Trail bike gps
My son inlaw does a lot of bush trail riding and has decided to finally got himself a gps as he is now going into new areas and riding for hours. He is thinking of mounting the gps onto the handle bars and also looking for a unit that he can download maps onto. Does anyone do a similar type of riding and use a gps if so what brand etc or any surgestio
regards murray
Another Mexican
Reply By: Member - Mick O (VIC) - Sunday, Dec 07, 2008 at 21:42
Murray,
both Garmin and Magellan have a variety of models that will suit the bill. It's really up to your young bloke to determine his exact use for the unit and how much he wants to spend. I use a Garmin Etrex Vista HCX which you can load up with topo and road maps. I use this both in vehicle and on my ATV (Quad bike). I use a handlebar mount with reticulating ball unit and holder from RAM mounts. Good robust unit that is dust and waterproof (within limits),
Good places to start are the GPS Australia site for info (they have an associated e-store which has good prices) or GPS OZ who have a couple of stores in sydney but can offer a wealth of info. Check out the RAM mounts on their website.
Hope this is a start for you.
Mick
AnswerID: 338725
Reply By: Bonz (Vic) - Sunday, Dec 07, 2008 at 23:00
I use my Garmin GPSMap60CS on my bike with a RAM handlebar mount, it fits the bill
AnswerID: 338731
Follow Up By: madcow - Monday, Dec 08, 2008 at 07:28
I'll second that! I have a gpsmap60cx. 5 seonds to install and remove to put in the fourby. I leave the ball mount on the bars when it's removed. It is a real shame they will not take Lithium batteries.
FollowupID: 606271
Follow Up By: Member - JohnR (Vic) - Monday, Dec 08, 2008 at 07:45
Does the RAM mount make you go faster up hills Bonz?
FollowupID: 606273
Follow Up By: Bonz (Vic) - Monday, Dec 08, 2008 at 17:15
I just twist the throttle John, but really, it doesnt matter what I try I am still 15kmh slower than Paul
FollowupID: 606345
Reply By: dionbremner - Monday, Dec 08, 2008 at 07:04
I use a Garmin on a KTM200EXC. I had it mounted on the bars but it didn't last too long due to vibration. But the guys with four strokes don't seem to have the same problems, mounting them to the bars without dramas.
Dion
mycampgear.com
AnswerID: 338745
Reply By: Member - JohnR (Vic) - Monday, Dec 08, 2008 at 07:49
Murray, have a look in Trader on ExplorOz as there is often one there.
AnswerID: 338749
Reply By: Robin Miller - Monday, Dec 08, 2008 at 08:50
Hi Murray
We use both our old Garmin gps 111 and Garmin Quest on bikes , in each case we have removed the speedo and made aluminium brackets to hold the GPS.
The gps 111 runs direct of 12 volts and quest via a little 12v adaptor.
They both are held in place with velcro plus a cable tie.
We did this despite having regular mounts for these units.
The horizontal layout of these gpses has allowed them to be mounted low, parallel with the bars and hence the have survived falls quite well.
Important - both these Gpses are waterproof.
The gps 11 suffered from vibration issues which caused the heavy AA batteries to sometimes loose contact and hence permanent 12v solved this.
Both gps'es have there sensitivity reduced because of spark interference from the bikes and the bikes needed supressors for best performance.
The Quests in particular are designed for this type of use and have a 1 touch button that switches modes between map display and a dashboard trip computer display which allows you to easily use it as a speedo when riding.
You need high output display for bike work and Quests have this and they can even be operated with gloves on.
(Ours 2nd had from ebay US - $200 A$)
The mapping side never really worked for us on the bikes are proved to much trouble, even best maps are often not suitable for bike trails.
To much detail is a problem wearing a helmet/goggles
We tend to rely on a downloaded database of our waypoints backed up with thegeneral GPS basemaps.
AnswerID: 338759
Reply By: Danny & Helen - Monday, Dec 08, 2008 at 13:51
I use a garmin 60csx with ram mount and touratech holder combination and hardwire kit.
AnswerID: 338797
Follow Up By: Bonz (Vic) - Monday, Dec 08, 2008 at 17:17
Nice setup, it looks like its seen its fair share of dust and dirt and is still going.
FollowupID: 606346
Reply By: Member - Murray R (VIC) - Monday, Dec 08, 2008 at 20:33
thanks for all the replies good to see some are into over forms of bush recreation as well as 4wding.I have emailed him your comments and opinions which have been very helpful.
regards murray
Another Mexican
AnswerID: 338860
