Solar Battery Charger Question
Howdy folks, just a quick question for the solar guru's out there. I am after some info on what size panel i would need to charge a 18 a/h Sealed Lead Acid battery. Battery is used for running some fluoros and pumping some water every now and then. I dare say it would never reach half capacity each night and there is always plenty of sunlight to charge it, so i thought solar would be the way to go. Would something around 400-700m/ah do the trick? Or would i want something around 1 amp? Battery is in a box so could just mount the panel to top of box and let it do its thing, Rather then trying to charge the battery while on the move with a 12v charger.
Reply By: Member - Mick O (VIC) - Saturday, Nov 22, 2008 at 14:52
Kroozer,
do you have a dual battery system in the vehicle? Would it be possible to thread a lead back to the cab from your auxiliary battery and just plug the 18 AH onto it with an Anderson plug. It would probably only need a few hours to get it back up to speed. That's what I've done with mine. 18 A/H is in a canvas bag and sits beside the second 90 A/H battery in the rear of the cabin.
Image Could Not Be FoundImage Could Not Be Found
Just another thought and possibly cheaper than a solar cell.
Cheers Mick
AnswerID: 336454
Follow Up By: Kroozer - Saturday, Nov 22, 2008 at 17:57
Yeah i do have dual battery system, only thing is i dont always go with my vehicle. Though it probably is a good idea to do it anyway, how is the wiring set up for this? Is it just a cable run from positive and negative to an anderson plug?
FollowupID: 604137
Follow Up By: Member - Mike DID - Sunday, Nov 23, 2008 at 12:09
Where is the fuse in this arrangement.
Having this size battery without a fuse is a serious fire hazard.
FollowupID: 604230
Reply By: Affordable Batteries & Radiators - Saturday, Nov 22, 2008 at 15:45
Hi Kroozer
What is the battery voltage the next morning when you are ready to charge it ?
I ask this so I can work out what the SOC is and what size panel and regulator will be needed to replace what you have used in 8 hours of sunlight. (If available)
Derek.
AnswerID: 336458
Follow Up By: Kroozer - Saturday, Nov 22, 2008 at 17:53
Good question, its been a while since i last used it, but i think it was on around 12.3 before i charged it last. Thats just a feeling though and not really certain. I know it never drops below 12v though thats for sure.
FollowupID: 604136
Follow Up By: Affordable Batteries & Radiators - Saturday, Nov 22, 2008 at 18:13
So that would be about 50% to 60% discharged.
To replace 50% or 9 a/h you would need close to double that to be able to do it in daylight hours.
I am guessing at a 30W panel and a 5A regulator.
Derek.
FollowupID: 604139
Follow Up By: Affordable Batteries & Radiators - Saturday, Nov 22, 2008 at 18:23
Perhaps a better option would be the car to car charger.
This would charge the battery off the cars battery in about 1hr 30 min.
They are 85% efficient so you would loose about 11 a/h from the car battery but this can be replaced quickly at fast idle.
These units use cigar plugs and are very quick.
Derek.
FollowupID: 604143
Follow Up By: Kroozer - Saturday, Nov 22, 2008 at 18:45
Damn didnt think i would need such a big panel. Was obviously given false info from a salesman. Anyway, what is this car to car charger? Is this a portable option or fixed to the one vehicle? So many options i dont know which way to go.
FollowupID: 604148
Follow Up By: Affordable Batteries & Radiators - Saturday, Nov 22, 2008 at 19:16
The Car to Car Smart charger is a 7.5A voltage booster. It will take 10V to 15V input and charge at 13.8V to 15V. It switches off at the set time or 15V which ever occurs first.
Derek.
FollowupID: 604156
Follow Up By: Boobook2 - Saturday, Nov 22, 2008 at 20:22
Derek that looks pretty cool. How much is it and when will it be available, Web site says Dec, is that still right?
FollowupID: 604162
Follow Up By: Affordable Batteries & Radiators - Sunday, Nov 23, 2008 at 01:33
Yes, due for release 1st week of December.
Derek.
