Patrol wheel fell off? Pictures.
Submitted: Friday, Oct 31, 2008 at 12:17
geocacher (djcache)
Saw this unfortunate bloke on the median strip of the Burwood Hwy in
Melbourne yesterday morning.
How many times does this have to happen to people before there's a recall on Patrols?
Image Could Not Be Found
I own a Patrol which I recently bought & is out of warranty anyway, but I'd hate to end up in this situation particularly a long way from home.
Is there anything that can be seen before it happens to indicate weakness or likelihood of failure? Is replacing rear rotors/studs at some 50/100,000 increment of kms a preventative measure?
At least for this blokes sake it happened in mobile phone range, didn't result in an accident & with help easily at hand.
If someone knows him and can post how he got on I'd like to know. I felt bad not stopping to help but there wasn't much I could do, nowhere to
park & if I'd stopped for every broken vehicle I saw between
Melbourne & Lakes yesterday I'd have stopped more than half a dozen times. Trust me, if he'd been somewhere more remote I'd definately have stopped.
Dave
Reply By: hl - Friday, Oct 31, 2008 at 12:43
The best preventive is tight wheel nuts (also the cheapest)
It seems to happen only with the alloy
wheels, so tightening them with a torque wrench to the correct specification and re-checking after a run should really fix it.
332848
Reply By: Dunco (NSW) - Friday, Oct 31, 2008 at 12:51
And you will probably find that Warranty would not cover it as it is the drivers responsibility to check wheel nuts.
332850
Reply By: Robin Miller - Friday, Oct 31, 2008 at 12:55
Would be ironic if that was the test one from FTG just down the road , and it could be!
My solution Dave is just to check the wheel nuts before each trip, and I stay away from alloy
wheels.
It does help that I change the
wheels sets often and in the process I do occasionally find a loose wheel nut.
332851
Reply By: Member - Captain (WA) - Friday, Oct 31, 2008 at 13:12
Hi Dave,
I assisted a guy who's Patrol had also lost its RHS rear wheel. It had aftermarket alloys and had been serviced some ~400kms earlier. From what I have seen/read/heard, its due to minuet amounts of dirt/sand/mud between the rim and hub. When the crap works its way out, the nuts are now slightly loose and thus eventually the wheel falls off as the nuts loosen further.
While all vehicles have this issue, the Patrol hub design does seem to be more prone to it. Nothing like a check 50-100kms after a wheel change to minimise the problem.
Captain
332852
Reply By: Kiwi Ray - Friday, Oct 31, 2008 at 13:30
This can also happen with steel rims after removal and refitting, it does pay to re-torque the wheel nuts after a few ks.
This should be done with an accurate torque wrench.
Ray
332854
Reply By: ajd - Friday, Oct 31, 2008 at 13:38
Geocacher, you state;
'How many times does this have to happen to people before there's a recall on Patrols?'
Has this happened before?
How can Nissan rectify loose wheel nuts?
332855
Follow Up By: Member - Phil G (SA) - Friday, Oct 31, 2008 at 14:28
Been a lot of reports of this in the archives over the past 2 years as
well as every other
forum. Seems to happen a lot more with GU Patrol mags than other
wheels.
Only workable solution I've seen is to regularly check your wheelnuts for tightness - especially after a service/ tyre rotation etc
600708
Reply By: Philip A - Friday, Oct 31, 2008 at 14:05
I had it happen to a friend near
Barcaldine.
Had been to a tyre place and within 200Km he lost the right rear. I do not think they ever found it!
It always seems to involve a tyre place or after a service so I wonder if the centre spigot is too tight , or whether it is easier to "jack" the wheel in place with the surface not fully engaging the hub than in other cars.
Regards Philip A
332858
Reply By: Member - extfilm (NSW) - Friday, Oct 31, 2008 at 14:13
It is not just Patrols, I had a Cortina with alloy rims where one of the
wheels came off left hand rear.
Saw a landcruiser troopie with alloy
wheels on the
great central road with a rear wheel gone. All his wheel studs were within 2 metres of one another.
Seems to happen more on Patrols for some reason though.
I believe the problem is, and it has been discussed here is, when the
wheels get put on with a rattle gun, the holes in the
wheels start getting elongated as alloy is a very soft metal.
I do not like to take any vehicles out in those areas with alloys as if you do bend a rim then it can not be repaired easily, where as a steel rim can be hit with a sledge and it is all good.
peter
332860
Follow Up By: Member - joc45 (WA) - Friday, Oct 31, 2008 at 15:05
I recall in the early 70's, we ran a few Tojo FJ55's between Kalgoorlie and
Eucla, and these had a habit of popping wheel studs. We had several occasions where a rear wheel rolled on by, preceded by a big lurch as the back of the vehicle went over the wheel .
The only technical advice we got was to check the studs every day. Really useful! Nothing was ever done by Toyota.
600711
Follow Up By: ajd - Friday, Oct 31, 2008 at 15:08
Careful, you're not allowed to denigrate Toyota's on this site otherwise the Tojo police will be on to you.
600712
Follow Up By: Member - extfilm (NSW) - Friday, Oct 31, 2008 at 15:36
AJD, I am simply stating a fact. I love both Toyotas and Ford Cortinas. Cannot stand my nissan but when I am bagging it I am just stating the facts.
