Mounting reversing camera screen in GU sunglasses holder???
Submitted: Monday, Oct 27, 2008 at 11:33
geocacher (djcache)
Has anyone found a brand of screen for a reversing camera small enough to fit into the sunglusses pocket up in the roof light/mirror area of the GU?
I'm thinking that would be a good spot for it and I could hopefully still close it when it's not in use.
I don't mind having to modify the sunglasses pocket as it isn't deep enough for most sunnies anyway.
Thanks,
Dave
Reply By: Member - Roachie (SA) - Monday, Oct 27, 2008 at 12:11
Can't really answer your question, but have done a bit of "work" in that area of my GU.
I removed the standard mirror and made a right angle steel bracket that utilises the "break-away" system (for safety reason) and then mounted my 5" screen to that bracket.
As for the sunglasses holder, I removed it and mounted a speaker for my
HF radio in there. It is a "noise-cancelling" type speaker which has a switch on it to supply 12 volts to enable the cancelling feature to operate. It also has a earphone jack on one side. I can still access these features....the speaker is sort of half-in and half-out of the hole.
I would imagine that any screen that would fit in the sunglasses holder would be too small to be practical, maybe......
Good luck
Roachie
332108
Reply By: geocacher (djcache) - Monday, Oct 27, 2008 at 13:58
Thanks Roachie.
I'm thinking a 2.5" screen or similar. They don't need to be really big. The ones built into the
Ambulance mirrors are about that size.
I didn't really want to replace the mirror.
The noise cancelling on my HF is a function of the NGT so I just mounted the HF speaker under my
seat. Works quite
Thanks,
Dave
332133
Follow Up By: Member - shane (SA) - Monday, Oct 27, 2008 at 20:13
hi mate, i have fitted one in the sunglass holder as you described.
got it off eBay about three years ago, works fine for me. when not in use i close flap and the screen turns off via a micro switch.
cheers Shane.
600031
Follow Up By: Bekali - Tuesday, Oct 28, 2008 at 00:24
Hi Shane, dont suppose you could give us a little more info on the one you bought from ebay so I (we) can see if we can find one aswell? It sounds like a perfect solution.......
cheers Bek
600101
Follow Up By: geocacher (djcache) - Tuesday, Oct 28, 2008 at 13:36
Hi Shane,
Thanks for that. If you don't still have the details on it would it be possible to post a photo of your setup on here or email it to me - dave at davejones.com.au?
Thanks very much & I really like the microswitch idea.
Dave
600172
