Tanami pump
Submitted: Wednesday, Dec 03, 2008 at 15:38
ThreadID: 63993 Views:5447 Replies:4 FollowUps:21
The Tanami Pump has recently been re-released.
The 'pump' consists of a standard jerry can lid with an air hose
fitting & pipe which extends to the bottom of the jerry so fuel can
be removed via 2 metres of fuel grade hose with either a 12volt air
compressor or a foot/ hand pump.
There is also a pressure relief valve fitted to the lid. A jerry can
be emptied in a round two minutes.
The Tanami Pump retails for $89 plus postage. Details at
Tanami pump
Came across this on another forum.
John C
Reply By: Sir Kev & Darkie - Wednesday, Dec 03, 2008 at 15:41
I wonder if the Canning Pro will be a plastic jerry can version??
Cheers Kev
Russell Coight:
AnswerID: 338045
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 15:53
The old Canning Pro was for 200 litre (44gal) drums.
The guy I work with bought one of the last of the original Pro's for pumping bio-diesel into his Toureg.
Geoff
Geoff,
FollowupID: 605578
Follow Up By: Sir Kev & Darkie - Wednesday, Dec 03, 2008 at 16:04
Well that blew that theory :(
Russell Coight:
FollowupID: 605580
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 16:19
We aim to please, must get the gun sites fixed!
Geoff
Geoff,
FollowupID: 605587
Follow Up By: Member - Jeff H (QLD) - Thursday, Dec 04, 2008 at 01:30
Boys ,boys: blue on blue.
Shame.
So tell me Sir Kev, the lord hi overseer of WPHnS, where do I get a metal lid for my plastic jerrycans?
jh.
FollowupID: 605698
Follow Up By: Ron173 - Friday, Dec 05, 2008 at 12:49
steady on old chaps.................all things in 'MODERATION' now lol
FollowupID: 605902
FollowupID: 605903
FollowupID: 605904
Reply By: Willem - Wednesday, Dec 03, 2008 at 17:34
I have a home made one without a relief valve. Pumps a jerry empty in 60 to 70 seconds. I only use it for diesel transfers.
Image Could Not Be Found
AnswerID: 338075
Follow Up By: Member - Footloose - Wednesday, Dec 03, 2008 at 21:34
By crikey Willem, that looks a nice bit of kit. Have you published DIY details anywhere ?
FollowupID: 605657
Follow Up By: Willem - Wednesday, Dec 03, 2008 at 21:47
Footy
No
It is just a jerrycan pourer with the nozzle removed, a bit of pipe welded where the nozzle was, a cap on the top of the bit of pipe, two holes drilled, a copper pipe fitted and a truck tube valve stem fitted and the whole shebang soldered together. Fit clear rubber hose to copper pipe and remove valve from stem.
When pumping fuel fit air hose to valve stem and remove when end of hose starts spluttering air (i.e. jerry is empty) :-)
FollowupID: 605660
Follow Up By: Willem - Wednesday, Dec 03, 2008 at 21:48
PS
Cost $10 in parts and a 6 pack of beer for the welding mate
FollowupID: 605661
Follow Up By: Willem - Wednesday, Dec 03, 2008 at 21:55
Here is a better photo
FollowupID: 605663
Follow Up By: GerryP - Wednesday, Dec 03, 2008 at 23:03
Hi Willem,
Looks good mate - I made a similar one myself a few years back, also using a pourer like you have. The only difference is that I used flexible tube to go down into the jerry, with a brass fitting on the end to give it enough weight make it dangle to the botom. Works a treat - a damn sight easier than lifting the can upside down next to the car!
I also made a similar one for my screw top water cans to decant into the water tank in the car or trailer.
Gerry
FollowupID: 605686
Follow Up By: Member - Footloose - Thursday, Dec 04, 2008 at 08:20
Many thanks Willem. :))
FollowupID: 605714
Follow Up By: Member - Oldplodder (QLD) - Thursday, Dec 04, 2008 at 18:26
Thanks Willem.
FollowupID: 605787
Reply By: Paul Grabonski. Vic - Wednesday, Dec 03, 2008 at 21:50
Hope everybody realises how illegal this type of device is. Under all state laws it would be not only illegal but dangerous. To use one of these devices next to humans and your vehicle is madness. Check with your local state Workplace for confirmation
AnswerID: 338125
Follow Up By: Willem - Wednesday, Dec 03, 2008 at 22:30
Please post details and not just hearsay
FollowupID: 605668
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 22:58
I'll have a look around my Workplace in the morning if you like and post back all occurences of the Tanami Pump.
Paul, what is it with you and Internet Guerilla Warfare?
Mate, you've probably got some really great stuff to offer.
Please offer that something substantial.
Geoff
Geoff,
FollowupID: 605680
Follow Up By: GerryP - Wednesday, Dec 03, 2008 at 23:12
Paul,
Not sure about the illegality, after all, they are available for sale, but it's only unsafe if you over-pressure without a safety valve fitted and even then, if used with diesel only, what would happen - you stink like diesel for a while if the jerry splits. While some of us have made our own (yes, without safety valves I admit), used in the proper manner, there is virtually nil chance of a mishap. There would be more chance of injury lifting several jerry cans trying to top up your tank. In any case, being from the old school, I take full responsibility for my own actions.
Gerry
FollowupID: 605690
Follow Up By: Member - Jeff H (QLD) - Thursday, Dec 04, 2008 at 01:23
Good advice Paul!!
Too many Idiots around these days!
Sheesh.
BTW, could you post those details re decanting gas from a 40kg bottle to a 2kg bottle - last lot got burned when the sparks from the grinder met methane for diesel plant.
Onya Pedro,
jh.
FollowupID: 605697
Follow Up By: Paul Grabonski. Vic - Thursday, Dec 04, 2008 at 08:23
Geoff things can be sold which are illegal to use. These devices should not be used and contravene all state workplace health and safety laws. Regardless of having a safety valve or not, the safety valve would need to be approved. However you could never get the device approved. Whoever is silly enough to sell a device like this would want to have bulk liability insurance. Actually knowing the unit would be illegal liability insurance would not be available.
FollowupID: 605716
Follow Up By: Willem - Thursday, Dec 04, 2008 at 09:37
We all know that Workplace Safety has gone mad over the years.
Does using a device in private have anything to do with Workplace Safety? If I manufacture something myself and then use it and then lets say, an accident occurs, who do I sue as being liable. Myself?
You can buy plastic pressure pumps from the hardware shops which work on the same principle.
All the TP does is to push liquid along a pipe by means of air pressure from a pump which is putting out very low air pressure cycles. There is an open outlet at the end of the line so no pressure build up is possible.
Anyway. It will be good to see the details and fine print when they appear in this thread.
FollowupID: 605729
Follow Up By: Member -Pinko (NSW) - Friday, Dec 05, 2008 at 12:44
And another dangerous activity is pumping up split rims without a cage. So I think we should all bring along an OHS approved device.
And smoking kills ya it says so on the packet !!!
I feel better now.
Stan
FollowupID: 605901
Reply By: Member - Rod N (QLD) - Friday, Dec 12, 2008 at 08:02
Sent a query to Tanami ref plastic container Tanami Pump.
Reply from Mark Stonehouse was
"There will be further pumps in the future. The wedco plastic Jerry is on the drawing board and others will follow."
Rod
AnswerID: 339333
