Brake Pads
Submitted: Tuesday, Nov 18, 2008 at 15:11
arrano
HI Forumites,
This has probably been covered, and will probably get told to use the search function, but here it goes!
I am about to change the Brake Pads on the 4 Corners of the 'Trol (2003 GU3, 3.0 tdi).
I am after some opinions on what are good brake pads / bad brake pads that people have used / experienced.
I am leaning toward Bendix or Ferodo 4wd pads, but open to the
forum thoughts?
Thanks,
Arran
Reply By: Member - Troll 81 (QLD) - Tuesday, Nov 18, 2008 at 15:17
I am voting for Bendix 4x4 pads been happy with them
335899
Follow Up By: Pat (vic) - Tuesday, Nov 18, 2008 at 15:30
I'll second that 60,000k on the front of a crooza with only about 30-40% worn and they stop
well enough to.
cheers Pat
603571
Reply By: Member - Vic S (VIC) - Tuesday, Nov 18, 2008 at 15:32
Arran
I would also recommend Bendix I use them myself and in clients cars ,they may be a bit dearer but are more cost effective in the long run
Vic
335901
Reply By: bushy04 - Tuesday, Nov 18, 2008 at 15:33
Have been retired from the brake game for ten years, or so but always found Bendix to be very good pads, Ferodo are good but tended to be a bit noisy.
Hope that helps.
Bushy.
335902
Reply By: garryk - Tuesday, Nov 18, 2008 at 16:04
G'day Arran
As a recently retired mechanic ,I suggest the ones I use in our own vechiles and thats a not so
well known brand
called QFM ( Queensland Friction Materials )
A good product and
well priced
I know of several cases where the big brands were not satisfactory and changing to these gave excellent results
Do a google search for " QFM brake pads " Australia only
and read some more opinions if you wish
I have no connection with them apart from using them for years
Garry
335911
Reply By: Truckster (Vic) - Tuesday, Nov 18, 2008 at 16:10
I'll recommend OEM Nissan pads again.. I did and couldnt be happier.
Have tried Bendix or Ferodo, I was far from impressed, that was on GQ and GU.
The EBC were good after 20 mins, cause they need heaps of temp in them to work
well but useless in a daily driver where brakes arent used all day every day.
Go with the Nissan pads.
YMMV.
335912
Reply By: Member - Kiwi Kia - Tuesday, Nov 18, 2008 at 17:06
Do you want to stop in the shortest distance or do you want long life pads ? The quicker the stop the more wear on the pads and the discs. I would go with original maufacturers equipment which should be best of both worlds.
335926
Reply By: Splits - Tuesday, Nov 18, 2008 at 17:29
I agree with Truckster and Kiwi. What is wrong with the genuine item? They have been designed for your particular car and nothing else.
I have worked for a Holden, Ford and three Toyota dealers as
well as a few other workshops. The workshops rarely used genuine. Non genuine were usually cheaper and they either made more money on them or were trying to save their customers a few dollars. The dealers always used genuine.
I have seen plenty of non genuine come back with complaints about squealing, shuddering, rapid wear etc.etc. I can't remember ever hearing a complaint about genuine.
Brian
335932
Follow Up By: Member - Paul W (VIC) - Tuesday, Nov 18, 2008 at 19:48
Me 3,
i put OEM pads in the cruiser but surprise surprise they were cheaper than any other pad on the market. shocked the hell out of me actually. but my discs still look like new after 66k so i will be sticking to them i say. cheers Paul
603610
Reply By: Pete G - Tuesday, Nov 18, 2008 at 19:44
Go the genuine. They are exy but I still have the original pads at 385K's and they are still about 30%.
Pete G
335947
Reply By: Robnicko - Tuesday, Nov 18, 2008 at 20:15
Arran,
I use Bosch in my 80 series. Been in for coming up 5 years now and still look like new.
Rob
335956
