Camry fuel filter
Submitted: Tuesday, Oct 28, 2008 at 17:42
ThreadID: 62988 Views:4865 Replies:2 FollowUps:9
G'day, Can someone please tell me how to access the "in tank" fuel filter on a 2004 4cyl Camry?
Thankyou
Krakka
Reply By: Member - Phil G (SA) - Tuesday, Oct 28, 2008 at 18:16
I've replaced it on a 2002 Corolla. I'm guessing it would be very similar to the camry.
Take negative off battery.
Ensure tank is not full of fuel.
Lift out back seat.
Unscrew round cover.
Unscrew tank pump/sender/ pick up unit and lift out.
Be careful with the sender arm as it looks fragile.
The filter is a plastic clip-on unit that contains the pump. Disassembling it is straight-forward. From memory, the pump was fiddly to remove from the filter. Put new filter in the same way it was removed.
reassemble the lot.
AnswerID: 332384
Follow Up By: Krakka - Tuesday, Oct 28, 2008 at 18:21
Thanks Phil, is the seat easy to remove, asking because it had 75k service today and it doesnt look like seat has been removed to me. Also only charged 1.2hrs labour, for oil, filter etc.
Krakka
FollowupID: 600220
Follow Up By: Member - 120scruiser (NSW) - Tuesday, Oct 28, 2008 at 20:01
They wouldn't have changed it. The toyota in tank filters are about $95.00. If you are doing it yourself take particular care with the o rings. If you loose one you will not be able to gain fuel pressure and they don't supply a new one with the kit.
The filter is a fairly big white round unit and the fuel pump usually sits down inside the centre of it. A bit fidly but doable.
Scott
FollowupID: 600240
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 28, 2008 at 20:16
Krakka,
Fuel Filter Change is done at the 80k service.
FollowupID: 600242
Follow Up By: donk - Tuesday, Oct 28, 2008 at 20:51
The camry is on 15,000 klm intervals not 10,000 klm like the corolla so this is why the filter is changed at 75,000 klm service
Is there a filter charged on the invoice as they dont take long to do
Regards Don
FollowupID: 600246
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 28, 2008 at 22:48
Whoops.....Thanks for the correction Don!
FollowupID: 600275
Follow Up By: Krakka - Tuesday, Oct 28, 2008 at 23:16
There is a filter charge Don, $59.75 + labour, How is the seat removed? I don't see an easy way of removing it. The only bolts that I can see are at the rear of the seat with the backs of the rear seat folded down, and they look untouched to me.
Krakka
FollowupID: 600282
Follow Up By: donk - Wednesday, Oct 29, 2008 at 00:18
From memory the seat base frame has a wire loop on either side at the front that sit down into white retainers in the floor panel
To release it you pull the front of the seat upwards & the base will come out
Regards Don
FollowupID: 600284
Follow Up By: Krakka - Wednesday, Oct 29, 2008 at 12:32
Thanks Don, couldn't work out what those wires were for.
Krakka
FollowupID: 600316
Follow Up By: Member - Tour Boy Springsure- Wednesday, Oct 29, 2008 at 13:52
Hi guys,
does the 98 bug eyed 112 series corolla have one as well or only the later ones.
Dave
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 600331
Reply By: johannagoanna - Wednesday, Oct 29, 2008 at 08:34
Yeah, I had a Camry before the Pathfinder, it is under the back seat. Pretty easy job to do!
Jo
AnswerID: 332455
