Grey Water Tanks - Cleaning
Submitted: Wednesday, Dec 10, 2008 at 17:59
ThreadID: 64169 Views:3333 Replies:4 FollowUps:1
Hi, we have just bought a second hand Millard van. It has a grey water tank, sink water runs into it. We think it might need cleaning before we take off. What should we use to clean it? Any ideas please.
Reply By: Ron173 - Wednesday, Dec 10, 2008 at 18:08
Generally I found solution of bleach, filled up left to sit, drained and then flushed out couple times, this works for my main water tank.
Not sure about grey, why worry are you recycling it? my sink just goes out onto grass or attach drain line if in a site
Rgds
Ron
AnswerID: 339112
Reply By: Member - Kim and Doug (QLD) - Wednesday, Dec 10, 2008 at 19:46
box of bicarb then half fill with water does the trick
AnswerID: 339122
Follow Up By: Garbutt - Thursday, Dec 11, 2008 at 08:58
Agreed but take it for a drive to let it slosh around.
FollowupID: 606722
Reply By: Paul Grabonski. Vic - Thursday, Dec 11, 2008 at 08:25
about 70c hot water 2/3 full plenty of Morning Fresh and a good drive then drain. If really clogged up with fat then caustic soda and read instructions carefully.
AnswerID: 339180
Reply By: Nomadic Navara - Thursday, Dec 11, 2008 at 22:02
If you use Bio-Magic for your portable dunny then use a charge or two of that. It will compost the food scraps and other gunk in the tank if you leave it there with the tank half filled. Leave it there for some time before going on your trip and empty it just before you get to your first camp spot. (These instructions will work what ever the chemical you use.)
AnswerID: 339304
