Which Auto - Diesel or petrol - need fuel economy figures - non towing - prefer
Submitted: Saturday, Dec 06, 2008 at 12:26
ThreadID: 64068 Views:4876 Replies:5 FollowUps:3
Related Pages
I've always been a Diesel fan but the Gov'yt is not supporting this eco friendly fuel - so I MIGHT change. Just sold my 2005 Toyota Hilux Turbo Diesel - looking to buy a wagon for $20 000. Family wagon & will not be towing anything & it must be automatic.
Looking at the older shape Prado due to the price ? But I need to know fuel economy figures to compare the petrol & diesel ?
What figures does the 6 cyclinder 3400 run ? How many Km per tank ?
Also are there issues with the old 3L Diesel motor ie cracking heads ?
I may even if I go diesel inject it with LPG.
I will also look at 80 series cruiser Diesel also if auto.
Look forward to your replies & advice.
Cheers Beddo
Reply By: Member - DOZER- Saturday, Dec 06, 2008 at 17:33
Old cruisers mid 90's, turbo diesel auto 12l/100 petrol auto 18l/100 towing, t/d 14l/100, petrol 24l/100....l
AnswerID: 338562
Reply By: Member - Phil G (SA) - Saturday, Dec 06, 2008 at 17:52
Gday Beddo,
I used to travel a lot with Prado owners - the 3.4 auto was pretty economical on the open road - they'd get about 13.5-15 l/100k depending on speed etc while I'd get 12 out of a manual Prado diesel. When crawling in low range, the difference was a lot more.
They hold 159 litres of fuel, and could go from Oodnadatta to Birdsville on about 130 litres.
The diesel 1KZ-TE has been known to crack heads - not often, but it happens.
Re 80series, a 1Hz diesel auto is a real slug and uses more fuel than you'd like. A factory TD auto (1HD-T or 1HD-FT) is a much better option, and fuel consumption is about the same as a Prado diesel.
AnswerID: 338565
Reply By: helping - Saturday, Dec 06, 2008 at 18:28
2003 Prado 3l Diesel does 9.6L/100 KM with cruise control at 2000 RPM = 89 kph indicated / 85 kph true by GPS when at medium to heavy weights. 1800 RPM is slightly better. When I need new tyres, I'll go for larger diameter which should be even better. When refueling, drive forward then reverse and you'll get rid of huge air bubbles and get another 6 to 7 litres in.
I wish there was a cheap accurate 'fuel used' counter on the market. This F to E relying on a lump of cork on a piece of wire is pretty useless.
AnswerID: 338571
Reply By: Best Off Road - Saturday, Dec 06, 2008 at 21:26
Beddo,
Does it have to be a Tojo?
There are a lot of other vehicles offering far better value for money. Jackaroo V6 is a gem and you can still pick up a Terracan V6 with some of the 5 year warranty left for less than a much older Prado.
Jim.
AnswerID: 338589
Follow Up By: Beddo - Saturday, Dec 06, 2008 at 22:39
Jim, no it does not have to be a Tojo, but not a Holden I'm a Ford fan & I couldn't do it.
Terracan maybe - do they have the centre diff lock like the Prado. Whats the reliability like ?
I use to have a 97 Surf & it was great, plenty of room & good ground clearance, I went to Cape york & the kimberley in it, but parts well were an issue ?
I will go offroad but not extreme stuff, may do Simpson in it.
Like the torque of the diesels, though maybe should have a drive of a V6 !
Cheers Beddo
PS. The old 4Runners & Surfs had the right size & ground clearance, you could sleep in the back if you wanted with the tailgate down - can't down that in anything else I've seen.
PPS. Delica (import) ? What are they like ?
FollowupID: 606152
Follow Up By: Best Off Road - Saturday, Dec 06, 2008 at 22:57
Beddo,
Jack is not an Holden, it's an Isuzu, rebranded by Holden.
Terracan does not have a centre diff, but you won't need it. Reliabity is great, I owned one for nearly four years and only traded it as I needed a ute.
Terracan does need some lift, Ironman do a great kit. The diesel is a good, economical unit, but having driven them they lack the urge of the V6 and command a much higher price.
Jim.
FollowupID: 606153
Follow Up By: Best Off Road - Sunday, Dec 07, 2008 at 06:52
Missed one of your points, The Simpson.
Terracan ha a piddly 75 litre tank and the V6 eats fuel in the sand. Long range tank is available, 120 L I think, but I doubt you'd get across the Simpson on that.
Diesel would probably suit you better.
Have a look at www.terracan.australia4wd.com
I set that forum up nearly four years ago and there is a heap of information. Should answer any question you may have.
BTW, my wife has a Hyundai Getz, which has just turned 4. Never had a single warranty issue it. Hyundai do make a very good, reliable vehicle.
FollowupID: 606162
Reply By: gdownie - Tuesday, Dec 09, 2008 at 14:02
06 diesel auto hilux[new] on d-gas getting 10/lrsper 100 around coffs harbour and 9/ltrs per 100 hyway trip.
AnswerID: 338935
