mitsubishi triton
Submitted: Thursday, Oct 30, 2008 at 12:52
ThreadID: 63040 Views:3645 Replies:5 FollowUps:2
i have a 98 v6 auto triton sometimes when it is hot the engine cuts out , i pull to the side of the road put it in neutral hit the key and away i go
i took it to the local ford dealer (no Mitsubishi dealer in town Mt Isa) he just told me to take it to a Mitsubishi dealer. bright boy closest dealer a 1000k away in Townsville
has anyone had this or a similar problem
thanks Michael
Reply By: Member - Doug T (NT) - Thursday, Oct 30, 2008 at 14:38
Could be fuel vaporising , old Len Beadell had that problem with his Landrover in the hot WA Outback, he poured water over the fuel lines around the Carby , of course yours wont have a carby but still could be the same problen of vaporisation in the heat, You need to look at getting more air in there , have those Tritons got a bonnet scoop, the 2005 had one.
Image Could Not Be Found
AnswerID: 332649
Follow Up By: Member - Doug T (NT) - Thursday, Oct 30, 2008 at 14:41
On checking my folders I see the 2002 and 2007 models do not have scoops.
FollowupID: 600487
Follow Up By: Brian (Montrose, Vic.) - Thursday, Oct 30, 2008 at 20:56
That was onlt the turbo diesel ones Doug, same as I drive
FollowupID: 600612
Reply By: Member - Madfisher - Thursday, Oct 30, 2008 at 14:40
Michael their is an excellent forum at Vic pajero club. Sorry I cannot provide a link, but someone on tthat site should be able to help you.
Good luck Pete
AnswerID: 332650
Reply By: peteC - Thursday, Oct 30, 2008 at 16:55
Had a similar problems with a cars over the years.
1. Turned out it was the coil. When it got hot it internally broke down.
2. The fuel filter was mounted under the bonnet next to the fuel pump. The filter was before the pump and when it got hot the fuel vapoured in the filter and the pump was not able to clear it. Fixed by swapping the hoses so the filter was after the pump.
AnswerID: 332684
Reply By: Neil & Lynne - Thursday, Oct 30, 2008 at 17:07
Hi Michael
Go to Pickerings in Mt. Isa, they are the Mitsubishi dealers.
We took our Triton there a couple of months ago and received good service.
The address and phone number is -
59-65 West St
Mount Isa, QLD 4825
(07) 4743 4622
Neil
AnswerID: 332690
Reply By: chucky135 - Friday, Oct 31, 2008 at 09:13
G'day Michael
This is a simple fix that should get you out of trouble! Buy yourself some stainless steel & asbestos heat shield plate and bolt it in between the fuel pump, filter and lines & the main engine block and head. It sounds like the heat from the engine is vaporising the fuel before it gets to the injector pump and rail. I had this problem years ago and this fixed it!
Good luck mate and happy trails.
Ian
AnswerID: 332811
