Wednesday, Nov 19, 2008 at 11:46
Depends.
Those diesels have in line
fuel filters - so it is unlikely that at 71,000 or 80,000 km's that a nozzel needs a clean, and it certainly shouldn't be worn out.
More likely is that somethings broken or leaking with regard to that injector.
IF it is one of the newer HEUI (Hydraulic Electronic Unit Injector) then yes they cost upwards of $900 each in just about any brand (via stealership spare parts avenues of supply).
The vehicles warranted 3 years or 100,000 km's whichever comes first....
If the 3 years is up it is up - if you never took in a warrantable condition for repair for 9000km's - and left it until xyz days after warranty expires - then your liable basically UNLESS the dealership & Tojo decide from the goodness of their heart to help you out!
Sounds like they don't want to eat$900 for a new injector to me - and who would when they are as expensive as they are!
Try replacing all 8 of them at $900 each on some of the new HEUI V8 diesels!
Generally speaking the injectors are pretty hardy and reliable - it's MORE likely to be an electrical short in the electronic circuit that fires them, because the injectors inside the rocker cover where the hot lubricating oil runs - ad hot oil and electrical wires don;t go together so
well - specially if the wire rubs its insulation off on any of the Ohead cam gear and shorts etc...
These high tech diesels are damn economic and good performers until something goes awry with the electricals that control them these days.
It seems the designers have forgotten that one of the primary reasons many chose diesels in the first place was because of the unreliability of electrical ignition problems on petrol engines in hard service applications like agriculture outback transport and marine applications - the diesels proving far more reliable.
Now however woth electronically controlled diesel injection - we are right back to where we left off with petrol engine reliability - i.e. basically screwed.
Its a shame because the additional cost of diesel was considered a worthwhile trade off for the additional reliability.
Now it seems we have diesels with all of the extra expense but NON of the extra reliability due tio the introduction of electrionic cam position sensors and engine management computers that fire the damn injectors!
Mechanical
fuel injecton was at least RELIABLE - the new modern replacement with these common rail, chipped and computer run diesels, just isn't there anymore.
In truth these new diesels aren't fit to travel anywhere outsideof the city where the technicians have the computers diagnostics and electronics experts to fix them.
Welcome to the brave new world of technology!
With reliability issues and costs, etc of the new technology, who can blame Toyota, for running scared from possible warrantable work if they can find an "out clause' in the fine print!
With the state of auto manufacturers finances - I reckon we will probably see a LOT more claims for warranty denied from here on in by many dealers/manufacturers in an effort to stay afloat fiscally thru these hard times.!
Cheers!
336022
