How do I prevent fuel fumes in vehicle from a chainsaw?
Submitted: Wednesday, Oct 22, 2008 at 11:31
MADOG
Is there an "airtight" carrying device for when we carry a chainsaw inside the LandCruiser. My wife is allergic to
fuel fumes and I prefer to not have a roofrack so where to from here?
Would appreciate any advice as to what is available to contain the fumes.
Reply By: Goona - Wednesday, Oct 22, 2008 at 11:46
Madog,
Not sure if this will get rid of all the smell with the case of the chain saw but I have a similar situation with the outboard when I put it in the back of the Patrol. All I do is run the motor until it runs out of
fuel. This alleviates any
fuel smells.
Goona
331192
Reply By: Nomadic Navara - Wednesday, Oct 22, 2008 at 11:47
Probably the best solution for someone like you is a twin cab with a canopy over
the tub. You sit in one capsule and put the smell in the other.
331193
Reply By: Member - DAZA (QLD) - Wednesday, Oct 22, 2008 at 11:52
Hi Madog
How about Wrapping it up in a Small Plastic Tarp, you can get small
Tarps around 2 metres square, or even smaller, and they are cheap.
Daza
331194
Reply By: Redback - Wednesday, Oct 22, 2008 at 11:55
I put
mine in my rear wheel rubbish bag, keeps it out of the car, my misses has the same problem as yours.
This was the easiest solution for us.
Baz.
331196
Follow Up By: Member - Willie , Sydney. - Wednesday, Oct 22, 2008 at 14:42
Baz,
That's a good strong looking rubbish bag , what brand is it . I have buggered a couple already so I am looking for a good one .
Thanks ,
Willie .
598977
Follow Up By: Redback - Wednesday, Oct 22, 2008 at 14:53
Homemade Willie, Kerry bought the canvas and sewes it, i designed it.
There is a rear rubbish bag on the NSW/ACT4WD Asoc website that'son special ATM for $99 reduced from $120, it looks pretty sturdy.
marketing @4wdnsw-act.asn.au
I don't know you need to be a member to get the discount.
Baz.
598980
Follow Up By: Member - Willie , Sydney. - Wednesday, Oct 22, 2008 at 15:23
Baz ,
That is a email address. Did you mean for me to email them and ask them ?
I could find nothing on their website - maybe it's in the members section.
Thanks,
Willie.
598984
Follow Up By: On Patrol & TONI - Wednesday, Oct 22, 2008 at 19:25
Willie
While I have seen that 4WD NSW bag, it is
well designed and
well made, "for rubbish" and wet recovery straps etc.
I would not be too sure how it would handle the rigours of carrying a chain saw bouncing up & down in it however.
Cheers, Colin.
599035
Reply By: A J - Wednesday, Oct 22, 2008 at 12:07
Madog - have not tried this, but if I had that problem.
1. Place a rubber or metal seal under the lid but you may have to remove it before using to allow the
tank to breath.
2. If the saw is not too big, buy a plastic container with a filled lit. The place door weather seal under the lid to tighten the seal.
A J
331198
Follow Up By: Member - lyndon K (SA) - Wednesday, Oct 22, 2008 at 12:15
As said above, run it out of
fuel but also open the lid on the
tank to let any residual
fuel evaporate.
598966
Reply By: brushmarx - Wednesday, Oct 22, 2008 at 12:16
It generally only takes a couple of minutes to remove or replace the blade and chain, and you could store the engine/
fuel tank in a 20 litre plastic paint or plaster drum, or a screw top plastic container big enough.
Good luck.
331199
Reply By: Hairy (NT) - Wednesday, Oct 22, 2008 at 13:17
Stihl make a plastic chainsaw carry case.
You could see if it fits in one of them and wrap some duct tape around the join to make sure?
Image Could Not Be Found
331205
Follow Up By: Wisey - Wednesday, Oct 22, 2008 at 17:24
I'm with you on this one. Huskvarna (sp?) also do the box. Although a bit bulky, with some attention on cleaning, sealing and
fuel draining as mentioned. Wrap saw in cloth and cling wrap or Cling wrap will further seal the box for long periods of non use.
Andy
599007
Follow Up By: Member - Glenn D (NSW) - Wednesday, Oct 22, 2008 at 17:49
I have done almost the same thing , except I am a bigger tight arse, LOL
I just got a storage box from GO LO ,cut a hole to let the cutter bar through ,wrapped the saw in an old towel . Also have room for a
fuel container and bar oil .
Packs easy cause its square.
Glenn.
599016
Follow Up By: Member - Paul W (VIC) - Wednesday, Oct 22, 2008 at 20:20
Yep i did the same as Glenn,cut a slot in a 30l? tub and put some foam around the cutting bar then jam it in the box and put the lid on.
fuel can and spare chain in it too. no smell and stores
well with other tubs. Paul
599051
Reply By: Member - Willie , Sydney. - Wednesday, Oct 22, 2008 at 14:48
Madog,
I bought a canvas chainsaw bag from :
www.infrontcampinggear.com.au
It does not solve the problem , but I keep the chainsaw really clean by wiping away oil and petrol, and it all helps.
Willie.
331219
Reply By: Moose - Wednesday, Oct 22, 2008 at 15:22
G'day MadDog
Last time I carried the saw in the back of the Cruiser I too was worried about the
fuel smell. It's bloody hard to keep the fumes contained. The saw and all the bits and pieces live in a wooden box. The
fuel can (plastic container) I double wrapped inside those Woolies type plastic shopping bags. Just changed them for new ones each time it was used. Likewise I wrapped the engine of the saw itself as best as I could in plastic bags (obviously have to let it cool after use). It worked pretty
well although on really hot days after the vehicle was left standing for a while there was some odour, but not too bad. The box probably helps a fair bit too.
Cheers from the Moose
331226
Reply By: Peter_n_Margaret - Wednesday, Oct 22, 2008 at 15:35
Here is a different alternative.
Get an inverter and run an electric chainsaw (or a reciprocating saw which will cut ANYTHNG with the appropriate blade)
Peter.
http://www.tinyurl.com/OKA196-PnM
331231
Follow Up By: Member - Tony B (QLD) - Wednesday, Oct 22, 2008 at 17:57
Peter. Never though of that even though one sits in the shed. They are about 1800w though, do you consider a 1kva inverter genset could run that even through an inverter. I have never used an inverter for the
camp. Cheers Tony
599020
Follow Up By: Peter_n_Margaret - Wednesday, Oct 22, 2008 at 21:20
Tony B, I was referring to a 12/240V inverter running off house (or crank) batteries, not a gen set.
A 1kva gen set would not run an 1800W saw, but a 2kva inverter would run it easily (with the motor running).
1800W is "only" 150A at 12V. About half or less of what a winch needs, and these things would be OK on modifies sine wave
inverters which are pretty cheap. 1800W is a huge drill, angle grinder, any 240V tool you can think of.
We have a 1300W pure sine wave inverter that runs every 240V tool that we need (plus the computer, and the bread maker, and the electric jug, and....and....)
Peter.
http:www.tinyurl.com/OKA196-PnM
599069
Reply By: Member - Royce- Thursday, Oct 23, 2008 at 00:29
Swap the chainsaw for an axe and handsaw....
331352
Follow Up By: Richard Kovac - Thursday, Oct 23, 2008 at 00:57
maybe get new wife.. LOL
599121
