Diff Whine
Submitted: Sunday, Oct 19, 2008 at 17:13
ThreadID: 62689 Views:6590 Replies:8 FollowUps:0
Hi all,
My GQ (180,000km) has recently developed a rear diff whine which becomes evident (annoying) at 100km/h plus. I got the diff oil changed at the last service, is this likely to be caused by incorrect oil, or is this more likely to be permanent damage that will cost lots of $$$ to fix?
Graeme
Reply By: Member - Mick O (VIC) - Sunday, Oct 19, 2008 at 17:49
Can't answer your question directly but this site is a wealth of info regarding all things Patrol.
Mick
AnswerID: 330749
Reply By: mechpete - Sunday, Oct 19, 2008 at 18:27
it won,t be an oil issue ,
its an adjustment , contact between the crown wheel and pinion.
maybe a worn brearing
mechpete
AnswerID: 330753
Reply By: Member - joc45 (WA) - Sunday, Oct 19, 2008 at 18:31
Hi Graeme,
The oil change is the possible source. These diffs are pretty unbreakable, so I'd be checking that. Esp as it's only done 180k. They've probably used a "fleet" all-purpose gear oil!
When I changed the oil in the transfer case of my GQ-Mav, I used a Shell oil, and straight away, I got a whine at about 90k. Changing to BP multigear, same rating, fixed the whine. Not criticising Shell, but obviously, the characteristics must have been slightly different.
I used to use BP Limslip 140 in the diff of my GQ/Mav but you can only get it now in big drums. Currently running Castrol LSX85W140 in the diff of my GU, no problems (Nissan confirmed it as ok, even tho a straight 140 LSD is recommended).
It's not a great deal of money to change it and see.
Gerry
AnswerID: 330755
Reply By: MrBitchi (QLD) - Sunday, Oct 19, 2008 at 20:51
Just had the diff in the Statesman done (250,000Ks) as it developed a nasty whine full time. Cost me $850 and boy what a difference ;-)
Full set of bearings and re-lapped....
AnswerID: 330795
Reply By: Member - Paul W (VIC) - Sunday, Oct 19, 2008 at 22:17
Many years ago i had a VC SL/E commodore wagon, decided to change the diff oil one service, it started whining when coasting only, shouldnt have but any way that was at 190k,had sold it to friends and at last check before it was written off (395k) the diff had gotten no worse. cheers Paul
AnswerID: 330814
Reply By: Member - RockyOne - Monday, Oct 20, 2008 at 10:44
Cheap experiment! At a guess the oil should be about 140EP and add a dose (as per directions) of Wynns™ HPLS now called,it seems 'Gear Oil Treatment' 125ml plastic filler tube P/No 59420. Use only mineral based quality brand. Was there any shrapnel in the oil at the drain plug (magnetic). If no big chunks,just fair wear and tear if not using the Wynns product. We accidently ran our XC Falcon 600 kms with zero oil in diff that had been treated with the Wynns product. (Lesson: Don't make gaskets out of the cardboard on the rear of a writing pad. Or maybe pad makers should use gasket material for folk like me;-) Reckon you'l get another 50,000 ks out of it yet.We took our 1980 Diahatsu F55 off the road as we have too many other reg wheels. Always greased,by me,Wynns red grease. Still has all original universals and steer knuckle bearings. No slaack anywhere. I had bought new UVs to put in it at nine year old to do Cape York. Mechanic said no wear in originals. Still have the boxed UV's at home yet Dia is 28yrs & towed 2 ton plus on our tandem trailer often.
AnswerID: 330863
Reply By: Member - Hugh (WA) - Monday, Oct 20, 2008 at 16:09
Hi Graeme,
Nissan spec SAE140 limslip oil plus a friction modifier. I had issues with my diff ~ 20,000km after getting diff oil replaced by mechanic. Replaced oil myself (Penrite limslip 140) plus added friction modifier 150mls (Penrite limslip additive) and no problems since then.
Regards,
Hugh
AnswerID: 330909
Reply By: Ti Trol - Wednesday, Oct 22, 2008 at 21:26
Hi guys, thanks for the responses. I will be getting it serviced next week and will get the oil seen to as a start.
Graeme
AnswerID: 331314
