240 volt in to CT
Submitted: Sunday, Oct 19, 2008 at 20:55
ThreadID: 62697 Views:2760 Replies:7 FollowUps:9
Hi has anyone put 240v in to their CT, I currently have it set up for 12v and am in the process of building a new tailgate kitchen which i have some 12v outlets on the side of and the brother in-law asked if I was going to have any 240v ones which has got me thinking?
So does any one know what is required as I am thinking that I would want the inlet plug on the side of the tool box and then a point in the trailer box and some on the side of the kitchen.
Reply By: Tony - Sunday, Oct 19, 2008 at 21:06
Not only do you need inlet power point of 15amp, you will also need a circut breaker.
AnswerID: 330799
Reply By: Member - Matthew C - Sunday, Oct 19, 2008 at 21:17
Yeah i fitted it to my Trak Shak earlier on this year.
Some Photos.Image Could Not Be Found
AnswerID: 330801
Reply By: Hairs & Fysh (NSW) - Sunday, Oct 19, 2008 at 21:20
Have you got a Caravan and camping trailer supplier near you?
They will have everything you need, or an electrical supplier.
I've just completed my 12V setup and now I'm contemplating a 240V system as well, just for those occasions that we camp near 240v.
AnswerID: 330802
Reply By: Member - Paul W (VIC) - Sunday, Oct 19, 2008 at 21:20
Just make sure it complies with all your states relevant supply authoritys regulations for such an installation. cheers Paul
AnswerID: 330803
Follow Up By: Member - Matthew C - Sunday, Oct 19, 2008 at 22:27
All Equipment fitted must be double pole activated.
This means when you turn it on/off it breaks 2 circuits not just one.
MAtt
FollowupID: 598441
Reply By: Member - Oldplodder (QLD) - Monday, Oct 20, 2008 at 15:53
As Matthew has done above.
Had my local electrician around for some stuff in the house and he did the C/T while he was at it.
15amp waterproof plug on the outside, and a circuit breaker and a couple of 10 amp power points on the inside.
And he gave me a certificate to say it was professionally installed in case a caravan park queries it.
I run an extension lead(s) to a power board(s) where I run the few 240v things we use when occasionally on a powered site.
AnswerID: 330905
Follow Up By: Member - Paul W (VIC) - Monday, Oct 20, 2008 at 21:07
i hope an RCD/ELCB (safety switch) was fitted also?
FollowupID: 598631
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Oct 21, 2008 at 09:28
Paul,
Yes, that is what the switch is. Sorry, lay term for me is a 'circuit breaker switch'.
Thanks for the correction.
FollowupID: 598690
Reply By: oldtrack123 - Friday, Oct 24, 2008 at 23:20
HI All
I should point out it is illegal FOR ANY 240V WIRING ON VANS TRUCKS BUSS ETC OR ANY WHERE ELSE TO BE DONE BY ANYONE OTHER THAN A CERTIFIED ELECTRICIAN,.
EVEN OFFERING ADVISE ON HOW TO DO SUCH WORK COULD LEAD THE GIVER OF THAT ADVISE LIABLE TO CHARGES IN THE ADVENT OF AN ACCIDENT BASED ON THAT ADVISE.
iT IS OK TO SAY YES IT CAN BE DONE BUT IT MUST BE DONE IN ACCORDANCE WITH THE RELEVANT AUSTRALIAN STANDARDS.
IN THE EVENT OF AN ACCIDENT [ELECTRICAL] ALL INSURANCE WOULD BE NULL & VOID .
AnswerID: 331723
Follow Up By: _gmd_pps - Saturday, Oct 25, 2008 at 01:12
Why do you keep shouting ... and please stay at home with your lectures.
have fun
gmd
FollowupID: 599569
Reply By: oldtrack123 - Saturday, Oct 25, 2008 at 12:07
Hi gmd
Why do I shout? simple, because the message is not getting thru due to ill informed comments by self believed experts!!
The laws are quite clear on these matters, if you wish to break the laws that is your problem though others may suffer as a consequence.
I believe I have a duty of care to point out the possible consequences of illegal electrical wiring not only to the performer of such work but possible unknowing future users of such equipment.
If you don't like the "lecture" you need not read it, that's your choice & the possible consequences are also your choice .
To others , I say read my post consider it in the vein in which it is given[ not as a would be knowall or some one trying to protect their patch] but as a retired electrician with 60 yrs of experience , during which I have seen some horrifying & life threatening work done by some self believed experts.
