Radiator over flow
Submitted: Wednesday, Nov 19, 2008 at 17:12
ThreadID: 63661 Views:5163 Replies:11 FollowUps:9
Has any one had any experience with a radiator not sucking back from the over flow tank, i have an idiot alarm installed in the radiator so i know when the radiator is low, i have and a pressure test on the cooling system done which is ok and i also had the exhaust gas test done on the system which is also ok.
The radiator has a a diffuser?? in the top of it, the radiator bloke said i should remove this at a cost of about $250 would this fix the problem or just lighten my wallet a little?
What else can i do to fix this problem?? it just gets a little annoying when off road and the car is not level.
Regards.........Steve
Reply By: Member - Rob S (NSW) - Wednesday, Nov 19, 2008 at 17:40
Hi Steve
What type of vehicle is it, as some are more prone to head gasket problems than others.
Had this problem with my old 2.6L Pajero, had all the usual tests
you have had done. Replaced all the hoses etc.But they didn't show any thing.
Ended up being the head gasket.It was only a very small leak,
just enough to cause the problem you describe.
Rob.
I only ever made one mistake
AnswerID: 336079
Follow Up By: stephen looking - Wednesday, Nov 19, 2008 at 17:57
Troopy with a 12ht engine conversion 1988 build, has a new gasket new water pump and it also doesn't get over a 1/4 in temp, apart from replacing the gasket how did you find the problem in your car?
Steve.
FollowupID: 603766
Follow Up By: Member - Rob S (NSW) - Wednesday, Nov 19, 2008 at 18:31
The head gasket was always the top candidate but the engine never boiled or ran hot. just ran as normal but for the water recovery would not draw back.Ended up biting the bullet and remove the head to find a very suss gasket.
Even if you have replaced the head gasket and reco the head doesn't always mean it has been fixed. had a mate who's diesel Navara blew the head gasket
Had the engine reconditioned and ended up with similar problem to yours after a few months head gasket again.they probably never pressure tested the head.
Just also double check all the radiator hoses/heater hoses and small by pass hoses are tight.
FollowupID: 603773
Reply By: mechpete - Wednesday, Nov 19, 2008 at 17:40
make sure you have a recovery cap on the radiator
not just a standard cap
mechpete
AnswerID: 336080
Follow Up By: stephen looking - Wednesday, Nov 19, 2008 at 17:59
mechpete got a recovery cap and the rubber is behind the metal its a genuine radiator cap, i should of mentioned this in my post thank for the reminder.
Steve.
FollowupID: 603767
Reply By: Member - Vic S (VIC) - Wednesday, Nov 19, 2008 at 18:21
Steve
also check the overflow hose itself ,once had one that had a split on the inside layer the acted like a one way valve
Vic
AnswerID: 336092
Follow Up By: stephen looking - Wednesday, Nov 19, 2008 at 18:36
Thanks vic didn't think about that have some new hose will replace it now.
Steve
FollowupID: 603777
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 19, 2008 at 19:22
To test this.........
Make sure the radiator cap is on and done up properly......
Take the lid off the overflow bottle. There should be a rubber hose that normally sits down in the overflow water....... Put the end of that rubber hose in your mouth and try to blow. If you cannot blow any air down through it, then it should be all good. If you CAN blow air down it, then it can't be properly sealed and you need to sus-out where the air is escaping. That is where your problem will be. Seal that up properly and the radiator will recover the water once it starts to cool down after a hot run.
FollowupID: 603788
Follow Up By: Member - Axle - Wednesday, Nov 19, 2008 at 19:59
Good trouble shooting advice Roachie!, Would you do that before or after lunch?.....))))))
Cheers Axle.
FollowupID: 603794
Follow Up By: Member - Roachie (SA) - Thursday, Nov 20, 2008 at 09:59
Yeh I know..... it's a toss up whether coolant tastes worse than diesel or petrol.....but if you have a stubby of beer close by, it tends to make it all worthwhile...hahahaha
FollowupID: 603868
Reply By: rescue134 - Wednesday, Nov 19, 2008 at 18:23
hi Steve
i think you will find that a new radiator cap will fix the problem, also it would not cost a lot to have the system pressure tested
kevin
AnswerID: 336093
Reply By: disco driver - Wednesday, Nov 19, 2008 at 18:54
Steve, For the water to be sucked back into the radiator all the connections from the overflow tank to the radiator must be airtight.
Check all the hose clamps are tight, don't just look, try using a screwdriver or spanner as necessary even a quarter turn on a clamp can make a big diifference.
Check that the overflow hose has not cracked or perished, if in doubt replace it.
Make sure that the cap on the overflow tank is airtight too, as only any little air leak may destroy the whole setup.
Disco.
AnswerID: 336094
Reply By: Member - Davoe (Yalgoo) - Wednesday, Nov 19, 2008 at 19:39
a pressure test is unlikely to find anything - ive had cracked heads -leaking water pumps etc over the years and no amount of pressure testing could detect them.