FollowupID: 604188
Follow Up By: zha zha cruiser - Sunday, Nov 23, 2008 at 10:01
I really want one of those car to car chargers...how much?
FollowupID: 604204
Reply By: Maîneÿ (wa) - Saturday, Nov 22, 2008 at 20:32
Kroozer,
Said with no technical gibbly gook, without knowing what your using (Amps) we are only guessing as to what (Amps) you have to replace !!
Mainey . . .
AnswerID: 336487
Follow Up By: Kroozer - Saturday, Nov 22, 2008 at 22:28
Very true, but i wouldnt know either. I run one fluoro camping light, i have no idea how much it draws as i brought it 2nd hand and it has no make or anything on it. Its a well built one which probably lights up the same as most. Maybe 1-2 amps. And it also runs a Primus 12v shower which i think to memory might draw close to 2 amps max and only used for about 8 minutes a day max.The light is also only used for 3 hours. Im pretty sure after about 6-7 hours running the light and running the shower for around 15 minutes and sitting for a week it was reading 12.3 amps.
Thanks everyone for your questions and answers too, as it helps me understand whats going on alot better then just getting an answer to what to buy.
FollowupID: 604177
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 01:31
The shower is probably used during the day, so the minuscule amount of power it uses is actually replaced as it's used in the same day as it's being used, so you only have to worry about recharging the light.
Fluoro light could use up to 5 Amps (~3 Amps probably) at night (3 hours) without any method of recharging, so it's recharged next day and you will require maximum of 5 amps (~3 Amps probably) replaced in ~6 hours
Mainey . . .
FollowupID: 604187
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 06:41
Mainey, I think you are confusing Amps with amp hours. ( Charge)
You need to know how many amps you use over a period. Knowing the number of amps alone will tell you nothing in relation to restoring a battery's charge.
Most flouros use about 1.2A. If you have it on for say 6 hours then it is 7.2AH. Plus if the punp is 6A and you use it for 30 mins then you use 3AH
Add up the charge used by all the devices and you come to a total. Say 10AH. Then you know that you should double it to get a 20AH battery.
Then you know you have say 4 shours to charge the 10AH so you need to charge it at 2.5A, allowing 20% loss - 3A.
That tell you that you need a panel of 3A x 17v or 50W.
FollowupID: 604193
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 09:56
Bb,
I believe there's no confusion, I've stated the *total* number of Amps used over the period of a 'day' or 'night', not the Amps used per hour, "Fluoro light could use up to 5 Amps".... this is the total number of Amps used at night.
Yes, this equates to ~1.7ah maybe down to ~1ah, but for the answer as to how much power is actually used you need to know the *total Amps* used, then you know the total Amps your Solar panel must be capable of replacing in full during the PSP.
Bb, your own reply statement above states:
"Most flouros use about 1.2A. If you have it on for say 6 hours then it is 7.2AH"
This of course is technically incorrect, however I'm sure it's just a typo :-)
Personally I believe a 50W panel would be way way over the top, in both physical size, $$ and capacity, I believe it could be possible to use a panel of ~20 Watts because as I say, the shower Amps consumption are replaced (almost) as they're used.
Because the shower is used during the day, the Solar panel would have been supplying max Amps previously, therefore the battery will be fully charged.
A Solar panel of ~20 Watts will deliver max of ~1.2 Amps, so when using the shower pump, which your rating @ 6 Amps, for 10 mins each time, this equates to just ~1ah which is capable of being delivered direct from the Solar panel, without taking power from the battery.
Pictures clearly showing this exact scenario are shown in "my profile" below.
Mainey . . .
FollowupID: 604201
Follow Up By: zha zha cruiser - Sunday, Nov 23, 2008 at 09:59
Hi there amps/battery/solar experts...I need a little help and your knowledge will be most appreciated.
I have a camper trailer 12volt wired to a deep cell battery 65.
I have a couple of lights in the camper trailer, those ARB lights that draw very little power, so the battery has never run out. It then charges through the anderson plug when we're travelling.
Im impressed with that charging gadget that the battery man has coming out in december...I think I will need one, and my question is?
