haymen reece systems for pathfinders 2007
Submitted: Saturday, Nov 15, 2008 at 18:07
ThreadID: 63548 Views:2481 Replies:3 FollowUps:4
we have a pathfinder 2007 model and are having difficulty with the hayman reece not being low enough to match the tow cup on the caravan.Whe we use the standard one the van is 19 inches at the front and 17 inches at the back thus not level. Would this cause a big problem or is there something else we need to do / buy? thanks
Reply By: Member - George (WA) - Saturday, Nov 15, 2008 at 18:10
Buy an adjustable hayman Reece tongue
AnswerID: 335393
Follow Up By: j and k- Saturday, Nov 15, 2008 at 18:14
what do you actually mean by this. As you can probably tell we are first timers and learning every day. Thanks
FollowupID: 603102
Follow Up By: Member - George (WA) - Saturday, Nov 15, 2008 at 18:22
If you have a Hayman Reece towbar or similar, you can get a tongue that has an adjustable plate bolted to it which you can adjust to suit the height of your trailer
FollowupID: 603104
Follow Up By: Member - George (WA) - Saturday, Nov 15, 2008 at 18:25
If you have a fixed towbar where the plate, which holds the tow ball, is welded to the towbar then there is not much you can do to adjust the heights
FollowupID: 603106
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Nov 15, 2008 at 18:34
One of these,
Find it here,
Hayman Reese
Under "Products -> Weight Distribution"
Goff
Geoff,
FollowupID: 603110
Reply By: Member - Vic S (VIC) - Saturday, Nov 15, 2008 at 21:10
I am in Melbourne and I am thinking of selling my adjustable Hayman Reece hitch as we have moved from caravan to camper trailer with an off road hitch.Contact via email if interested.
To answer the other question ,to tow well it is much better to have your load level.
Vic
AnswerID: 335422
Reply By: eerfree - Sunday, Nov 16, 2008 at 00:02
J and K
Please check with Hayman Reece or your Nissan dealer as there can be a bit of a problem using a hitch with a Nissan Towbar.
AnswerID: 335453
