Coleman northstar duel fuel lanturn
Submitted: Friday, Oct 31, 2008 at 00:46
ThreadID: 63068 Views:3214 Replies:3 FollowUps:1
Hi just got a new Coleman northstar duel fuel laturn and it is very noisy when up full sounds like a little jet engine is this normal ?seems a bit loud for a top of the range product.
Reply By: Member - Porl - Friday, Oct 31, 2008 at 11:16
I use mine when near the beach so don't really notice it over the ambient noise, what fuel you running it on? I used to use petrol but fould shellite burns much better and longer, maybe it's a fuel thing.
They are not quiet unless on low but I wouldn't say "jet engine" like so would suspect somethings up.
Everything is deconstructable and replaceable on these models so if there is a problem take it back.
AnswerID: 332837
Follow Up By: geezer0 - Monday, Nov 03, 2008 at 15:05
Thanks for your help went back with the unit to ranger camping and they said there was a bit more noise than usual and changed it for a new one . The new one is much better
thanks again
FollowupID: 601243
Reply By: Member - Warfer (VIC) - Friday, Oct 31, 2008 at 15:42
Also get into the habit of lighting it on a firm surface,Because at some stage there may be a vapour build up and when you hit the piezo it will go bang and you'll drop the unit breaking it and filling up your undies as well !Not a good start to the night..
It will not explode but the bang is quite loud...
AnswerID: 332874
Reply By: Ron173 - Monday, Nov 10, 2008 at 11:44
I have used a northstar for a time now, no issues, but can tell you following:-
runs brighter on unleaded.
At full tilt it does make noise, but throttle back untill noise stops and you wont lose light, there is a point just short of noise but max brilliance, with some playing you will find it.
If its really sounding like a jet, stop using it and fit a new mantle as its prob not on right and causing it to sing high pitched like that, and you cant refit them.
carry a spare pack of 3 mantles with you.
top top light but can have an appetite for mantles, and I will admit to stuffing a few by my own fault in clumsy fitting / wind.
With its stablemate the powerhouse stove, forms a perfect pair.
Just great using my powerhouse this weekend, very windy, but cooked like gas.
Gotta look at a top battery coleman for inside tent now also.
AnswerID: 334479