My engel 40 litre fridge usually stays plugged into the car and on occaission I cant use the generator cos Im in a national park. It would be real handy if I could plug it into the deep cell 65 battery in the camper trailer.
If I was to stay a couple of nights (and it would only stay plugged during the night time) how long before I drain the deep cell battery? And as for that little gadget pictured above, will it charge the battery OK?
FollowupID: 604203
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 10:20
Mainey, I think you are still confused.
eg when you say in your last comments
This does not make sense. There is no such thing as the total number of amps used over night. Current ( measured in amps) is an instantaneous thing. So a flouro that uses up to 5 A means it could use up to 40Amp Hours over night ( assuming 8 hours).
Are you referring to AMP HOURS which is charge and a function of the amount of current ( A) over time.
Also you say
No typo, perhaps is is your confusion between current (Amps) and Charge ( Amp Hours). 6 x 1.2 = 7.2 by my calculator. I am referring to a typical 11w flouro.
Your comments are very confusing mixing up current and charge. Your advice is not technically right.
FollowupID: 604206
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 10:26
You posted:
"Most flouros use about 1.2 Amps
If you have it on for say 6 hours then it is 7.2 Amp Hours"
please explain how a 1.2 (Amp) light uses 7.2 (Amp Hours) ?
Mainey . . .
FollowupID: 604208
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 10:37
Wow....
If a light uses 1.2A and is on for 6 hours, that's 6 times 1.2 = 7.2 AH
Let me ask you a question.
If you have a 55w light that draws say 4A that is on for 4 hours, how many amps is that?
FollowupID: 604209
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 10:38
BTW I forgot to ask, what is your answer to your question?
FollowupID: 604210
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 10:43
Bb,
Your post:
"If a light uses 1.2A and is on for 6 hours, that's 6 times 1.2 = 7.2 AH"
Is incorrect...
It's NOT the numbers I'm referring to, the TERMINOLOGY is wrong !
Mainey . . .
FollowupID: 604211
Follow Up By: Member - Mike DID - Sunday, Nov 23, 2008 at 11:06
Boobook2
Yes, I've given up too !
Just because instantaneous fuel consumption litres per hour, certain people here insist on writing instantaneous current draw as amps per hour, ignoring what the rest of the electrical industry around the world uses.
FollowupID: 604213
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 11:27
Mike,
in the statement:
""Most flouros use about 1.2A. If you have it on for say 6 hours then it is 7.2AH""
Question: is the above Terminology technically correct?
a simple 'yes / no' answer would be nice.
Yes, the light may use 1.2 Amps
if it's left on for 6 hours it is: 1.2 Amps x 6 (hours) = 7.2 Amps
It won't change from 1.2 Amps to 7.2 Amp HOURS in the equation as posted
Mainey . . .
FollowupID: 604219
Follow Up By: Best Off Road - Sunday, Nov 23, 2008 at 11:27
I've read this three times to see if I am missing something.
My conclusion is clear, Boo's logical explanation is correct.
Jim.
FollowupID: 604220
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 11:35
Jim,
you believe if a 1.2 Amp light is left on for 6 hours it is WILL consume 7.2 Amp HOURS as posted by Bb ??
Mainey ...
FollowupID: 604224
Follow Up By: zha zha cruiser - Sunday, Nov 23, 2008 at 11:58
just to diffuse the argument, can someone have a go at answering my question on engel fridge drawing on a 65 battery
FollowupID: 604227
Follow Up By: Member - Mike DID - Sunday, Nov 23, 2008 at 12:08
in the statement:
Yes, this is correct
If I have a generator that uses 1.2 litres per hour and I have it running for 6 hours it uses 7.2 litres.
Dimensional analysis shows -
Amps TIMES hours gives amphours (NOT amps per hour - a silly measure)
Litres per hour TIMES hours gives Litres.
FollowupID: 604229
Follow Up By: Best Off Road - Sunday, Nov 23, 2008 at 12:12
No definitive answer Zha, as it depends on ambient temp, how often it is opened etc.
BUT, here is a rough guide. An Engel 40 will average about 35 to 40 AH in a 24 hour period. You have a 65 AH battery. In the interest of battery life, they should not be drained below 50% capacity, hence you have about 32.5 AH at your disposal.
