Laptop battery not charging.
Submitted: Sunday, Oct 19, 2008 at 08:40
ThreadID: 62675 Views:2754 Replies:7 FollowUps:5
Gurus please help.
I've got an HP fliptop that I had repaired under warranty. Since it came back the battery won't charge. The battery didn't go with it for repair, that stayed with me and when I pout it back in it had 98% charge.
Since using it, it dropped to 25% and won't come up.
Before I spend time on the phone to HP tomorrow, does anyone know of a setting, or something, that may have been changed to switch off the battery charging programme?
Any and all advice will be happily received.
Jim.
Reply By: Willem - Sunday, Oct 19, 2008 at 08:46
Morning Jim
Simple tests first
A. Have you tested both AC and DC charging?
B. Are both the chargers working? Test them.
C. Have you switched the wall plug on?..lol
AnswerID: 330656
Follow Up By: Best Off Road - Sunday, Oct 19, 2008 at 15:52
They all seem to be working as the flippie runs when plugged in and the little icon down the bottom says it is charging.
As for C, that's not as funny as it sounds, but I'll not go into that for fear of making a complete goose of myself.
Jim.
FollowupID: 598355
Reply By: Notso - Sunday, Oct 19, 2008 at 08:48
If you take out the battery does the laptop run off the charger?
Try that, if it doesn't then the charger isn't working.
AnswerID: 330657
Follow Up By: Best Off Road - Sunday, Oct 19, 2008 at 15:53
Runs fine with or wihout the battery in.
Jim.
FollowupID: 598356
Reply By: nomadoz - Sunday, Oct 19, 2008 at 11:30
Hi Jim
Try this! control panel, power option, alarm, tic low battery alarm, slide level to 15%
Tick Critical battery alarm slide level to 10% that should reset
Joe blogg
AnswerID: 330703
Follow Up By: Best Off Road - Sunday, Oct 19, 2008 at 15:55
Tried that, but to no avail.
Jim.
FollowupID: 598357
Reply By: oz doc - Sunday, Oct 19, 2008 at 14:37
Hi Jim, My laptop did the same once. Turned out to be the battery not being 'clipped' into the laptop properly. Mine had two different buttons/clips that formed the mechanism to hold the battery in place. One of them wasn't fully in position and as soon as it was adjusted the battery would charge again. Worth a try I suppos. Doc.
AnswerID: 330725
Follow Up By: Best Off Road - Sunday, Oct 19, 2008 at 15:56
Gave that a try too, but the bloody thing still refuses to charge.
Jim.
FollowupID: 598358
Reply By: Mike Harding - Sunday, Oct 19, 2008 at 14:59
Sounds like HP's problem to me Jim.
Mike Harding
AnswerID: 330732
Follow Up By: Best Off Road - Sunday, Oct 19, 2008 at 15:57
Beginning to look that way.
Jim.
FollowupID: 598359
Reply By: Member - AJB (VIC) - Sunday, Oct 19, 2008 at 19:00
The battery on this laptop plays up at times and it is mainly due to leaving it hooked up to 240 for too long. Then it drops very low and does not charge. What I do is take the battery out of the laptop and sit it aside for half an hour or so. Then I shut down the laptop and re-insert the battery and it then charges up to the max again.
AnswerID: 330761
Reply By: Member - Malcolm C (QLD) - Sunday, Oct 19, 2008 at 22:47
Run on battery until almost completely flat. Then charge it fully.
Do this a couple of times to see if it works. If not, get somebody like BatteryWorld to test the battery.
living the 'good life'
AnswerID: 330821
