200series stalling while travelling along.
Submitted: Tuesday, Oct 14, 2008 at 12:37
ThreadID: 62535 Views:2883 Replies:9 FollowUps:4
has anybody had this problem.
Nugget
Reply By: Member - Footloose - Tuesday, Oct 14, 2008 at 13:00
Fuel dirty ? Electrics etc playing up ?
AnswerID: 329830
Reply By: Member - John (Vic) - Tuesday, Oct 14, 2008 at 13:02
There was something about this posted awhile ago??
Thought to be something to do with fuel injection system if my memory serves me??
Maybe do an archive search and see what comes up other than that I'm sure a current 200 series owner will be along shortly to provide some detail.
AnswerID: 329831
Reply By: ingo57 - Tuesday, Oct 14, 2008 at 13:18
Yes! have driven a friends 200 and it stalled on me twice, both when coasting along to a stop.
He was with me at the time and said it hasn't happened to him before and to my knowledge has not happened since.
AnswerID: 329834
Reply By: Member - w B (WA) - Tuesday, Oct 14, 2008 at 13:35
Local dealer hasnt heard of the problem.yes it occurs when coasting to a stop.Fuel filter should have been changed 3000 kms ago but will check.now done 24000 kms.serviced at 21000.
Nugget
AnswerID: 329836
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 14, 2008 at 14:31
Doesn't sound like a fuel filter if it does it when coasting to a stop. But like all these things with warranty, they will point to that as the culprit since it's overdue (never mind the logic!)
Gerry
FollowupID: 597306
Follow Up By: ingo57 - Tuesday, Oct 14, 2008 at 15:02
wB
The one I drove had not even been run in, so I tend to agree with joc45 that it doesn't sound like the fuel filter.
Hopefully it should store a trouble code or fault, then the dealer can check it through the ECM.
FollowupID: 597310
Follow Up By: Member - Captain (WA) - Tuesday, Oct 14, 2008 at 15:48
Are you sure you need to change the fuel filter? My 200 had a separate brochure in the manual advising NOT to change the fuel filter due to the chance of dirt contamination. I think the filter only needed changing every 100,000kms.
A few 200's have had an issue with fuel pump pressures, not sure of exact reasons but were replaced with new pumps by Toyota under warranty. There is more info on the LCOOL site where there is a similar thread today (yours?).
Captain
FollowupID: 597318
Reply By: donk - Tuesday, Oct 14, 2008 at 15:42
If you talk to your dealer they will have information & a fix for this if it is the normal reason
Regards Don
AnswerID: 329861
Reply By: Stephen M (NSW) - Tuesday, Oct 14, 2008 at 17:16
Yes seems to be common on the diesels not the petrol. As John above said it has been said on here before. Was only talking to a mate yesterday who has just come back from two weeks away and was driving his mates 200 also diesel. It has been stalling and was taken back to Toyota prior to the holidays and was presumably fixed (didnt say what it was and I forgot to ask). Well it wasnt and did it to them about 6 times through the two weeks they were away. It was going back to Toyota yesterday. I will see if I can find anything out tomorrow for you. I belive it went to a Toyota dealership over Hornsby way, not sure of the dealerships name over their but maybe find out the dealers ship name and ring them and they should have the above mentioned 200 series in there been looked at. Regads Steve M
AnswerID: 329872
Follow Up By: Abra- Tuesday, Oct 14, 2008 at 17:37
Phil McCarroll Toyota Telephone 02 9488 2188
FollowupID: 597335
Reply By: Member - w B (WA) - Tuesday, Oct 14, 2008 at 19:04
Thanks for all the feedback.Totota dealer cant look ar it until tuesday next week .Wiill advise outcome then.Regards nugget.
Nugget
AnswerID: 329895
Reply By: Member - Redbakk (WA) - Tuesday, Oct 14, 2008 at 21:52
YES....have two new troopy's at work and the the engine will just quit even when under power...was very embarrassing coming out of pit 4 and up the ramp when suddenly..nothing...would not start...but you could turn them over....no go.....R260's and CAT 793's floating around....scarey.
It seems after you wait awhile they will start again...no codes...nothing...we still don't know....NOTHING to do with filters or fuel and the like so far...toyota does not seem to know either.
Having similar problems with our Hilux's BUT you get a engine light and codes.
AnswerID: 329933
Reply By: Member - OzGazza - Tuesday, Oct 14, 2008 at 23:37
Its a known issue - related to a faulty fuel pump.
Toyota have a fix for it and can identify the issue when you take it to them.
Take a look at this thread on LCOOL
AnswerID: 329953
