Driving Lights Feedback
Submitted: Tuesday, Oct 28, 2008 at 15:48
rab2008
HI,
I'm new to this site and probably unaware of the ethics. Anyway, I have a problem with IPF lights they are dead on my 2005 Kluger. All the wiring and Installation was previously present and sold with the car and I didn't change any wiring. I have tried new IPF relay from ARB and 2 switches with led indicator but lights didn't ON. The fuse in the yellow wire was blown off since then i have replaced the fuses but no luck so far. Can't even hear the On/OFF clicking of IPF relay and moreover left highbeam is not working. I have checked the globe it is not blown.
There are 3 wires inside car, 1 Yellow with the fuse, 1 black and 1 black n white.
The switch configuration is: Pwr 12V, Acc and Earth. i connecte the yellow wire with pwr, black n white with earth and black with Acc. and then later on variety of connections. I had spent hours and hours to play with the switches with different settings but of no use.Led on switch is not ON as
Any Idea what went wrong with it?? How I can fix this myself??
Looking forward for the replies.
Thanks in advance.
Reply By: Member - Graham H (QLD) - Tuesday, Oct 28, 2008 at 16:33
Would suggest that Black should be earth. Run a wire from battery+ to the relay and see what happens Did the loom not come with a diagram
332357
Reply By: Member - Matt (Perth-WA) - Tuesday, Oct 28, 2008 at 17:45
Rab I would firstly remove all connections for the spotlights and correct the high beam on the vehicle first. If the spots are using that high beam feed to switch them on...then nothing will work no matter what combination you play with later.
Once that is sorted then replace all the other fuses in the wiring loom and look here for a diagram that is very similar to the IPF one!
ABR - Derek
Matt.
332376
Reply By: Louie the fly (SA) - Tuesday, Oct 28, 2008 at 19:06
If you disconnect the wiring from the lights and connect a wire to the battery on + & - sides do they light up? It could be that they are wired to the left high beam circuit (not working) as someone else suggested, so this should be fixed. Also check the plug and wiring cause if the previous installer did a bodge job the connections may have come apart.
Does the car have separate fuses for each headlight circuit?
332387
Reply By: Bekali - Wednesday, Oct 29, 2008 at 23:08
This may sound a little silly but '2005' model, is the car still under warranty? if it is take it to toyota.......
332570
Reply By: rab2008 - Thursday, Oct 30, 2008 at 16:38
Many Thanks Folks.
I will try to do it over the weekend and let you guys know.
Thanks.
332675
Reply By: chucky135 - Friday, Oct 31, 2008 at 09:32
G'day Rab
Two things you need to check, first it sounds like you have a dead short between the relay and battery as you seem to be blowing fuses, and second it could be that you alternator isn't big enough. The alternator needs to be able to supply enough power to run all the lights and everything else electrical in the car that would normally be running at night. Most Klugers only have a 65 - 75 amp alternator which may not be enough.
Simple formula for working out your power needs; add up the watts for all lights (including parkers and brake lights), dashboard, indicators, AM/FM radio/CD player, interior light,as
well as the spots; Then divide the total by the volts carried by the battery (12 or 24). The answer is the amps that you need to be able to draw from the alternator. If this number is bigger than the amps rated on the alternator, you need to install a bigger alternator....around 110 amps normally. Also you should have one relay operating on each twin set of spots and run 5-6mm cable from the battery side to each spotlight to the relay and use thinner cable for the switch in the cab. This will reduce voltage drop over the circuit. Hope all this helps mate.
Ian
332817
Reply By: rab2008 - Monday, Nov 03, 2008 at 16:19
Hi All,
Thanks for the Help.
I managed to fix the problem by replacing one blown fuse in the Relay box and now my IPF lights are alive again. I was saved from the tedious work. Thanks for all your help and support.
Now I’m facing another issue with the engine. I’m hearing engine knocks between speed of 30-60kms when ever I press for the gas. Also I found it bit hard to speed up on the freeway. Did anyone face such kind of situation??
This car had recently done 80000kms and major service was carried by Toyota, on Friday I went to servicing department for this issue. I and their foreman went for the inspection drive and at the end of the trip the foreman told me that either Auto-trans or engine mount is creating problem. But he didn’t believe in auto-trans problem as the auto-trans light warning is not ON in the panel. I told them that this problem has occurred after the servicing and it was not there before.
As per my pervious experience with the Commodore, Air filter (which is clean in this case) and spark Plugs needs to be replaced and this will fix the problem. I’m planning to give the car to Toyota on Friday the 7th Nov 08.
What you guys suggest? Please advice.
Thanks in Advance.
Rab
333415