Therefore I would suggest any more than 24 hours is looking for trouble. If you're driving every day you'll be OK, but if not you need to find some way of recharging the battery, solar or a generator, both have their good and bad points.
Jim.
FollowupID: 604231
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 12:13
Mainey,
"Yes, the light may use 1.2 Amps
It won't change from 1.2 Amps to 7.2 Amp HOURS in the equation as posted "
This statement shows a very poor understanding of the difference in current and charge.
Try this calculation.
A compressor draws 60A for 1 minute how many amps is that? I'll give you a clue, it is 1 Amp Hour.
Honestly given your lack of understanding in the basics of this, I STRONGLY advise that you don't give further advice to people asking battery / solar questions untill you read up and understand a little more. If you insist you are right then I advise people to IGNORE your abttery and Solar Posts as you are misleading them and may cost people dearly.
FollowupID: 604232
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 12:16
Jim beat me to your Answer.
Zha, I would agree with him. I may conclude a bit less than 24 hours, say 20 hours before needing the charge as suggested.
FollowupID: 604233
Follow Up By: Boobook2 - Sunday, Nov 23, 2008 at 12:47
Ok Mainey here is a hand to help you understand.
The total Charge used is equal to the integral from 0 to t, were t is the total time, of the current over that time.
If the current is constant ( as it is in a light etc, but not a fridge), then this can be simplified to C ( in AH) = Current in A x time in hours that you are measuring.
Charge can also be measured in Coloumbs which is the number of amps x seconds. This measurement is more useful for electronics and scientific purposes but less so for day to day stuff for batteries etc.
As Mike R said current ( measured in Amps) is an INSTATANEOUS measurement and has no relationship with time. to think that a current goes up over time ( and especially Hours!!!!) is missing the basics of electrical theory.
Please read up on this subject. It is important for understanding the whole solar basics.
It does also explain your answers to other threads which miss the point.
FollowupID: 604236
Follow Up By: zha zha cruiser - Sunday, Nov 23, 2008 at 13:46
Thanks Jim,
sounds like I can plug the fridge in for a couple of days...i.e. not for 48 hours straight but certainly for maybe 2 x 10 hours over the 48 hour period should be fine. (while cooking breakfast and dinner then turn if off completely while sleeping if the weather isnt too warm)
As menitoned the fridge stays in the car and hence when we drive off during the day it gets power to cool it then.
thank-you again.
FollowupID: 604242
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 14:17
Bb,
your own reply above states:
"Most flouros use about 1.2 Amps.. as Mike R said current (measured in Amps) is an INSTANTANEOUS measurement and has NO relationship with time"
Your original statement:
"If you have it on for say 6 hours then it is 7.2 Amp HOURS" - which has now created the relationship with time ?
I'm prepared to look and learn, please show me the method of working out your original statement ""Most flouros use about 1.2A. If you have it on for say 6 hours then it is 7.2AH""
My belief is a light that draws 1.2 Amps, will definitely use 7.2 Amps in 6 hours, however these Amps are not referred to as 'Amp HOURS' but as Amps Total or just Amps.
'Amp Hour' is the Amps draw when stated per HOUR, as shown in your own statement "A compressor draws 60 Amps for 1 minute.... it is 1 Amp Hour" at least we agree on that :-))
Mainey . . .
FollowupID: 604247
Follow Up By: Member - Mike DID - Sunday, Nov 23, 2008 at 14:31
"My belief is a light that draws 1.2 Amps, will definitely use 7.2 Amps in 6 hours, however these Amps are not referred to as 'Amp HOURS' but as Amps Total or just Amps. "
- No, if it draws 1.2 amps (an instantaneous measure) then it draws 1.2 amp hours over an hour or 7.2 amphours over 6 hours.
That's why battery capacity is measured in amphours.
My fridge draws 5 amps when the compressor is running. If it runs fulltime it will use 5 amphours over an hour.
