CV & Uni alternative.
Submitted: Monday, Oct 27, 2008 at 21:13
ThreadID: 62963 Views:2599 Replies:5 FollowUps:2
Thompson Couplings
These may not be new to some buy many would possibly not have seen them before. Its a 32MB file but an interesting film.
Cheers Colin.
Reply By: On Patrol & TONI - Monday, Oct 27, 2008 at 21:15
Try this one.
Ooops
AnswerID: 332227
Reply By: Richard Kovac - Monday, Oct 27, 2008 at 21:41
Colin
it make you think why it takes so long for someone to come up with a better thing.
pulsating has all ways been a big problem in engineering drive shafts at an angle.
Richard
PS. I have seen and read about it before but it's very interesting
AnswerID: 332237
Reply By: joff1 - Monday, Oct 27, 2008 at 22:27
It is 2 uni's (same as a double cardan). The trick bit is keeping the angles right.
AnswerID: 332255
Reply By: BoldJack ( Penrith NSW) - Monday, Oct 27, 2008 at 22:43
G'Day Col
Yep, seen it on The new inventers on the ABC a while back very clever , be great for extreme drive line applications ;).
Cheers Bert
AnswerID: 332258
Reply By: Member - DOZER- Tuesday, Oct 28, 2008 at 11:26
Very informitive Col.....now i know where my economy went whem i lifted the cruiser. The jury is still out for me on whether you should swap back to the Ni##an transfer case....you got to love the lower gearing in low, amd i bet you would like to try some taller 4.2t diff ratios, which would change the speed at which the vibrations start occuring too.
AnswerID: 332314
Follow Up By: On Patrol & TONI - Tuesday, Oct 28, 2008 at 18:57
Andrew
The drive line specialist is looking at it as we speak, I will see what comes of that before anything else. The transfer case option is a long shot that will possibly never happen. Jason is also investigating the Thompson option along with the specialist.
Will keep you posted.
Cheers, Colin.
FollowupID: 600227
Follow Up By: Member - DOZER- Tuesday, Oct 28, 2008 at 20:07
Dunno if id go that way Col, u cant get em out the back of Blackall :)
Id be looking at fitting a double cardon because i fixed my front tailshaft vibration issues that way on mine.
If that didnt work well enough, id be looking at a 80 series rear diff as a further upgrade...they come in 4.1 .. i know nis##n do 4.1 up front...80's run fully floating axles up back...a third option that would assist to lower vibration would be to lift her up .... dont know if thats an option or not....doggy might protest
Andrew
FollowupID: 600241
