Redarc isolator
Iam trying to install a redarc dual battery isolator to my 08 Prado i was told to fit it close to the battery but has anyuone installed one and where have you fitted it , any thoughts
Reply By: mike w (WA) - Tuesday, Nov 25, 2008 at 17:24
Yep, close to the battery, sitting upright, on top of the wheel arch. I utilised an existing bolt negating the need to drill into any bodywork. I have found that one good bolt is more than enough to mount the isolator effectively. I have done this on two vehicles now.
Mike
AnswerID: 336860
Follow Up By: Phillipn - Tuesday, Nov 25, 2008 at 21:07
Use 6 B & S wire. No smaller. And mount it as Mike W has.
It`s also a good idea to run a earth wire between the batteries and from the Anderson plug if you are connecting it to a caravan , rather than earth it through the body of the vehicle.
FollowupID: 604609
Follow Up By: Member - Brenton W (SA) - Tuesday, Nov 25, 2008 at 21:21
thanks guys i will locate a bolt hole and make a bracket to suit, how heavier wire do i need i run 2 small 35 ltr fridges in the camper.
FollowupID: 604615
Follow Up By: Phillipn - Tuesday, Nov 25, 2008 at 21:29
Use 6 B & S cable, not 6 mm cable., as it is a lot thicker.
FollowupID: 604616
Reply By: Nomadic Navara - Tuesday, Nov 25, 2008 at 18:24
Fit it close to which battery? The main point is to mount it in a position so that the lead between the two batteries is as short as conveniently possible.
AnswerID: 336874
Reply By: Member - Nick (TAS) - Tuesday, Nov 25, 2008 at 18:29
My Redarc isolator is in its second vehicle now.First one it was mounted exactally half way between batteries and this time its mounted close to the aux battery.Wored the same on each.
AnswerID: 336878
Reply By: Axel [ the real one ] - Tuesday, Nov 25, 2008 at 18:41
The reason you want it close to the battery - starting not the aux - is the longer the cable the more chance of voltage drop ,ergo the Redarc may not cut/out in at the specified voltage , that said ,really does not make much difference as long as the cables are of sufficient thickness and lugs are crimped properly.
AnswerID: 336882
Follow Up By: Boobook2 - Tuesday, Nov 25, 2008 at 19:31
Exactly!
FollowupID: 604582
Follow Up By: Best Off Road - Tuesday, Nov 25, 2008 at 19:41
Exactly x 2
FollowupID: 604584
Reply By: Member - Peter R (QLD) - Wednesday, Nov 26, 2008 at 08:31
This is where my Redarc is in 2007 D4D
Pedro
AnswerID: 336930
Follow Up By: Member - Peter R (QLD) - Wednesday, Nov 26, 2008 at 09:46
Try this one
Pedro
FollowupID: 604647
Follow Up By: Member - Brenton W (SA) - Wednesday, Nov 26, 2008 at 12:52
Thanks Pedro a great help, is it secured by one bolt or two, cant see the other side of the redarc?
FollowupID: 604672
Follow Up By: Member - Peter R (QLD) - Wednesday, Nov 26, 2008 at 14:56
I had the unit installed and two bolts were used.
Pedro
FollowupID: 604679
Follow Up By: Ozboc - Wednesday, Nov 26, 2008 at 21:18
must be the cleanest engine bay i have seen in a while ... no mud up there ay ?
Boc
FollowupID: 604720
