Petrol vapour leak - how to find?
Submitted: Thursday, Oct 30, 2008 at 18:11
Member - John R (QLD)
Hi all,
I've noticed recently that there is no release of pressure when the
fuel cap is opened on our Hilux, and there is a petrol smell noticeable around the
fuel tank area when you pull up. No obvious
sign of liquid petrol leaking though (it's a cab chassis, so you can see the filler pipes and
tank).
Has any
forum reader had experience in efficiently finding what is probably a small crack in a filler pipe somewhere, or a faulty petrol cap? Have thought of using very soapy
water to try to find where the vapour is leaking, but not sure if this is the best idea.
Thanks, John
Reply By: Robnicko - Thursday, Oct 30, 2008 at 19:03
John,
Most likely the seal on the
fuel cap. Being a petrol engine the seal on the
fuel cap is part of the
fuel system pressure.
On a sunny day if there is a
fuel vapour leak you may see a shimmering effect like at
the servo when you fill up.
I very much doubt it would be a crack in the filler pipe as they usually have a rubber section between it and the
tank to allow for body flex. Check the vent hose, if there is one, along the filler section.
Rob
PS> apart from the obvious check with a match!....had to get that in before someone else
332714
Follow Up By: Member - John R (QLD) - Thursday, Oct 30, 2008 at 19:42
Match test might be a bit too permanent, Rob :-)
The reason I suggested a crack is that I have seen this where the small bypass(?) pipe joins the main filler pipe just below the cap (I assume when you fill, liquid petrol goes down big pipe, displaced air/vapour back up and out bypass pipe).
Thanks, John
600586
Follow Up By: Robnicko - Thursday, Oct 30, 2008 at 22:04
The bypass pipe is to allow for quicker filling (air dissipation), bit like the spout nozzles on jerry cans. If cracked it would most likely be the source of the leak as it is directly connected to the
tank.
Good luck
Rob
600627
Reply By: simple - Thursday, Oct 30, 2008 at 19:04
i always thought the breathers were meant to prevent that, but i may be wrong
332715
Reply By: Grizzle - Friday, Oct 31, 2008 at 10:15
I had the same issue on a Mitsubishi Triton. It turned out to be the filler cap. It has and internal valve which was playing up on
mine. $14 and it was fixed. I had had it to the dealer on numerous occasions but they couldn't find anything. The silly thing was that I still got the release of pressure when taking the cap off to fill up.
Also it's probably the easiest and cheapest thing to check.
332822
Follow Up By: Member - John R (QLD) - Friday, Oct 31, 2008 at 19:11
Thanks, Grizzle. I'll see if the Hilux has a similar valve that can be replaced. Hoping not to have to replace the lot, thereby needing another key for the lock.
Cheers, John
600756
Reply By: Member - John R (QLD) - Tuesday, Nov 18, 2008 at 19:51
Followup: from above advice I tested with some soapy
water, and found vapour bubbles coming out around centre of
fuel cap (where key turns). Took cap apart, and found quite a bit of red dust, presumably from desert trips in 2007. After cleaning all parts of dust with soapy
water and reassembling cap, problem has been fixed.
Cheers, John
335949
