Help Please - My R50 roof rails have come loose
Submitted: Wednesday, Oct 15, 2008 at 22:51
ThreadID: 62581 Views:2409 Replies:3 FollowUps:2
I have watched your forums for many years - and now just become a visitor in need of some advice if possible.
We (from Melb) have just completed the Gibb River Road and Bungle Bungles (and now in Derby) - I have a basket on the roof with an extra spare tyre.
I am now in Derby and noticed that my roof rails have come loose. Eg - I can lift the middle and rear mounting out of its place on the roof.
It looks like the nuts may have come loose from the retaining bolts -from the corrugated roads ?
Any suggestions on how this can be fixed ? Can it be done externally - or does the roof lining need to be removed ?
Thanks for any suggestions
Best regards JR
Reply By: Member - JohnR (Vic) - Wednesday, Oct 15, 2008 at 23:25
John, it may help to know what the roof rails are on - the car I mean. Jeepney, Disco, Exploder?
AnswerID: 330089
Follow Up By: donks1 - Thursday, Oct 16, 2008 at 07:30
R50 pathfinder i suspect
Donks1
FollowupID: 597593
Reply By: Member - Mick O (VIC) - Thursday, Oct 16, 2008 at 06:21
I had the rails and basket on my Navara. I thought the used a locking-self tapping screw or rivet of some description so they didn't have to do anything under the roof lining. It also kept the fastener head flat so it didn't impede the ability of the foot to slide up and down the rail. It would help to know how the rails appear to be fastened. Have you thought of giving a supplier like ARB in Perth or a 4x4 place in Broome or Karatha a ring. If it's a rivet situation, you'll only have to replace the broken pin or re-drill and use a slightly larger rivet.
Good luck.
Mick.
(Have you been keeping an eye on the screw tightness in the clamps on the feet? If they come loose a fraction of a millimetre, the vibration will cause the problem you have. I used to check mine every day on those rough roads. M)
AnswerID: 330099
Reply By: Member - Tessa (NSW) - Thursday, Oct 16, 2008 at 07:32
I am guessing you are driving a new VW Touareg. If so this has to be a warranty issue. Why not just ring the dealer and throw it in his lap?
tessa
AnswerID: 330102
Follow Up By: chisel - Thursday, Oct 16, 2008 at 07:35
Assuming it is a pathfinder, ask on pcoa forums
FollowupID: 597595
