air compressors
Submitted: Tuesday, Oct 14, 2008 at 13:55
ThreadID: 62538 Views:2436 Replies:3 FollowUps:2
Just wondering if anybody has any feedback on a T-max taipan heavyduty air compressor, just been given one and dont know much about it.
Thanks all.
Marble
Reply By: Moose - Tuesday, Oct 14, 2008 at 14:08
Freebie - U beauty. That's the best one to get :-)
AnswerID: 329845
Follow Up By: Member - Graham H (QLD) - Tuesday, Oct 14, 2008 at 18:16
Try googling the name bound to be a review on there
FollowupID: 597341
Reply By: Member - Doug T (VIC) - Wednesday, Oct 15, 2008 at 09:25
Hello mate,
I got one free from a certain 4x4 mag and the pump works quick and well (it's prety quiet too) unfortunately, the first time i used it the seal on the brass valve fitting broke. Upon further insp the reason becomes clear, there's too much clerance between the flimsy silicone 'o' ring and the seating groove thus causing it to blow-out. An easy fix is to push the brass valve forward and wrap insulating tape behind it to keep it there. Poblem solved , easy and cheapo ......
p.s. I called the folks at Tmax and told them what happened , They were only too hapy to replace the offending component...... Coolio ......
AnswerID: 329990
Follow Up By: glennbo - Wednesday, Oct 15, 2008 at 12:05
thanx Doug for your response, ill follow your advice on the valve fitting.regards glennbo
FollowupID: 597461
Reply By: thomasando - Wednesday, Oct 15, 2008 at 23:50
I got one with a certain magazine too. I have only used it a couple of times but so far it hasn't caused me any grief. It has been pretty quick - it takes my 31" BFG's from 18psi back to 38 in 3 minutes.
I would like to give props to the company that distribute them here (Aunger) too. When it was delivered it was left on the porch and the dog got into the box and destroyed the air hose, bag, some of the fittings and the little rubber feet. I enquired about how much to replace these parts but they sent them out to me free of charge.
AnswerID: 330090
