New LED table lamp - at 4X4 show
Submitted: Monday, Oct 27, 2008 at 09:12
ThreadID: 62926 Views:5699 Replies:3 FollowUps:4
LED table lamps have been around for a couple of years now , but
none has attracted our attention enough to purchase until we saw this new product at this weekends Melb 4X4 show.
It provides effective light from a small package and has a number of good design features.
The idea of a table lamp for us is a robust small package that is portable and can be picked up quickly and placed on a table away from the car when camping and requires no power led.
It must have enough light output to be able to make dinner with.
There are many designs out there, often with twin fluro tubes
and with large high reflectors to push the light down onto a table
surface. Some of these like the Coleman units put out more light than one we purchased and are a better light depending on the way you camp and do things.
So, as in most things you need to understand your requirements first.
This lamp has the following features which have made it better than the many we have seen before.
First the light output is 300 lumens from 3* 1 watt LEDs (previous units about 45-70).
This is roughly the equivalent of a 4watt fluroscent tube, which is still significantly down on your standard general purpose 11watt U-tube work light.
The LEDs are Nichia brand, while the advertising hype on led products tells you that leds last forever, they don't, and heat and poor quality bonding compounds see most of the cheap ones lose light output and can die whereas ones like these can last for 100,000 hours. I have specified this type of LED for large scale government projects on the basis of long and stable life.
This lantern runs for 25 hours on 3 X D cells, double this on its low power setting.
It also has a flashing mode and a small "always active" low power green led which flashes weakly each 5 seconds- presumeably so that you can locate it in the tent in the dark.
Its not designed for external power use, and in fact its entire makeup is one of small compact and robust design. The entire unit is only 190mm tall by 80mm wide.
The batteries are in the base with a light diffuser above which makes it very stable.
This is enhanced with rubberized non-slip moulded casing on its base, sides and top, so that it can be knocked on dropped with low breakage risk.
The good design continues to its carry handle which folds in close and neat and is also rubber covered to stop those annoying rattles that can come from the usual chrome plated metal ones.
The light output spread is good and sufficent to shine down onto a small table surface however maximum light output is upwards at about a 15 degree angle.
This is where those units with a big high reflector outperform this product.
However this lamp incorparates two cute tricks, first is a plastic hook moulded into the base so it can be hung upside down , and the second is that the reflector assembly easily twists off. This provides a powerful wide angle light which can be used torch like, or to provide a quite effective concentrated
light spot more than a meter across, when hung from an awning.
We found this lantern particulary effective on the floor in a tent or when placed to check under the car.
Replacing the batteries, is slightly tricky as the cover is keyed and better indication for alignment could have been made.
The packaging it comes in is not useful as a permanent holder to prevent scraps in the car. We cut the top off a square plastic 2 liter fruit juice and put ours inside this with a rubber band over the whole thing for storage.
Manufacturer Primus
Model Primus NOVA Max led lantern part no. 591123
Supplier Ray's
Cost at show $60
Reply By: Member - Alastair D (NSW) - Monday, Oct 27, 2008 at 11:18
Robin,
Thanks for this alert. I am on the lookout for exactly this type of light. I have a Coleman fluro desk lamp which is excellent but it does attract a lot of bugs. Our small LED torch/light does not attract but does not give enough light for the table. Will have a look at this one
thanks
alastair
AnswerID: 332097
Follow Up By: Robin Miller - Monday, Oct 27, 2008 at 12:41
Ok Alastair , I think actually ours came from the Aussie disposals store stand not Ray's although it will probably become available widely over the coming weeks.
FollowupID: 599941
Reply By: Member - Andrew (QLD) - Monday, Oct 27, 2008 at 14:31
Is there any photos around of this product Robin?
There is only one Rays in Qld (cairns) so will have to look elsewhere to see one in the flesh. :-(
Andrew
AnswerID: 332135
Follow Up By: Robin Miller - Monday, Oct 27, 2008 at 15:08
I think mine came from the Aussie disposals stand Andrew - Its a new product and not even in the primus website yet , but you can't go wrong if you go by the model number - if I get a chance I'll try and take a picture but this is unlikely before to-morrow.
FollowupID: 599979
Follow Up By: Member - Andrew (QLD) - Monday, Oct 27, 2008 at 16:04
Andrew
FollowupID: 599986
Follow Up By: Robin Miller - Tuesday, Oct 28, 2008 at 08:08
Have added a photo in my members photo area Andrew.
FollowupID: 600129
Reply By: Member - JohnR (Vic) - Monday, Oct 27, 2008 at 18:37
Some friends of ours have a rechargeable torch supplied by Snap-On, but I can't find it in the catalog. It is blue and folds in the middle hiding the LEDs. It showed a great light outside of their Karavan. The recharger is 240v though rather than 12v.
AnswerID: 332178
