New clutch for GU
Submitted: Tuesday, Oct 28, 2008 at 14:01
ThreadID: 62982 Views:3523 Replies:8 FollowUps:10
Hi all,
About to put a new clutch in the old GU TD42-T. Most of the postings I find recommend the Exedy replacement and I have a leaning to this one.
But a parts mob in Perth are suggesting an Adelaide Clutch (Clutch Pro, or Aust Clutch Service) replacement. Can anyone recommend one over the other, or offer any comments on either.
I could go back to Nissan, but I expect they'll be the usual Nissan prices.
Thanks in advance,
Gerry
Reply By: geocacher (djcache) - Tuesday, Oct 28, 2008 at 14:05
Hi Gerry,
Out of curiousity, how many km did the old one do?
Dave
AnswerID: 332328
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 28, 2008 at 14:47
Hi Dave,
It's done 200,000, but the main problem is that it drags, making selecting gears difficult. It's been doing this on and off since about 100,000, but it's getting bad now.
While it was still under warranty it played up; Nissan reckoned it was wear and it wasn't covered. Funny that it's done another 100,000 since then!
I suspect the main problem is the spigot bearing, but since the gearbox has to come out, the whole clutch will be done ,esp at that mileage. It certainly isn't slipping.
I've already replaced the clutch master cylinder on the off-chance that that was the problem. No change.
Gerry
FollowupID: 600178
Reply By: Member - Nick (TAS) - Tuesday, Oct 28, 2008 at 14:34
Just put a Exedy Safari Tuff clutch in our cruiser and am very pleased with its transformation.Original clutch had 92000kms on it and looked new but oh man did it shudder.Shudder is now gone, clutch pedal feels the same pressure but did need to lengthen m/cylinder push rod a little to get clutch pedal off the floor.This was the most recomended clutch to me.
AnswerID: 332332
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 28, 2008 at 14:50
Thanks, Nick
As per my comments to Dave above, it doesn't slip or shudder, just drags. Tried lengthening the shaft as much as I could without closing up the gap, but no change.
FollowupID: 600179
Reply By: Robin Miller - Tuesday, Oct 28, 2008 at 14:36
There are a few Gerry , I noted 2 at the melb 4wd show
which were supplying heavy duty clutches along with lightweight
flywheels for my 4800 GU.
On the clutch I would need to be convinced on getting other
than Nissan as mine has done 173,000 and still seems to work
despite a little shudder now and then.
Because of the difficulty of measuring how much is left on them
I'm thinking I should replace mine before I get seriously embrassed
with it somewhere.
The 2 I saw could not give me an answer on pedal pressure required and I would rather a standard item than an unnecessary HD one which required more pedal effort.
AnswerID: 332334
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 28, 2008 at 15:01
Hi Robin,
Yes, have to agree that the original clutch has lasted the distance as per my comments to Dave above, and I suspect the spigot bearing is the culprit, not the clutch.
Will give Nissan a ring anyway just to check the cost. My mechanic reckons he'd go for the Nissan one, but obviously, if I can get a replacement which is just as good or better, but somewhat cheaper, then that's the way I'd prefer to go. It's just that Nissan's prices are a bit rich.
The bottom line is, I guess, that with the high labour cost on this job, it's silly to skimp on the parts. I just want to make sure that I choose the best replacement.
Gerry
FollowupID: 600180
Follow Up By: Member - Matt (Perth-WA) - Tuesday, Oct 28, 2008 at 15:01
Robin, absolutely the added pressure on the master and slave system components is also a good reason to not purchase a cheap HD clutch. If they increase the clamping pressure by increasing the pressure plate springs then the chance of a hydraulic failure is increased significantly.
A good HD clutch will build into it more clamping pressure with the spring medium and compensate by changing the pivots as well.
I fitted two clutches to two identical 2.8 TD Isuzus..one Safari (Exeddy) and one standard and the operation and feel are miles apart....love the Safari one!
Matt.
FollowupID: 600181
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 28, 2008 at 16:46
Hmmm, looks like a Nissan clutch kit is very similar in price to an Exedy.; ie, around the $750 mark. A Safari Tough is about $200 more. The Adelaide Clutch, HD is a smidge over $600.
Might go for the Nissan version.
