Friday, Oct 24, 2008 at 22:59
Hin Krakka
Before spending money on monitors etc you need to find out exactly where why you are loosing power
Try following steps as set out:
#1 isolate fridge from cruiser bat IE DISCONNECT BAT LEAD.
#2 WITH FRIDGE SWITCHED TO MAX & CONNECTED TO VAN [A] DOES IT RUN OK?? IF so what is voltage @ terminals WHILE RUNNING??
[B] IF NO
CHECK WHAT VOLTAGE ARE YOU GETTING @ VAN BATS??
[C] IF VOLTAGE @ BATS OK
CHECK BETWEEN POS & NEG LEADS PROGRESSIVELY @ EACH ACCESSABLE POINT[YOU MAY NEED TO REMOVE SOME COVERS OFF PLUGS] TOWARDS FRIDGE .
IF YOU SUDDENLY FIND A SIGNIFICANTLY LOWER VOLTAGE AT SOME POINT ALONG THE PATH THAT WOULD INDICATE THE PROBLEM IS BETWEEN THAT POINT & THE IMMEDIATLY PREVIOUS GOOD READING.[ IT COULD BE DRY SOLDERED JOINT , CORRODED CRIMPED CONNECTION ,SIMPLY POOR DIRTY/LOOSE CONTACTS OR A BROKEN WIRE]
[D]NOTE ALL READING MUST BE MADE WITH FRIDGE CONNECTED @ TURNED ON EVEN IF IT IS NOT RUNNING, ALTERNATIVELY YOU COULD SUBSTITUDE head lamp bulb or some similar type of load
#3 DO NOT REALY ON COUPLING & FRAME FOR NEG LINE USE ,RUN HEAVY NEG CABLE FROM BATS TO FRIDGE
599552
