GQ turning circle
Submitted: Friday, Oct 24, 2008 at 22:04
Ti Trol
My GQ has always had the turning circle of the Queen Mary until my brother pointed out a couple of bolts on the rear of the ball joints. I adjusted these right in and hey presto I can suddenly manage U turns at traffic lights. But my concern is: will I chew out my CV joints from excessive turn angles? Why were they set to such a poor turning circle in the first place?
(Note I have tried to post this on the Nissan Patrol
Forum, but still can't get into it.)
Graeme
Reply By: Member - Graham H (QLD) - Friday, Oct 24, 2008 at 22:11
They are usually set like that for a reason and excessive angle will be one of them. Tyre scrubbing will be another.
In saying that we have 6 identical buses and we have to do a U turn at the end of a street with markers round the edge of the turning circle. One bus just gets around if you get it exactly right. The others have varying clearances. The best is over a meter inside the worst one. So much for identical.
331709
Reply By: Nav 8 - Saturday, Oct 25, 2008 at 11:53
I have had the same experience as you and I can tell you the GU Patrol and Navara are no different. I have owned the three of them and complained to Nissan about it when I had the GQ, I was told that's the way it is. I also had a look at adjusting it myself but decided against it because of the effect it may have on the CV joints and power steering. Regards ,,,Nav.
331773
Reply By: Member - Davoe (Yalgoo) - Saturday, Oct 25, 2008 at 14:24
tojos are the same
331794
Reply By: Member - Duncs - Saturday, Oct 25, 2008 at 23:04
My old GQ had an OK turning circle, it was never great but it was not too bad either.
I had some work done on the
suspension and when it came back it was hopeless. A mate pointed out the bolts so I adjusted them until it was turning as it had previously. This was a bit hit and miss but it ended up about the same.
Anyway I forgot all about it until you posted this. The last thing that broke on the GQ before I sold it was the drag link. It is apparently not uncommon on GQ's that have worked hard.
Mine stripped a nut and the ball joint popped out but most of them break the ball joint.
When I was looking for a replacement about 90% of them had severe scoring on the ball joint behind the rubber boot. I wonder if this was caused by excessive turn angles adn is the reason the Queen Mary turns so tight, relatively.
I don't know just raising it as a possible answer to your question Graeme
Duncs
331890
