where to install 12v water pump in camper
Submitted: Sunday, Oct 19, 2008 at 22:04
ThreadID: 62699 Views:5147 Replies:5 FollowUps:0
could some one please tell me where the best place to install a 12v water pump in a camper would be 'thanks
Reply By: fwdfun - Sunday, Oct 19, 2008 at 22:09
How about between the water tank and the tap? Have the flow indicator pointing towards the tap. There are no rules, have fun.
AnswerID: 330812
Reply By: Member - JohnR (Vic) - Sunday, Oct 19, 2008 at 22:56
Close to the tank Baz&Mak so if it gaet something under a valve in the pump it doesn't have a great head to lift water to the pump
AnswerID: 330825
Reply By: Baz&Mak - Sunday, Oct 19, 2008 at 23:54
Thanks guys,It was a silly question i know but i was just worried about mud and salt water stuffing it up, if i were to install it under the traileri open to the elements
AnswerID: 330830
Reply By: The Rambler( W.A.) - Monday, Oct 20, 2008 at 00:05
Baz & Mak,
I don't think it makes that much difference where you install it providing you use a pump to do the job you wan't.What i would also do is to install an on/off switch to the pump as most systems are under pressure when the tap is turned off and if you get a leak while travelling or when the camper is folded up you could end up with a very wet camper.Iinstalled a switch near the battery which Iturn off when the camper is not in use which gives me eliminates any leakage problem.
AnswerID: 330831
Reply By: chocolate teapot - Monday, Oct 20, 2008 at 06:12
Hi Baz&Mak
don't think I would put it under the camper - somewhere protected - perhaps inside is a much better idea IMO - under a seat, cupboard, battery compartment or in some other hatch.
Most pumps have a lot of plastic and wont last long on a gravel road. You mention salt - the pump, your wiring and the connectors probably wont last long either if directly exposed to salt & moisture outside.
Have a pump installed in a cupboard no trouble - connected to 2 tanks through a y tap connector - most pumps can lift a bit - might take a little time to prime on first use after an empty tank - they have non return valves so it doesn't happen each use.
Hope this helps
AnswerID: 330840
