onboard caravan batterie charging
Submitted: Saturday, Dec 06, 2008 at 19:59
zacc
hi all i have a 2005 jayco
heritage and need advice on the onboard batterie charger . i have a deep cycle acid batterie on board . when it is charging through the onboard charger the batterie bubbles away , now i know this is dangereous as the gas is explosive . is this common for these chargers or are they surpose to switch them selves off to prevent over charging? cheers
Reply By: Affordable Batteries & Radiators - Saturday, Dec 06, 2008 at 22:17
Hi Zacc
Yes bubbles mean gas which can explode.
Please advise the details of the charger.
Note: The battery could have a bad cell or the charger is unregulated.
Derek from ABR
338596
Follow Up By: zacc - Saturday, Dec 06, 2008 at 22:34
not sure of the specs of the charger. the charger is the standard power supplier that comes with the van 240 goes in and 12 comes out as
well as it being a batterie charger . the owners manual says it will charge at 13.9 volts and that is what it is charging at , but that is all the manual says no wiring diagram or specs.
606151
Follow Up By: Affordable Batteries & Radiators - Sunday, Dec 07, 2008 at 10:09
Hi Zacc
How old is the battery ? (It could be ready for replacing)
Test the voltage at the battery to see if it is producing more than it should. I think that the battery should be tested and if it is fine then replace the charger.
Derek from ABR
606178
Reply By: Member - Cookie & Di - Saturday, Dec 06, 2008 at 23:05
You should get that checked by an Auto Sparkie.
338601
Reply By: Member - Redbakk (WA) - Sunday, Dec 07, 2008 at 00:34
Hi Zacc....I have the same type of van and the charger they instal is usually right for the job....
mine is ok and works fine...but yours sounds as though it is over charging...no, your battery should not be get hot or be bubbling,
mine stays cool and the charger which is on all the time while plugged in to the supply keeps it topped up.
Turn it off and have it checked out as soon as possible otherwise it will wreck your battery.
338610
Reply By: Dunaruna - Sunday, Dec 07, 2008 at 09:14
In 2005, jayco were using the centurion or ST series charger/power supply. They are a cheap and unreliable unit. The 'charging' mode is renowned to fail.
A 15 or 25 amp ctek is a very good replacement, and reliable. There is no need to use the power supply mode, just run everything of the battery.
338630
Reply By:- Sunday, Dec 07, 2008 at 20:42
we had a similar problem with our 2005 Avan.It cooked a delco battery,plus it was placed under the bed and the cooling fan in it was loud enough to wake you up,just nodding off after a good day's touring.Replaced it with a ctek xs7000 which is also has a power supply function and no cooling fan.No problems since.
regards Dave and Dulcie.
338715
Reply By: zacc - Sunday, Dec 07, 2008 at 21:00
thanx for the advice . i left the batterie disconnected over night and this morning it was dead. i have connected another to the charger and no sizzling or bubbling (touch wood) i will see how it goes . i will eventualy get another charger to be on the safe side. cheers
338717
