Tow vehicle suitability
Submitted: Monday, Oct 27, 2008 at 15:45
garbage
I'm eyeing a lightweight Royal Flair caravan with a tare weight of 830kg to be towed by a 4 cylinder, 2.0L Subaru
Liberty (smaller engine than the standard 2.5 Liberty/Outback) with a kerb weight of 1400kg. I'm planning to have a weight distribution hitch put on as
Assuming there was an average load in the car and caravan, would this be safe towing?
garbage
Reply By: jdwynn (Adelaide) - Monday, Oct 27, 2008 at 17:42
Garbage, I reckon it could be ok when van loaded up - bit marginal though. You find when van about same weight that you dont feel so in control. Suggest you follow car manufacturers recommendations (for insurance if nothing else). cheers JD
332167
Reply By: Member - Graham H (QLD) - Monday, Oct 27, 2008 at 18:53
Basically it boils down to this
If the ATM on the plate on the van exceeds the manufacturers
recommended towing capacity You may not legally tow it with
that vehicle.
Doesnt matter if its full or empty thats the law.
As Ive said before it cost me $23,000 to be wrong
332181
Follow Up By: Member - Graham H (QLD) - Monday, Oct 27, 2008 at 18:57
Alsp remember that the towball weight is part of the load in the tow vehicle and must be allowed for
Eg load capacity 300kg Ballweight 100kg
Means you can only put 200kg in the car including
fuel You and the load
600014
Reply By: coley - Tuesday, Oct 28, 2008 at 22:08
Just ring Hayman Reese , they will tell you every thing you need to know
Cheers Coley
332414