600720
Follow Up By: Member - Old Girl (QLD) - Friday, Oct 31, 2008 at 15:59
Its ok. Im a cruiser driver and had a rear wheel depart while driving. It was about 7 years ago. After the fact we remembered the dogs going off the night before. I found one of the studs where the car was parked. Since then I always walk around the car and check every day while on our trips, and aerials had them stolen and swapped. You never know who wants what you got.
Sharon
600725
Follow Up By: Bonz (Vic) - Thursday, Nov 27, 2008 at 22:18
100 series Cruisers too I have heard do the same
604869
Reply By: Moose - Friday, Oct 31, 2008 at 14:15
One would imagine that as the wheel worked loose there would be some sort of vibration happening and that the driver would check it out and not keep driving.
I recall being on a tag-a-long trip when I was a novice and one of the other participants had a "strange noise". So I walked along beside the vehicle and it was a loose rear wheel. That was 20+ years ago but guess what make of vehicle it was - yep Nissan. Probably just co-incidence.
Ever since I've regularly checked my wheel nuts when travelling.
Cheers fom the Moose
332861
Follow Up By: Member - Old Girl (QLD) - Friday, Oct 31, 2008 at 16:02
Yep about a km you feel weard movement. The brakes are loud first if your in town. I remember it quite clearly. I was up the side of a truck when it happened. Doing about 40 through town.
Not nice.
600726
Reply By: 93 Navara - Friday, Oct 31, 2008 at 17:17
Happy to me in our work Patrol. Torque setting has to be right. I believe the series 4 mags now have a steel sleeve inserted in the alloys now to prevent any issues with overtightening. Ours fell off approx 12 months ago and this was an alteration that was going to be made or had been made recently to address it. We still run the 16 inch rims on our new vehicle so I can't check it for you. Might be woth a phonecall to Nissan though,
Ben
332887
Follow Up By: 93 Navara - Friday, Oct 31, 2008 at 17:18
Ooops, 'Happened to me'.
600740
Reply By: autosparky - Friday, Oct 31, 2008 at 22:40
i work with a flrrt service mob , sub contract to fit out emegancy vehichles that are changed over at around 50000k's .tyhey have 30+ nissans with the same problem.
332946
Reply By: Member - Mark G (NSW) - Saturday, Nov 01, 2008 at 10:37
gday guys
saw the exact same thing on the side of the pacific hwy @
coffs harbour Friday afternoon.
couldnt see his wheel though,probably still going scrub bound,cheers.
PS.....same model Patrol too. :-(
332988
Reply By: geocacher (djcache) - Saturday, Nov 01, 2008 at 23:09
Okay. I know it's wheel nut related, but it seems that Patrols seem to be over represented in the stats here. If something is over represented statistically there's often another reason for it.
Maybe therefore it's design related.
IF, and I do say IF it's design related then they should be looking at a cause and a recall.
It's far more prevalent than some safety issues with other vehicles that have been recalled, and more dangerous.
Dave
333078
Follow Up By: PJA44 - Wednesday, Nov 05, 2008 at 08:39
Our 05 Nissan lost the left rear wheel on the Hume Highway last Friday. Lucky there was not a serious accident. Our initial response was to blame the tyre fitter. After reading quite a lot of similar stories on this site, we agree it is just too prevalent, particularly with Nissans. We will buy a torque wrench and check the wheel nuts ourselves (VERY regularly) in future. We will also write a letter to Nissan about our experience, and would urge others who have lost a wheel to do the same.
601513
Reply By: timglobal - Wednesday, Nov 26, 2008 at 11:34
Some interesting additional insight and some bonus solutions...
Happened to a Patrol I rented from Hertz 2 years ago. It had also had a puncture and wheel replaced about 100 kms previously.
Car shed it's tyre at low speed (as they often do due to cf force) part way down a fairly windy and steep gravel road (Majors
Creek Mountain Road near
Braidwood if you know it).
Hertz sent low-loader with replacement (Ford Courier!) who arrived pretty quickly as it was Australia Day! Drove the low-loader down and swapped them over! Impressive driving.
We had a ball waiting for it to arrive at the Majors
Creek pub which had great food, great beer and great staff.
Back to the point...
I have also had it happen in a Mitsy Triton soon after having new tyres.
There is also a thread on the AusJeepForum about it happening v soon after a roadworthy test inc tyre removal.
So for those that believe there is some statistical significance against Nissan in the reports here, they are sadly mistaken. It barely scrapes as a trend for investigation at present. The more obvious correlations seem to be with alloy
wheels and recent refit.
Since I know everyone here is about finding a solution and not whinging about the problem ;) the best solutions from looking around the web are:
Use the correct nuts for your wheel type (differs I believe between alloy and steel)
Be more cautious about alloy
wheels after refit - check them 50 kms after refit.
Remind yourself / your fitter about under *and* over-torquing which is as bad.
Consider those plastic wheel arrows (or a less obvious marker if you're precious) as seen on larger trucks and buses - you can see if the blighter has moved as it shows you!
As you were,
Tim
336957
