Are 60 seris and 80 seris split rims the same?
Submitted: Monday, Oct 27, 2008 at 21:03
Member - G N (VIC)
Hi again
Last post for toninght i promise.
Are 60 and 80 seris split rims the same?
Many thanks
GN
Reply By: Peter 2 - Monday, Oct 27, 2008 at 21:51
No, different offset and different appearance.
332242
Follow Up By: Member - G N (VIC) - Monday, Oct 27, 2008 at 21:56
mmmm thats what i was starting to think,
i have always just asumed they were the same, so for trailers this could be an issue.
thanks Peter 2
GN
600063
Reply By: Member - Phil G (SA) - Monday, Oct 27, 2008 at 22:46
The 80 series split has more backspacing than the 60 series split.
I know a few people who use the 60series splits on their 80series because it widens the track.
332259
Reply By: Member - Footloose - Monday, Oct 27, 2008 at 22:52
No. As above.
332262
Reply By: Peter 2 - Tuesday, Oct 28, 2008 at 06:02
As Phil said you can run 60 series rims on an 80 resulting in a slightly wider track, might upset the legalities though ;-))
80 series rims won't fit on anything earlier as they foul the front brakes and narrow the track, not something you want to do on 75 series ;-))
A relatively common change is to fit 60 series diff housings to a 75 as it widens the track by about 80mm, then fit 80 series rims which widens it further, increases the stability of a 75 no end. Also solves the problem of the small front diff in a 75
332285
Follow Up By: Member - G N (VIC) - Tuesday, Oct 28, 2008 at 08:37
Hi Peter 2
thanks for that, i would of also guessed that a 75 seris was no narrower than a 60 seris, but have never owned one or taken enough notice.
So are the 80 seris splits identifyable by the circle pattern cutouts around the center section. My mates are like this but would it be safe to asume all 80 seris rims have these circles and all earlier ones dont?
Kind Regards
GN
600137
Follow Up By: Member - Davoe (Yalgoo) - Tuesday, Oct 28, 2008 at 09:19
only 1990 on 75s had smaller fron diffs AFAIK
600144
Follow Up By: Peter 2 - Tuesday, Oct 28, 2008 at 18:32
That's correct Davoe
600223