Is it actually using water from the radiator? A healthy system puts FA into the overflow. listen to bubbling from the overflow pipe into to overflow when warm. If it is using water it would almost certainly be a cracked head as it was fairly common on the 2h/12ht motors.
also check for any external coolant leaks
AnswerID: 336101
Follow Up By: stephen looking - Wednesday, Nov 19, 2008 at 21:32
Davoe i thought a test of the radiator coolant for exhaust gas would rule out a cracked head??
How would you do a test for a cracked head?
FollowupID: 603824
Follow Up By: Member - Davoe (Yalgoo) - Wednesday, Nov 19, 2008 at 22:34
ah didnt see that I have never had one done only pressure tests
FollowupID: 603831
Reply By: trainslux - Wednesday, Nov 19, 2008 at 22:49
Ive come across this problem several times before.
But for clarification.
it fills the overflow bottle, then next time you run it, it fills it again, and finally the overflow bottle overflows itself??
and the rad level drops accordingly???
first thing to check is the rad cap, that it actually allows for vac to suck back into the rad, and that it seals under vac so that it dosent suck air from the top seal, and thus the bottom seal / valve dosent bring in from the overflow.
Then check the plumbing from the overflow tank to the rad cap area.
These areas can cope under positive pressure, but pull a vac on them, and they can leak and not draw from the overflow.
One good one I had was a pulsar with the metal pipe behind the block under the inlet manifold that had an o ring to seal said pipe into the back of the water pump.
Fine under pressure, no leaks, but under vac, the o ring was perished, and the cracks would allow air into the system.
It would heat up, push water into the overflow, but not bring it back.
Next heat cycle, it would push water into overflow, but not bring it back.
Finally it would empty itself to the point of overheating.
So check your cap, and hose tightness in general, vac leaks can be strange ones to find.
Trains
AnswerID: 336143
Reply By:- Thursday, Nov 20, 2008 at 09:40
Have a similar issue start recently with a GQ patrol, check the coolant when engine cold and it would be an inch below where the cap seals. Overflow never seemed to change in level. Replaced the radiator cap and checked overflow hose for air leaks etc. Could find no sign of coolant leaks including inside the cabin from the heater core. Could go away on a trip and have no problems but when engine cold, coolant would be an inch below where it should be. Could add some coolant and leave the cap off and it would slowly fall back to an inch below. As the height of the coolant would always stay higher than the head I figured it wasn't a cracked head or blown gasket problem. Ended up by passing the heater core as I wondered if it was blocked and maybe creating a air block. On by passing the heater the coolant level in the radiator stayed full. Flushed the heater core and re-connected, whilst it still isn't staying 100% full (about 6mm below) it hasn't to fallen to an inch below full so far. So figure the heater core is the problem!
AnswerID: 336177
Reply By: Member - Old Girl (QLD) - Thursday, Nov 20, 2008 at 14:37
Did half of this years rally with the cap turned back a notch to get the car home it was spitting coolant everywhere out of the over flow.. It turned out to be a shagged radiator. We thought the worst though as at the same time the turbo hoses blew off. We had a couple of seperate issues that put together looks worse than it realy is.
AnswerID: 336210
Reply By: Smudger - Thursday, Nov 20, 2008 at 18:16
A few others have said it ..try a new radiator cap.
Had a similar issuue with my Disco ..coolant in the overflow, but tank level would slowly drop. Turned the seal over in the cap and Bingo!
I met a guy in Victoria who leaves his modified Rangie out here and flies down every year from England for his holidays (and we thought Poms didn't hae any tatse) Anyway, he had a similar problem.
A real DIYer, he replacd all hoses ..nope!Took out the radiator, sweated off the top tank off, cleaned it out and re-sealed it. Problem continued. Replaced water pump ..Nup! Finally figured it must be a head gasket issue ..pulled into a freebie and did a head job on his perfectly OK V8. Bugga! In depseration he dropped into a radiator shop, bloke listened to his saga, handed handed him a new radiator cap and said .."On the house mate!"
Problem solved.
AnswerID: 336254
Reply By: Wherehegon - Friday, Nov 21, 2008 at 11:43
Hi Stephen also make sure the tube that is connected to the lid of the overflow bottle make sure the tube is connected up to the right one.. My wifes old car would blow water into overflow bottle but wouldnt suck it back into the radiator. Took me a while to work out what the hell was going on but turned out for some unknown reason why the hell the mechanic even touched it I have no idea but anyway the rubber hose coming from the radiator across the cap on the over flow bottle wasnt connected to the long tube which sits towards the bottom of the overflow bottle therefore could blow in but not suck back out. It was connected to the pressure side outlet of the bottle incase your overflow bottle need to get rid of some pressure due to overfilling etc. Proabaly not your problem but some thing esle for you to check. WHG
AnswerID: 336329
