Cleaning Silicon off Aluminium
Submitted: Saturday, Oct 25, 2008 at 22:01
ThreadID: 62883 Views:7171 Replies:3 FollowUps:3
I am sure I am not the first.
I want to clean the silicon off all the edges of the caravan.
The previous owner thought he would fix the leak by siliconing every join and window on the van Without cleaning back the bits that squeeze out. Of course once a bit of dust has settled on it the once clear silicon now give the van a very dirty look.
Is there an easy way or product that will dissolve it?
Once it is all off I am planning to pull the windows and edges off and do the job properly along with a new paint job.
Are those retro 70"s snails ...they had character.
Actually this one is a dream to tow and don't bounce all over the place.
Also I think I read somewhere what the correct sealing compound to use is but can't remember now. I am sure someone will give me the answer.
Thanks in advance.
Reply By: Isuzumu - Saturday, Oct 25, 2008 at 22:25
David hi, clean up with eucalyptus oil, after getting rid of the bulky stuff. As far as sealing windows/ alloy etc use a GLAZING silicone.
Cheers Bruce.
AnswerID: 331882
Reply By: Member - Graham H (QLD) - Saturday, Oct 25, 2008 at 22:29
Turps takes it off also.
I would be looking at a Sikaflex product rather than silicone for sealing.
After years in the roofing trade we found that silicone always pulled off one side or the other due to expansion, vibration or just differences in materials.
Sikaflex stays pliable and is much better
AnswerID: 331884
Follow Up By: Member - Graham H (QLD) - Saturday, Oct 25, 2008 at 22:33
Forgot to say that I was told by a reputable Caravan repairer that when resealing to scuff the aluminium where you are sealing with some fine sandpaper. Just enough to take the shine off it, makes the sealant grip better.
He reckons if manufacturers did this his work would halve.
FollowupID: 599737
Follow Up By: disco driver - Sunday, Oct 26, 2008 at 00:49
Graham, you are right. Sikaflex is much better, it remains flexible and waterproof for much longer.
A couple of words of warning though.
There are a fair number of Sikaflex products, make sure that you get the right one for what you want to do.
Sikaflex sticks, like shiete to a blanket, to everything and needs a very steady hand when applying it if you don't want it to go everywhere (I found this out by experience doing the same thing with my 'van).
Disco.
FollowupID: 599751
Follow Up By: Isuzumu - Sunday, Oct 26, 2008 at 14:23
Sikaflex will not stick to glass, polycarbonate and perspex it looks ok for awhile but it just does not work. Where do I get this boat building for 25 years. Its great with the same materials, timber to timber etc.
Cheers Bruce.
FollowupID: 599818
Reply By: Member - Andrew (QLD) - Saturday, Oct 25, 2008 at 22:45
Selleys brings out a silicon removing compound ===> http://www.selleys.com.au/Selleys-Silicone-Remover/default.aspx
Just be aware of the suitability of this product on some surfaces/materials.
Andrew
AnswerID: 331886