Do you want yourself or a family member to be a possible victim of illegal unqualified elect work as it seems some on this & other forum would advice.?
I agree much of the advice given on forums is on the right track & given in a helpful manner, but some is outright wrong, .misleading & dangerous & yet many continue to push their line often based on the type of statement "I did it this way & I'm still alive so I must be right"
AnswerID: 331776
Follow Up By: Mike Harding - Saturday, Oct 25, 2008 at 12:34
It's only illegal in Oz because the electricians union managed to persuade government that they needed their jobs protected.
Many countries allow people to do their own low voltage wiring (UK, NZ etc) and they're not littered with the corpses of the burned or electrocuted. Basic low voltage wiring is very simple and does not require a high level of knowledge or expertise to do safely. Given the number of stores selling cable, fixtures etc into the public arena I would have thought this was self evident.
Mike Harding
FollowupID: 599616
Follow Up By: oldtrack123 - Saturday, Oct 25, 2008 at 21:20
Hi Mike
I am well aware of your views/opinions on the subject of anyone being allowed to do 240v work[simple?]. You have a right to express your opinion , but the point is the performance of such work by uncertified persons is illegal in Oz
Mike said
"It's only illegal in Oz because the electricians union managed to persuade government that they needed their jobs protected."
A strange statement ,since the greatest supporters of the existing situation are the various contractors associations[Business groups. this has also been supported by govt of all colours .
Mike said" low voltage wiring is very simple and does not require a high level of knowledge or expertise to do safely"
Yet the standards ass find it necessary to regularly refine & update the regulations, how many of those you propose should be allowed to do this work are aware tthat there are specific standards coveriing caravans etc.
Mike said'Given the number of stores selling cable, fixtures etc into the public arena I would have thought this was self evident"
Mike, you & I are both aware that because something is sold it does not neccesarily make the use of such legal ie after market car components , fitting lpg to autos ,gas & plumbing fittings such work again on health & safety grounds to be only carried out by qualified gas fitters &/or plumbers.
Mike I recognize by your many posts that you do have a high level of elect knowledge ,sometimes that can lead us to think that "it is so simple any one should under stand"unfortunately this is not always true.
I will know tell you of an incident my son [ a certified electrician]came across only today.He was asked to check out a fluoro that was not working in a home which showed some evidience of home handy man elect work. On removing the fitting he was horrified to find that the frame had been connected via green earth wire to the switch wire. The frame was alive when ever the light was on.
Needless to say that house is now up for a full inspection & test
HOW would you propose such errors, potentially deadly, be avoided if any one be allowed,to do such work.
FollowupID: 599721
Follow Up By: Dunaruna - Saturday, Oct 25, 2008 at 22:59
Mike, I think you would be shocked (pun intended) by the number of shody 'handyman' electrical repairs in vans. Just last week we had to rewire (12 & 240) a van that had caught on fire due to wiring faults that the owner created.
The list of stupid repairs is staggering, I've seen 12v circuit breakers used in 240v circuits, auto wires used for 240v, earth wires going nowhere (not connected), live frames, screws/nails through 3 core, earth wires connected to timber frame (my personal favorite).
FollowupID: 599739
Follow Up By: Mike Harding - Sunday, Oct 26, 2008 at 14:38
Thank you gentlemen for your considered replies. I could tell you a few tales of sparkies who should never be allowed near a multimeter too but it doesn’t prove anything. I suspect we’ll just have to agree to disagree :)
Just one thought, and I do believe it’s a gaping hole in your argument: Aussies are not less capable or less intelligent than Poms, Kiwis etc so how come they can manage to do home wiring and we can’t? One of the drawbacks of being such a remote island race is that we are not exposed to other cultures and lifestyles in the way (say) European nations are and that leads us into a tendency to believe our way is the only way.
Mike Harding
mike_harding@fastmail.fm
FollowupID: 599821
Follow Up By: _gmd_pps - Sunday, Oct 26, 2008 at 15:42
Dumb laws for dumb people .. and they get even dumber.
Electricians throw wires across attics with little protection, they connect up 12V transformers on top of chiprock ceilings with simple cable joiners (no junction boxes).. it took Australia how long to make RCD's mandatory ?? pathetic .. and thats not because there are so many dumb people doing worse jobs.. give me a break.
I have seen so many shotty jobs by so called "electricians" in this country it's not funny. I learn for an electricians exam in an afternoon, not much to it .. is it ??
have fun
gmd
FollowupID: 599827
