Iridium and Telstra Sim use
Submitted: Thursday, Oct 23, 2008 at 20:10
Member - Graham H (QLD)
Bought a nearly new 2nd hand Motorola 9505A today.
Put my Telstra Sim Card in it, turned it on, went outside waited about 30secs for a sat lock on, dialled
my home number away we went. How easy is that.
Peace of mind on our trip now.
Reply By: Member - Footloose - Thursday, Oct 23, 2008 at 20:33
Just remember not to chat too long on it. The call charges are quite savage :)
331508
Follow Up By: Member - JohnR (Vic) - Thursday, Oct 23, 2008 at 22:54
Jim, I did a spreadsheet a few months ago comparing the cost against a stock standard $30 a month plan to find the breakeven was around 120 minutes and 50 calls for the call costs. If you make a lot of calls or do a lot of calls the account pays as it would for you. To get the breakeven at that level you have to gainfully use the 10 minutes a month that you get for your $30 or the breakeven is even greater call times.
On that account, one friend has his live in his car whenever he is out driving so he uses it. I recon you can get cheaper calls quite frankly on even Telstra mobile.
599340
Follow Up By: Member - Footloose - Thursday, Oct 23, 2008 at 23:04
John, having a long day. Are you saying that the break even point between the $30 a month with the $10 free and putting the Telstra simcard in at about $3.80 a minute is around 50 calls ?
Does this mean that the sim card or the $30 month is cheaper for fewer calls ? Sorry mate, brain is lagging at the moment (as usual).
599342
Follow Up By: Member - JohnR (Vic) - Thursday, Oct 23, 2008 at 23:33
I can send you the spreadsheet Jim, the breakeven slides upwards if you can't use the free calls EVERY month. The breakeven if you DO or CAN make use of them is about 120 minutes plus the dial up air time for about 50+ calls.
That means if you don't use it for more than 40 calls, say and two hours the global roaming sim card is cheaper and a LONG way cheaper if you don't use much of your $120 of free calls over the twelve months. The $10 a month can't be accumulated, you have to use them or lose them.
I also plugged in the charges if Pivotel for a trial and it really didn't do any better, just playing at the edges. You must plan to use the phone a lot to warrant paying account fees whichever company.
599346
Follow Up By: Member - Footloose - Friday, Oct 24, 2008 at 10:32
Thanks John, the brain is in better shape this morning :)
Yep, I can remember doing a similar exercise and still the Telstra card comes up roses.
599394
Reply By: Trekkie (Member - WA) - Thursday, Oct 23, 2008 at 20:55
What did you pay for the Motorola
331513
Reply By: hl - Thursday, Oct 23, 2008 at 20:59
Just make sure it was actually using the satellite and not the GSM network on that call........or you could be in for a nasty surprise when you do have to use it in the bush.
331515
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 23, 2008 at 21:14
A Motorola Iridium phone doesnt and CANT use the GSM network.
It is a Satellite only phone regardless of where in the world you use it.
Only Ericcssons and the like on the Globalsh+t network were dual mode phones as far as I am aware
Yes Im aware of the charges and because I was home alone and outside I couldnt answer it anyway. I just tried it and disconnected when the home phone rang.
Main reason for posting was because of the doubters who think the Telstra sim card doesnt work.
I paid $950 with all accessories.
599310
Follow Up By: Motherhen - Thursday, Oct 23, 2008 at 21:21
Well done Graham - looks like you have a bargain and can use it without too much further cost.
599314
Follow Up By: hl - Friday, Oct 24, 2008 at 06:34
Thanks for that info.
Sounds like a good opton if you only need to use it occasionally.
By the way, you can also use a Telstra phone SIM in their nextG modems and get reasonably cheap internet within coverage areas at without a contract.
599366
Follow Up By: Member - Graham H (QLD) - Monday, Oct 27, 2008 at 16:08
Well I dont consider ANY of Telstras internet prices could be considered "reasonably cheap" in comparison to other providors
Unfortunately until Optus get their network enlarged we have to put up with being ripped off unmercifully to put it mildly.
599988
Reply By: Gramps (NSW) - Thursday, Oct 23, 2008 at 21:18
Graham,
That was with "global roaming" or similar enabled ?
331520
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 23, 2008 at 21:42
As far as I know it is and dont think it works if its not.
I asked for it to be done when I got the account ($49 cap plan) with this in mind.
Yes a good buy still has the plastic cover on the screen.
Only for emergency use so wont be using it too much hopefully.
599321
Follow Up By: Gramps (NSW) - Thursday, Oct 23, 2008 at 21:49
Thanks. I thought that was the case.
599328
Reply By: Big Woody - Thursday, Oct 23, 2008 at 22:20
It works
well doesn't it Graham?
I did exactly the same with my 9505a with my sim card. I have used it a few times and call costs have varied but ususally work out at about $3.50 per minute.
I picked
mine up from the Tender Centre, completely unused and still sealed in original box with all accessories. Have a guess how much?????
$250..................Bargain. It had a $1200 reserve too.
Enjoy travelling with peace of mind that you are never out of range.
Brett
331541
Follow Up By: Member - Footloose - Thursday, Oct 23, 2008 at 22:58
Pardon my ignorance, but what is the Tender Centre ?
599341
Follow Up By: Muddy doe (SA) - Thursday, Oct 23, 2008 at 23:25
A place where my old man spends WAY too much time!
