wheels for navara 2008 d40
Submitted: Tuesday, Dec 09, 2008 at 16:18
ThreadID: 64142 Views:8110 Replies:4 FollowUps:3
looking for a spare set to put allterains on does any other model fit the d40 been told stud patern common but the off set is diterent on the d40 i dont know if it is true
Reply By: camwill69 - Wednesday, Dec 10, 2008 at 10:50
Warren,
I have 4 x D22 Steel rims 16 x 6, if you can find out if they fit they are yours. Only issue is I am in Qld.
Regards,
Camwill69 aka Cam
AnswerID: 339063
Follow Up By: Member - warren G (VIC) - Wednesday, Dec 10, 2008 at 22:27
thanks for offer and will keep in mind especialy as i am going to qld over crissy to see a mate for a week but as family are staying at home and i will be on my own i might fly
FollowupID: 606679
Reply By: oweee - Wednesday, Dec 10, 2008 at 21:59
Having done a bit of outback driving, the experts all recommend that you use steel wheels for outback driving - If you hit a big pot hole, stump, or cattle grid too hard, you can crack alloy rims, or worse. With steel rims, they can be bashed back with a hammer, whack in a tube ad you will get home, and they are very cheap to buy new??? After-market alloys are also very cheap, and you might find a local supplier that has old stock or scratched rims he will give you for next to nix if you buy tyres??? Check ebay and trading post, as there are cheap packages there all the time. I also saw a couple of sets of factory ST-X rims on ebay earlier this week??? Nissan 6-stud is th most common - I think you will find that any IFS 4x4 will have similar offset - Triton, Rodeo, Hilux, etc??? You should be able to find stock Rodeo steelies at any decent tyre shop, rusting around in the back???
AnswerID: 339155
Follow Up By: Member - warren G (VIC) - Wednesday, Dec 10, 2008 at 22:39
thanks for input .i dont realy care if i get alloy or steel as they will be for 4wding not a fashon parade.it is that i was that d40s had a different of set and whilst others will fit they could do some damage over time .just dont get time to chase it up
FollowupID: 606681
Reply By: oweee - Thursday, Dec 11, 2008 at 12:52
I agree, limiting damage is a good idea - the point of the post was to inform you that most larger tyre dealers have a stack of steel wheels laying around out the back that they will give you, or if you want new, but some $80 steel wheels to teh correct offset, or spend $150 per wheel for some after market alloys at the correct offset? Go an inch wider at teh same time, and give yourself better options for tyres. We run 235x85x16 on one of the utes with no problems - this is a standard size. we have a 40mm lift on both of our D40s? ring around - you will be surprised?
AnswerID: 339209
Reply By: Nomadic Navara - Thursday, Dec 11, 2008 at 22:08
When I got my D40 I looked at a catalogue of wheels that the Nissan service people had. There were SFA other vehicles that had the same stud pattern. There were some Toyotas that had the same PCD but they were only 5 stud not 6.
AnswerID: 339307
Follow Up By: billytvaner - Friday, Dec 12, 2008 at 13:14
i purchased a new steel rim for my d40 from mudguard motors in darwin,they r the nissan people in darwin,,, we were about to travel gib river rd after having come from capecrawford via roper bar, yas go for steel ,the stud pattern is odd , no second hand rims anywhere, put the steel on the vehicle and have alloys as spares
FollowupID: 606917
