy toilets etc. I've heard nice things about this area but would be open to suggestions. I don't really want to tow the van up hill and down dale holding everyone up and am happy to find a good/nice base.
AnswerID: 329748
Follow Up By: Crackles - Monday, Oct 13, 2008 at 21:58
Steve to be truthfull I haven't been all the way on that route for some time but large sections have been sealed & from what I remember would not be a problem towing an offroad van if you have a decent tug.
Cheers Craig.............
FollowupID: 597207
Follow Up By: Steve - Tuesday, Oct 14, 2008 at 12:50
cheers mate - I'll do some homework
FollowupID: 597298
Reply By: Peter 2 - Monday, Oct 13, 2008 at 21:46
It can be difficult and it can be relatively easy depending on the weather, track conditions and the towing vehicle and trailer.
It is very steep in some spots, low 1st with a laden vehicle and if you stop with a camper on the back it may be a problem getting going again.
In dry hot weather the tracks can get very powdery and slippery, if it is wet at all don't even try.
Are you travelling alone or in a group?
The other problem is meeting an oncoming group, tracks can be very narrow, can you back your combo in steep terrain?
AnswerID: 329752
Follow Up By: gavjan1 - Monday, Oct 13, 2008 at 22:01
Hey Pete. 6x Patrols attending, all with good camper trailers. Most of us can reverse....some may need some pre trip training. Is the bit between Omeo and Tom groggin easier? We might be able to take bitumen from here to Khancoban?
FollowupID: 597209
Follow Up By: traveller2 - Tuesday, Oct 14, 2008 at 07:57
The trip between Omeo and Tom Groggin can be done by 2wd except for the last few k's drop down to the Murray crossing.
Bitumen leaving Omeo and then reasonably good fire roads and trails until the last bit down the mountain. You can actually see the flats at Tom Groggin from the top where you need to select low range for the drop into the valley, took us about an hour and a half with a few short stops the last time we did it.
FollowupID: 597255
Follow Up By: Mike Harding - Tuesday, Oct 14, 2008 at 13:42
Traveller2: are you suggesting the roads/tracks from Omeo to Tom Groggin via Davies Plain Track etc can be done in a 2WD!!!?
Mike Harding
FollowupID: 597303
Follow Up By: Peter 2 - Tuesday, Oct 14, 2008 at 14:43
As traveller2 stated it is possible to get from Omeo to the Tom Groggin crossing in about 1 1/2 hrs and yes most of the route is definately 2wd. Not via Davies Plain track though ;-))
From Omeo head nth along the Omeo hwy, about 4k nth turn right onto the Benambra rd, follow this until the left turn onto Beloka rd. Then turn right onto Mt Hope rd which is 2wd around to the northern side of Mt Hope where it joins the Tom Groggin track. From this point on it is 4wd, quite steep as the track drops straight down the ridge to Tom Groggin.
From the point nth of Mt Hope where the track gose from 2wd to 4wd you can look straight down the ridge and see the Murray and the Tom Groggin flats.
Definately not 2wd on the last section down the ridge but it is avery quick way for us New South Welshmen to access the high country.
FollowupID: 597308
Reply By: Mike Harding - Tuesday, Oct 14, 2008 at 13:48
For a Patrol/Cruiser pulling a, not too heavy, and _off road_ trailer and given good track conditions I would say the route from Tom Groggin to Benambra via Davies Plain is doable but not easy.
Please don't think I'm being trite but my feeling is that if you have to ask this question you probably should not do that track.
If you decide to go ensure you are prepared for weather ranging from snow to 45C.
Mike Harding
AnswerID: 329839
Reply By: Best Off Road - Tuesday, Oct 14, 2008 at 14:56
The run down from The Top of Mt Pinninbar to TG is very steep. We did it about 3 years ago and in a Petrol/Auto I had a very spongy brake pedal, bordering on running out of brakes. Those with manuals were fine.
A camper on the back is going to make it hard, but not impossible if dry. Manual box and brakes on the trailer would be my recommendation.
Not a trip for a novice (not suggesting you are one).
Jim.
AnswerID: 329853
Reply By: Member - Alastair D (NSW) - Wednesday, Oct 15, 2008 at 09:01
Gavin,
We did that trip last November.
In principle you could do it with a well set up vehicle & trailer as most of the roads/tracks are quite good. The main problems are the following:
1. The steepish drop down to TG from Mt Pinibar
2. At the Benambra Rd end of the Limestone Ck Tk there are some steep rocky climbs, one with a sharpish turn part way up.
Personally I would feel ok about 1 but not 2. There are steep drops on the rocky climbs and little space if things go wrong.
After you join the Benambra Rd turn left and a little way down you can take Native Cat Tk to your right. A nice drive.
From memory there is a loo at Davies Hut. The hut itself is in quite good shape but I would not sleep in it unless the weather was bad. Nice area. There are some really nice spots on creeks along DP Tk with enough space to camp.
There is a nice spot just after TG and the river crossing. Buckwong Ck I think. Much quieter than the big camp area on the NSW side.
If you take the Kings Plain Tk to the left about half way along the DP tk you can get to the Murray Rv and a nice camping area. There was a club group there so we did not stay. It is in and out not a through track.
Allow plenty of time. The distance are not big but there is plenty to see.
alastair
AnswerID: 329986
