Identify this GQ aux tank
Submitted: Wednesday, Oct 22, 2008 at 19:41
Mick15
Hi guys, as the thread says can anybody give me an idea as to who makes this particular
tank, its 70 litres for a gq, and was used as a main
tank when the vehicle was converted to gas....
Thanks for your replies
Mick
[img]
[/img]
Reply By: Sir Kev & Darkie - Wednesday, Oct 22, 2008 at 19:47
Reply By: Member - Mick O (VIC) - Wednesday, Oct 22, 2008 at 20:02
I'd second that. Long Range Automotive at
Lilydale.
Cheers Mick
331282
Reply By: SteveL - Wednesday, Oct 22, 2008 at 22:56
Have to agree with others, I have one the same in my GQ. If you are fitting it,pay particular attention to the way you attach the rear of the
tank. I had both rear bolts (only 8mm) break on the
Kalumburu Rd. and the
tank was close to dragging on the road.
-Steve
331342
Reply By: ingo57 - Thursday, Oct 23, 2008 at 16:23
Hey Mick
I have one exact same in the shed, my brother was looking at putting it on his GQ but we couldnt find a maker. It should have some ID numbers stamped on it. If you find out post it on here please.
331455
Reply By: Brew69(SA) - Thursday, Oct 23, 2008 at 16:35
Lots of people make one that looks like that. It's a standard belly
tank install done with most lpg conversions.
Mine was brandless.
331457
Reply By: Mick15 - Thursday, Oct 23, 2008 at 18:30
Okay, thanks people, looking at buying it to run as a aux
tank on a diesel gq, figure if i get it i'll remove the sender and give the inside a good clean, then wire bush and give the outside a good coat of killrust epoxy enamel.
Probably then hook a transfer pump between it and the main.
And thanks for
the tip SteveL i'll run 12mm high tensiles with nylocks if there is room.
Just a little concerned as ive heard of one brand in particular having a few issues with bad welds and leaking...
331484
Reply By: GlenJ - Saturday, Oct 25, 2008 at 07:55
Not a longranger
tank
http://
shop.ebay.com.au/merchant/oot-2007
most likely a brown davis or Longrange automotive
But as said before lots of people make this for cheap and sell to gas market
331741