Gerry
FollowupID: 600202
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Oct 28, 2008 at 20:18
I think the Nissan clutch is about $600 over the counter, The standard clutch is good value, mine has the original and has 250,000ks now and works fine and my old GU, 99 model 4.2td original clutch has just been changed at about 380,000KS Michael
FollowupID: 600243
Follow Up By: Member - Ed. C. (QLD) - Wednesday, Oct 29, 2008 at 02:44
Well Gerry, ya need to let your fingers do the walkin'.........
Earlier this year I bought a Exedy Safari Tuff kit (TD42T) for $630.00 "walk away, no more to pay" from my local brake & clutch place... from memory, the dearest quote (for the exact same part#) was in excess of $800.00..........
The reason I changed it was that a few weeks before a planned desert trip, I'd discovered oil weeping from the bellhousing:((
You guessed it.. rear crankshaft oil seal.. BUGGA!!
OK, since I needed to fix the oil leak anyway (as a matter of urgency), and since I'd "smoked" the clutch on a couple of occasions prior, I reckoned it'd be a good idea to replace that as a matter of course, even though it was showing no signs of slipping, though it had developed a noticeable shudder, mainly in reverse...
As it happened, the original showed no signs of wear (at 150K), w/- no discernable difference in thickness between it and the new one..
There were some scorch marks on it though, as well as on the pressure plate & flywheel, which I had machined out of the flywheel, of course...
All in all, I'm happy with the Exedy clutch.. pedal pressure is no more (if anything, a little lighter), though Exedy claim superior clamping force, and I reckon "take-up" between gears is smoother.. more "seamless", if you like;-)
Would I go Exedy again? on current indications, most definitely!
(YMMV)
Regards, Ed C
Confucius say.....
FollowupID: 600285
Follow Up By: Member - joc45 (WA) - Friday, Oct 31, 2008 at 12:01
Looks like my mech can get the Nissan clutch for a bit over $400+gst. What a markup for us mere mortals! I'll go with the Nissan one, as I've had 200k out of it.
But I must admit, I've heard nothing but good reports about the Exedy range.
Thanks guys
Gerry
FollowupID: 600705
Reply By: Shaker - Tuesday, Oct 28, 2008 at 16:17
Wouldn't a lightweight flywheel be a disadvantage in a 4WD?
AnswerID: 332350
Follow Up By: Shaker - Tuesday, Oct 28, 2008 at 16:18
Sorry, meant to hit Follow Up to the previous post. ^^^^^
FollowupID: 600197
Reply By: Bonz (Vic) - Tuesday, Oct 28, 2008 at 22:50
FWIW The Exedy comes with the greatest of reputations, the biggest researcher, procrastinator and complicators of process, ex EO-er LUCKY had got the Exedy in the Droopy and he would've researched it to death.
His decision would be enough to convince me to go for that should I need another clutch in the GU
AnswerID: 332422
Reply By: trainslux - Wednesday, Oct 29, 2008 at 09:04
The Clutch from Adelaide clutch will be fine.
I knew those chaps when they were in a small workshop behind ours.
They have an amazing range, and al top quality stuff.
would not hesitate to use their product at all.
currently running one of their clutch's in my hilux, and one in my old falcon, which is over 15 years going strong in it.
Trains
AnswerID: 332467
Reply By: brett patrol - Wednesday, Oct 29, 2008 at 11:48
G'day Gerry,
Go with a H/D clutch from clutch industries. I have one in my GU and is unbreakable. They are supposed to be better than other aftermarket clutches because of the avatiation grade material they are made from and are less than $100 dollars more expensive.
Just my 2 cents.
Brett
AnswerID: 332491
Reply By: steve58 - Friday, Oct 31, 2008 at 10:00
Hi Gerry
I have a GU nissan it has done 110,000 klms the clutch was getting very lumpy mainly 4th & 5th. I was told by a mechanic to replace clutch talking $1500. I changed the oil in the gearbox and added some PRO-MA MBL8 oil additive it is now like brand new. Maybe this will help you.
Steve.
AnswerID: 332820
Follow Up By: Member - joc45 (WA) - Friday, Oct 31, 2008 at 11:55
Hi Steve,
Once I have actually pulled the box into gear, (ie, overcome the spinning shaft), the clutch works fine. No shudders, no grabbing, no slipping. It certainly seems like the spigot bearing. The clutch was doing this occasionally while under warranty (not warranty, all wear and tear, according to Nissan), and when Nissan took the gearbox out to fix 5th (about 120k), I asked them about the condition of the clutch and was told it was fine. At this stage, it was working ok, so I took no further action. But with both old and new gearbox oil, the fault is the same, only worse now.
Gerry
FollowupID: 600703
