OT How to flush a 5hp mercury boat motor
Submitted: Wednesday, Oct 22, 2008 at 17:07
Member - Boo Boo (NSW)
I have been told to put the motor in a rubbish bin full of fresh
water, but I have a storage problem when travelling.
I have also been told there is a bolt on the side that comes out and a hose fitting can be screwed in, but being aluminium it will wear fairly quickly and this is not recommended. These words of wisdom came from a dealer.
Has anyone got a better idea?
Regards Bob
Reply By: Member - Rodney B- Wednesday, Oct 22, 2008 at 17:23
You should be able to get a pair of rubber "ears" that connect directly over the
water inlets and you connect a hose to it and run the motor to flush it. I've done this on every outboard from 15HP to 225Hp successfully. You could attach it to your trailer or caravan draw bar to start it I would think .
331245
Follow Up By: Member - Boo Boo (NSW) - Wednesday, Oct 22, 2008 at 17:35
Rodney
For the larger motors you are right. I use earmuffs on my 50hp, but the little motor does not have
water inlets where they normally are.
I am going to try what Keith has suggested
Regards Bob
599009
Reply By: Member - Keith C (NSW) - Wednesday, Oct 22, 2008 at 17:27
Gday Bob,there is a screw just beside the g/box filler plug on my 6,it`s painted the same as the motor,remove it and screw a Merc flush connector in, join up hose,turn on
water,start motor,easy,I use it all the time,reverse sequence when finished.I dont think it would be easily damaged.Very handy when travelling and simple to use ,better than the ear muff type.Good luck.Keith C.
331246
Follow Up By: Member - Boo Boo (NSW) - Wednesday, Oct 22, 2008 at 17:31
Well I was told to steer clear of that method, but if you have no problems then thats the way I'll go.
Thanks for the info
Regards Bob
599008
Reply By: toyocrusa - Wednesday, Oct 22, 2008 at 17:29
Hi. I thought with the smaller motors you could purchase a flushing plate that attaches to the underside of the gearcase covering the
water pickup. You then connect a hose and run the motor in neutral with
water tap turned on. I also put m.a.c.s through
mine after a couple of hours running to help resist corrosion.(It stands for Marine Anti Corrosion System) It is used extensively up in the Northwest where they have a high salt content in the sea
water. It is available from good marine outlets and accessory stores. Regards, Bob.
331248
Follow Up By: Member - Boo Boo (NSW) - Wednesday, Oct 22, 2008 at 17:39
Thats something to look at the next time I am close to a boat
shop.
Thanks for that.
Regards Bob
599012
Reply By: Member - Keith C (NSW) - Wednesday, Oct 22, 2008 at 17:53
Bob,The connector is a small brass thread with a click on hose doover attatched,you don`t even need a spanner,simply tighten by hand.Before you replace the plug after flushing,give the thread a drop of oil,I`ve never had any probs. Keith C.
331256
Follow Up By: Member - Boo Boo (NSW) - Wednesday, Oct 22, 2008 at 18:03
Thanks keith
599022
Reply By: Sand Man (SA) - Wednesday, Oct 22, 2008 at 20:20
Boo Boo,
I have a 4hp 4 stroke Mariner and a 15hp 2 stroke Merc and the "ears" fit over the
water inlets, which are on the side of the lower shaft housing, on both outboards.
Give the "ears" a go seeing you already have them and providing you see
water being expelled from the outlet, you are flushing OK.
Bill.
331288
Follow Up By: Member - Boo Boo (NSW) - Thursday, Oct 23, 2008 at 12:03
Thanks Bill
I'll go and have a look. I presume you're talking about just above the propeller.
If not I'll try standing it in the bucket and see if that works
599181
Reply By: Member - Rob S (NSW) - Wednesday, Oct 22, 2008 at 20:21
Hi Bob
I just use a 20 litre bucket, one of those white plastic heavy duty ones to flush my 4hp evinrude . It is is light enough just to sit in the bucket and hold it by hand to start and run it.
The bucket also comes in the boat as
well for carrying fishing gear etc, so it is not a storage problem.
Rob.
331289
Follow Up By: Member - Boo Boo (NSW) - Thursday, Oct 23, 2008 at 12:05
Thanks Rob
As I have said above I'll go and have a look and use the muffs if possible, failing that the bucket.
599182
Follow Up By: Member - Boo Boo (NSW) - Thursday, Oct 23, 2008 at 12:39
Rob
I have used my fishing bucket and it worked fine. Just fits.
I pointed the tell tale hose away from the bucket and only needed to put a little
water in the bucket to keep it full.
It appears that the inlet is just above the prop on the underside of the 'flat bit'.
599186
