roller draws
Submitted: Thursday, Oct 23, 2008 at 09:23
Dingo99
I am looking at putting roller draws in my ute (styleside tray). I already have a factory hard plastic ute liner in it. Do most people remove the liner or leave it in when fitting a draw system?
Dingo
Reply By: Best Off Road - Thursday, Oct 23, 2008 at 09:32
Depends on two things.
1. If the liner is there to seal the body leave it in.
2. If it isn't, get rid of it, that way your drawers can be made longer and wider.
Jim.
331380
Follow Up By: Dingo99 - Thursday, Oct 23, 2008 at 11:09
Jim,
Yeah the liner doesn't seal the body so i guess I can get rid of it, also how do ute owners seal the tail
gate when doing river crossings so ute contents don't get wet? Are there after market liners that allow tail
gate to open some how as
well as seal when need be?
599168
Follow Up By: Best Off Road - Thursday, Oct 23, 2008 at 11:26
When we fit our drawers we don't worry about it. Generally the only opening is at the back tailgate and the movement of the car stops any significant ingress of
water. We manufacture our drawers on 17mm support rails so that they are raised off the floor to allow "breathing" between the drawers and the floor.
If you get stuck in the river,
well the tub will let
water in no matter what you do, as will the cabin.
Jim.
599171
Follow Up By: Dingo99 - Thursday, Oct 23, 2008 at 14:54
Jim,
Thanks for the info.
dingo
599203
Reply By: Member - Mick O (VIC) - Thursday, Oct 23, 2008 at 18:50
I made a drawer system for the Navara and left
the tub liner in. I sealed the tailgate by using 25mm x 7mm neoprene tape from Clarke rubber that was sticky on the one side. I ran it round the edge of
the tub and pushed the tailgate up hard against it when closing. More for dust than
water but it did the job.
Cheers Mick
Image Could Not Be Found
331491
Follow Up By: Dingo99 - Wednesday, Oct 29, 2008 at 10:48
Mick
thanks for the idea, have a navara also, will have to give that stuff a go.
dingo
600303