If the compressor runs 50% of the time then the fridge uses 2.5 amphours over an hour. Calling this 2.5 amphours per hour is technically correct, but a waste of words. Calling this 2.5 amps average is also technically correct.
FollowupID: 604249
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 15:29
- No, if it draws 1.2 amps (an instantaneous measure) then it draws 1.2 amp hours over an hour or 7.2 amphours over 6 hours"
Yes, as you say just too many words :-)
All this is because I posted: "Said with no technical gibbly gook"
"Fluoro light could use up to 5 Amps (~3 Amps probably) at night"
Should have posted; 5 Amps per night ?
Mainey . . .
FollowupID: 604254
Follow Up By: Member - Mike DID - Sunday, Nov 23, 2008 at 15:34
""Fluoro light could use up to 5 Amps (~3 Amps probably) at night"
Should have posted; 5 Amps per night ? "
No, Amps is an instantaneous measure - it has nothing to do with time.
It's as wrong as saying "my generator used 5 litres per hour per day" - it either use 5 litres per hour OR 40 litres per day !
FollowupID: 604255
Follow Up By: oldtrack123 - Monday, Nov 24, 2008 at 21:34
Hi Mainy
A simple question if your lamp uses 1.2 amps & runs of a battery for 6hrs ,how much battery power has to be put back into battery assuming 100% efficiency[ie out= in] & what is that unit power called.
FollowupID: 604441
Reply By: gke - Sunday, Nov 23, 2008 at 12:36
OK let me have a go. If 3men worked for 2hours that would be 6 manhours of work. Similarly 3amps going for 2hours would be 6 amps X hours which abbreviates to 6amphours or 6AH. thus we would get the same 6AH answer using 1amp for 6 hrs. or 1.5 for 4hrs etc
Cheers Graham
AnswerID: 336554
Reply By: Kroozer - Sunday, Nov 23, 2008 at 13:32
All that and i now know less then when i started.
AnswerID: 336557
Reply By: Member - Ian W (NSW) - Sunday, Nov 23, 2008 at 15:45
Come on Guys',
I think its about time you should get a little bit abusive with each other so that the Moderator can lock this thread and let it die a natural death.
I"m sure that one of you is technically correct and the other is somewhere behind, however, as far as a solar/electrically challenged person as myself is concerned I have absolutly no idea who is winning.
Now if I don't know who is ahead or behind then the thread has become somewhat pointless from a spectators point of view.
Am I going to die of boredom or will one of the contestants now draw a knife?
Ian
AnswerID: 336568
Follow Up By: Maîneÿ (wa) - Sunday, Nov 23, 2008 at 15:54
We are gentlemen of leisure, we do NOT get abusive, not even a little bit, with each other, we incite questions and impart wisdom, with nothing better to do as the fish are not on the bite and the wine is cold, the V8 Supercars have not started racing (on tv) when they do I will turn off the comp :-))
I am however very sorry the thread has been hijacked so strenuously though.
However, I still think a Solar panel of ~20 Watts will suffice :))
Mainey . . .
FollowupID: 604257
Follow Up By: Best Off Road - Sunday, Nov 23, 2008 at 17:02
Mainey,
I agree, I reckon 20 watts would do the job required adequately. Might even sneak through with less with lots of sunshine.
Jim.
FollowupID: 604260
Follow Up By: Kroozer - Sunday, Nov 23, 2008 at 20:29
Very interesting, so a 20w panel but do i need a regulator? I honestly have no idea about this stuff, but i want to do it environmentally friendly and without having to charge off vehicle.
FollowupID: 604284
Follow Up By: Affordable Batteries & Radiators - Monday, Nov 24, 2008 at 20:44
A 20W panel on a 18 a/h battery.
Yes, fit a regulator.
FollowupID: 604431
Follow Up By: Best Off Road - Monday, Nov 24, 2008 at 21:07
Agree,
A 20 watt panel, unregulated, could destroy your small battery.
Try a cheap $30 reg from Jaycar or similar. It should do the job.
Just disconnect it overnight, cheap regulators can allow reverse charge in the dark, ie the panel can suck charge out of the batt when the Sun is down.
Jim.
FollowupID: 604434
