Please comment on Primus Automobile 12V Camp Shower Set
Submitted: Monday, Nov 17, 2008 at 20:23
yevi
I want to buy a
camp shower, with a pump powered by 12V.
I don't need heating.
Is it a good product? what can you say about it? (link to a good review will be appreciated as
well)
Any other similar products I should consider? (it should be in the same price range more or less)
Thanks.
Reply By: Michael ( Moss Vale NSW) - Monday, Nov 17, 2008 at 20:48
Yevi!! If its the $25 unit you are talking about, they are ok, it can last two uses or 50 depending on your luck.. I have had 2 in about 3 years, finally
water gets into the submersible motor or the inpeller falls off.., I have had both type of failures. Buy two in case the first lets you down.. You can also buy the same unit powered by batteries, about $40.. Primus is blue but the same unit is normally Yellow and is available from Jaycar for $20 Hope this helps , Michael
335757
Follow Up By: yevi - Monday, Nov 17, 2008 at 21:35
Thanks for this answer,
this is the product:
www.wildearth.com.au/primus-automobile-
camp-shower-p-257.html
what do you mean by impeller falls off???
and "Primus is blue but the same unit is normally Yellow"
Any other, similar
camp shower you can suggest? (no heating)
603451
Reply By: Member - Rob S (NSW) - Monday, Nov 17, 2008 at 21:35
Hi i bought one at Big W a few back and have found it to be very good.
There dose appear to be few others around they all look the same but different colour,boating shops sell them as
I just heat up a billy full of
water and add it to a bucket of cold and can get at least two good hot showers out of one 9L bucket.
The shower head has an on /off valve helps save
water, wet your self down lather up and rinse.uses a lot less than just tipping a bucket over your self. As for how long it will last?cheap as just get another.
Rob.
335775
Reply By: yevi - Monday, Nov 17, 2008 at 21:37
p.s.
I am not from Australia, and i am going to order from ebay.
335777
Reply By: Steve - Monday, Nov 17, 2008 at 21:38
you can get em at K-mart, big W etc. We've probably had at least 40 showers out of ours - didn't know it was about to pack in though. For what they cost, it might be a decent idea to get a spare.
The black solar showers/bladders are good too. They have their limitations, especially in the cooler weather when you have to have a shower in the middle of the day because it's too cold otherwise.
335778
Follow Up By: yevi - Monday, Nov 17, 2008 at 21:59
I already have this "Black bag shower", it's not convenient to use.
603464
Reply By: Kroozer - Monday, Nov 17, 2008 at 21:54
What i was thinking of doing was just buying a Hella marine or Rule bilge pump and some tubing and wiring up my own. Has anyone tried this? Will the bilge be able to pump sufficiently to have a shower or will it pump too quick? This way at least i know that the pump will last for years.
335781
Follow Up By: Peter 2 - Monday, Nov 17, 2008 at 22:35
I've thought of that too but i suspect that the bilge pump might not like the restriction of a shower head.
They are meant to shift volume not pressure.
I've got one in the pit in the garage and it will pump 500mm depth of
water out of the pit very quickly but doesn't like it if the hose gets kinked. It is using 19mm ID hose, bit big for a shower ;-))
They are not very dear to try out though, can handle grit, oil and
water and if you get one with an inbuilt float switch you just lift it out of the
water to stop it.
I use the Jaycar $20 one when we need it.l
603473
Follow Up By: Member - Phil B (WA) - Tuesday, Nov 18, 2008 at 04:57
I have been using a bilge pump system (homemade) for about 8 years & haven't had any problems with pump.
I have an in line switch so it can be switched on/off from inside the shower. I switch on wet myself all over. switch off, soap up, rinse off, switch off, wash hair etc switching on and off.
Mrs and I can shower in 10 litres of
water using this system, very important when you're out in the deserts and can't carry heaps of
water.
603493
Reply By: austastar - Tuesday, Nov 18, 2008 at 09:13
We considered the retail shower options, but decided against it for various reasons.
Our setup is simple and there is nothing to break.
335844
Reply By: Kirks - Tuesday, Nov 18, 2008 at 14:27
Hi Yevi
Go out and buy yourself a 25 dollar bilge pump and rig it up yourself with a 12 volt battery,and it wil be the ant's pant's,hope this helps.
Kirk's
335892
Follow Up By: yevi - Thursday, Nov 20, 2008 at 07:34
Can you suggest specific pump model?
603852
Reply By: Bagwon - Tuesday, Nov 18, 2008 at 17:25
Yevi,I used one a mate owned,can't remember what make but it was very handy and simple to use,sounds similar to your primas
335931
Reply By: Kirks - Saturday, Nov 22, 2008 at 13:37
Hi Yevi
Kirks here, the brand of the bilge pump is a "rule" model 24 360gph/1360lph, made in USA, 12 volt,3/4(19mm)discharge,2.5amp fuse, i purchased
mine from a firm called (Whitworths)in
Melbourne,www.whitworths.com.au hope this helps you.
336439
