12volt Car and camper trailer setup
Hey Guys,
I am trying to get prepared for my camping setup.
I want to setup a dual battery system in the car for the fridge (Waeco 80ltr). Also I want to have another battery in the camper trailer to run an inverter and some 12volt lights etc.
My main question is what do I need to be able to charge all batteries while driving.??
I am thinking an anderson plug on the rear of the car connected to the trailer and some sort of switch to charge the batteries in sequence. Is this possible.???
Also I want to have the option to add solar panels to recharge the system at a later date. What sort of equipment would I need.
Is there a way to charge to aux battery in the car and the trailer with a generator without having to take the batteries out.??
Bruce
Reply By: Member - 1/2A - Wednesday, Nov 12, 2008 at 12:49
Here's a good place to start
AnswerID: 334848
Reply By: Robin Miller - Wednesday, Nov 12, 2008 at 12:56
There are a number of approaches Bruce - some better and some
more costly, however you can start by simply connecting all the
batteries together and also just plugging in your charger across
them all.
There is no need to remove batteries to charge.
From there you may move to the various options of adding in dual
battery controllers and even a step up voltage charger for the trailer.
Just make sure everything is fused , and that your waeco fridges low voltage cut out is set and working.
A small solar panel (<40watt) can just be plugged straight in to charge the batteries for a few hours at a time , and as you get more powerful panels you will need a solar panel regulator.
One of the most useful accessories when doing a simple setup and then growing is to have an accurate voltmeter connected across the batteries at all times so you can keep an eye on them without have to stuff around.
AnswerID: 334849
Follow Up By: Bruce n Sal - Wednesday, Nov 12, 2008 at 13:21
Thanks,
Do you know any places I can get one of these. And find anymore info on them.
FollowupID: 602620
Follow Up By: Member - 1/2A - Wednesday, Nov 12, 2008 at 13:24
Use the link on my first post and you'll be able to get every thing you need.
FollowupID: 602621
Follow Up By: Bruce n Sal - Wednesday, Nov 12, 2008 at 13:34
Thanks I will have a look at it.
FollowupID: 602623
Follow Up By: RV Powerstream P/L - Wednesday, Nov 12, 2008 at 15:26
Hi Bruce and Sal
If I can be of any help please contact me through the trader section of this forum.
The picture below is a new Zero Volt battery Splitter that has multi channels for multI batteries with over volt protection and backfeed protection and greatly improves the charge to your batteries from the ALTERNATOR.
Email me and I will try and assist .No Obligation whatsoever.
Ian
FollowupID: 602643
Follow Up By: Best Off Road - Wednesday, Nov 12, 2008 at 15:43
Bruce,
Ian is a straight shooter.
You might also talk to him about the Sterling charging unit, to ensure you are getting maximum power output. If you get one of these and self fit, it will work out similar in cost to getting a traditional (and less efficient) system.
Ian kindly donated one of these units for Michael Mitchell who is currently doing the "Great Cancer Bush Walk". Ian sent it down to me to fit to Mike's Jackaroo and it was a doddle (and I'm not an Auto Electrician's arse).
Jim.
FollowupID: 602646
Follow Up By: Robin Miller - Wednesday, Nov 12, 2008 at 16:08
Thats certainly an interesting device.
(Electronics engineer here and Ian sent me the brochure).
While I have no technical information nor have done any engineering tests , this sort of thing is the way technology is moving, as is beginning to be seen in such things as winch controllers.
I presume its based on power mosfet switching backup up by a microprocessor monitoring current flows into/out of each terminal based on use on small shunts.
I guess proof will be in the actual implementation and cost, but concept is sound.
FollowupID: 602653
Reply By: Wheaters - Wednesday, Nov 12, 2008 at 20:29
I am doing exactly the same,
I am trying to run a thumper 75amp as a car setup and then run the thumper 120amp in a trailer.
I have been told if I run the thumper 75 in the car I can charge it as I drive and use it to run my fridge.
Then when I return I can hook it upto thee trailer and it will trickly dump into my trailer 120 amp.
The enquiries I have made are via a site called
http://www.homeof12volt.com.au/
Cheers John
AnswerID: 334897
Follow Up By: Sand Man (SA) - Wednesday, Nov 12, 2008 at 21:04
John,
I have a dual battery setup in my Jack, controlled by a Piranha DB150S Controller.
On top of this I also have a 75Ah Thumper and a 39 amp in-car charging unit.
The way it works is this:-
The DB150S prioritises the starting battery to receive whatever charge that is necessary from the alternator, then once it has reached a specific voltage, will swap over to allow anything connected to the auxiliary circuit to be charged.
This generally happens within a minute or so because the starting battery is in good condition and not normally subjected to much current draw.
Once the auxiliary circuit is connected through the controller, the auxiliary battery in the engine bay receives whatever charge that is required.
The In-car charging unit for the Thumper is also connected to the auxiliary battery, so charging current also flows through the circuit to the Thumper in the back and connected whilst travelling.
The fridge is connected to the auxiliary battery when travelling, then when setting up camp, I remove the thumper and fridge and locate in the annex of the camper trailer. I also connect an 80 watt solar panel to the thumper to help maintain a charge for an indefinite period.
The auxiliary car battery is a backup should I need it, but that is unlikely.
In your situation, you don't need the dual battery controller, simply the in-car charging unit for at least the 75 Ah unit. This would be connected to your primary battery.
For the 120 Ah battery in the trailer, I would be inclined to have a separate circuit via an Anderson connector to and Arrid Twin Charge controller in the trailer and then to the trailer battery.
This setup will limit the need for heavy duty cable, but increase the voltage at the remote (trailer) end to enable correct charging of the trailer battery through the vehicle alternator.
The Arrid Twin Charge Controller setup is very common for correct charging of remote batteries by the vehicle alternator. It boosts the voltage level if necessary to remove voltage drop, the most common cause of inadequate voltage supply to a trailer battery.
Although the Arrid Twin Charge may also be possible of charging the Thumper in the back of your vehicle, I would prefer to have two separate circuits, one for each battery system.
I am sure you will receive expert advise from the guys at Home of 12 Volt.
Just be aware there are several ways of achieving a good result.
Bill
Bill
FollowupID: 602681
Follow Up By: Sand Man (SA) - Wednesday, Nov 12, 2008 at 22:51
Correction!
In my reply above, 39 is a typo.
The in-car charging units available are a 20 amp, or the heavier duty 30 amp unit.
Bill
FollowupID: 602694
Follow Up By: Wheaters - Wednesday, Nov 12, 2008 at 22:55
what are your thoughts on projecta pure sine invertors??
FollowupID: 602696
Follow Up By: Sand Man (SA) - Wednesday, Nov 12, 2008 at 23:02
Don't have any particular experience with the Projecta Inverter.
I have a 300 watt modified sign wave inverter infrequently used to run a small AA battery charger, or a charger for the video camera.
That is my sole need for an inverter.
I have structured my camping needs for 12 volt lighting only, plus running the fridge.
Bill
Bill
FollowupID: 602697
Reply By: Affordable Batteries & Radiators - Wednesday, Nov 12, 2008 at 21:23
Hi Bruce
Which ever system you use I recommend using the 50A Anderson plugs as a common connector to enable you to charge all batteries and also connect solar, mains chargers and the car to all sources and batteries.
Derek.
AnswerID: 334908
