Vic High Country
Submitted: Tuesday, Oct 21, 2008 at 11:15
ThreadID: 62740 Views:2276 Replies:4 FollowUps:2
Will be visiting the high country for the first time over the xmas break and am seeking some suggestions for scenic routes that are only moderate in their degree of difficulty. Have a current hilux 4x4 but it is loaded to gvm with a slide on camper, so this is the critical factor when considering tracks/roads as the centre of gravity is quite high.
Have had a look through the trek section but lots of the tracks are probably not suited for my vehicle setup. Wife loves a good view so any moderate ridge top roads would be great.
Thanks for any suggestions
Reply By: Mike Harding - Tuesday, Oct 21, 2008 at 11:27
The Licola to Jamieson road is easy and has some great views.
Mike Harding
AnswerID: 331014
Follow Up By: ajd - Tuesday, Oct 21, 2008 at 12:47
Its also a logging truck road so beware!!
FollowupID: 598741
Reply By: Member - Shane D (QLD) - Tuesday, Oct 21, 2008 at 16:52
Better not go Here ! ! ! ! !.
Shane
AnswerID: 331060
Follow Up By: wicket - Wednesday, Oct 22, 2008 at 09:57
Shane
nice video, pity you didn't get to see the view......definitely a track sans the slide-on!
FollowupID: 598941
Reply By: On Patrol & TONI - Tuesday, Oct 21, 2008 at 17:34
Gday wicket
If you have a GPS look at my plot posts, http://www.exploroz.com/Plots/Default.aspx
Days 1-7, they give you some tracks, that while a challenge, would suit a vehicle of your description.
They start off mild and end up wild. But still do able by MOST cars with 4WD & reasonable clerance.
Cheers Colin.
AnswerID: 331064
Reply By: wicket - Wednesday, Oct 22, 2008 at 09:45
Thanks guys, will check them all out.
AnswerID: 331180