599344
Follow Up By: Big Woody - Friday, Oct 24, 2008 at 06:58
Hi Footy,
The Tender Centre is like an auction house except it is only open for 3 days each fortnight for a silent bid type process.
The reserve prices are listed on each item and you just write the item number and the amount you are prepared to pay for it on the bid sheet and at the end of the 3rd day you are notified as to whether your bid is successful because it is thwe highest bid over the reserve, or as in my case, the seller accepted my bid even though it was way under the reserve price.
Less stressful than auctions and you can visit at your own leisure to place your bids.
There are a few different franchises around.
The Tender CentreThe Tender Center
BW
599369
Follow Up By: Member - Footloose - Friday, Oct 24, 2008 at 10:36
"A place where my old man spends WAY too much time!" You have to love that comment, Muddy. Perhaps they have a bar there :))
Thanks for that, Woody, looks interesting.
599396
Reply By: Mark - Saturday, Oct 25, 2008 at 20:13
Graham,
I also have a Telstra SIM in a 9505a on a $10 plan & I think call cost are $3.80 a minute so only emergency use really. I had to pay Telstra around $200 up front in order to get global roaming enabled on the SIM so it would work in the Sat phone, they just keep deducting the $10 from the amount I paid upfront. The only drawback with the Telstra SIM is you can't send or recieve text messages. I got an Iridium account with TR telecom when we went to Africa last year & it was $30 a month for four month term, this was better as sending mesages to peoples email is cheap & they can reply for free so great way to keep in touch with family when in the middle of nowhere.
Mark
331850
Follow Up By: Member - Graham H (QLD) - Saturday, Oct 25, 2008 at 20:22
Wasnt aware of that. Will try it tomorrow.
My sim was roamed for free.
I just bought a new phone on Ebay and took it in to the local Telstra
shop and they ported the account stuff over to the new phone. I said could you internationally roam it please as Im going overseas and they did it and it works.
Will let you know if messaging works
599710
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 26, 2008 at 12:45
Sorry to say but you are incorrect.
I have a prepaid Telstra sim that I got with a phone I bought for my wife. I activated it in a spare mobile phone and here is the result.
I can send a text both to it from the Sat phone and from it to the Sat phone.
I can also ring a voice call to the Sat phone from it (it has int roaming enabled automatically)
You cannot however use the prepaid card in the Satphone
My sim I use in the Sat is just my Cap plan card I use every day.
Dont know why yours wouldnt work but it doesnt pay to tell Telstra too much as they can disable bits if they want to
599812
Follow Up By: Mark - Sunday, Oct 26, 2008 at 18:09
Thanks, thats interesting. I tried it about 14 months ago & it didn't work then, my normal mobile is an Optus phone though so maybe thats the issue & it doesn't work across different networks, or perhaps Telstra made a change to allow text messages through Sat phones.
My family were using this site to send free messages when we were touring Botswana & Namibia
http://messaging.iridium.com/
I think you need an Iridium SIM for this one though.
I'll dig out the Sat phone & try sending a text from an Optus mobile.
599845
Follow Up By: Mark - Sunday, Oct 26, 2008 at 19:34
Ok just tried to send a text from an Optus mobile to 9505a with Telstra SIM, it didn't work. However I sucessfully sent a text from the 9505a to the Optus mobile & noticed it placed a 61 in front of the number, tried a reply to the text but it never came through. So it seems you can send text from the 9505a with Telstra SIM to other mobile networks but possibly only recieve them from a Telstra mobile & not other carriers.
599855
Follow Up By: Austravel - Sunday, Oct 26, 2008 at 20:50
I've done the same with my GSM sim card. Pretty sure though it's $3.80 both making and receiving calls.
599862
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 26, 2008 at 21:34
As per the manual you have to put 0061 in front of the australian mobile number or in some cases +61.
So it would be 0061 405 123456 ( no spaces)
Apparently when transmitting via satellite it needs to know which country it is sending to.
Im no expert as Ive just got it but playing with it for a while it worked.
It also was working whilst I was sitting inside my house.
Doubt that networks would make much difference but will try tomorrow to send a message to my son who is on Vodafone
599869
Follow Up By: Member - Graham H (QLD) - Monday, Oct 27, 2008 at 16:04
Well found out this
I managed to send a Text FROM the satfone TO a Vodafone number but trying both the prefixes 0061 and +61 it would not send one back.
Will experiment later in the week.
599987
Reply By: Dean - Monday, Oct 27, 2008 at 10:14
Hi all,
Just to confuse the issue even more. An iridium phone can be used around town with a telstra gsm sim and international roaming turned off, obviously dearer call rates.
Ive been with TRTelecom for over 3 years now, costs about $200 per year which includes all calls texts etc. Never any doubt or confusion you get with trying too save a few bob with using other sims, the thing simply works and you know the exact cost.
No doubt it costs more, but you get piece of mind and convienience where it may be needed most.
Dean
332077
Follow Up By: Member - Graham H (QLD) - Monday, Oct 27, 2008 at 10:35
Well looking on TR Telecoms website there is nothing like that listed.
Only the two below and at the call rate prices I wouldnt be running around town with one of these. Waiting for a lock on and risking getting the aerial broken at $300+.
http://www.trtelecom.com/pdfs/Call%20Plan%20$30%20Suspension.pdf
http://www.trtelecom.com/pdfs/Call%20Plan%20Australian%20Post-paid.pdf
599922
