265/75 tyres
Submitted: Thursday, Dec 11, 2008 at 14:33
ThreadID: 64187 Views:3371 Replies:5 FollowUps:1
Related Pages
Hi all, just have heard that if I put this size tyre on the front of my Prado that it will rub could I get some advice regarding this..
Reply By: Sir Kev & Darkie - Thursday, Dec 11, 2008 at 14:34
What model Prado??
Cheers Kev
Russell Coight:
AnswerID: 339228
Follow Up By: Jock69 - Thursday, Dec 11, 2008 at 14:43
Kev,
2002 last of the old shape..
FollowupID: 606766
Reply By: Member - Phil G (SA) - Thursday, Dec 11, 2008 at 15:44
If you have standard suspension, there will be slight rubbing on the front mudflap at full lock. May also touch the front chassis. Rear is usually fine. Lifted suspension is a lot less likely to touch.
AnswerID: 339234
Reply By: dieselman - Thursday, Dec 11, 2008 at 17:48
Mine does not rub unless full lock and under compression at the front(very slight rub on mud flap). 01 Diesel with 2inch lift kit.
Ben
AnswerID: 339244
Reply By: DBT - Thursday, Dec 11, 2008 at 18:29
Friends had them fitted by mistake and yes they did rum on full lock and when the vehicle was tilted.
AnswerID: 339253
Reply By: StormyKnight - Monday, Dec 15, 2008 at 19:25
Yes been there done that...2001 Prado GXL standard suspension.
BFG MT 265/75's....probably the biggest diameter tyre in this size bracket
I ended up getting a wheel alignment done & asked the guy to adjust the castor.....
This adjustment is basically done normally to increase/decrease the tendancy for the steering wheel to return to centre when let go.
A side effect of adjusting the castor is that you are actually moving the whole wheel forward & backward. Thus the adjust gives more space for the tyre to fit especially at the point it will contact on the Prado, the mudflap "lump" at the top of the mudflap. I was able to get about 1cm increase in this spacing by doing this without any noticeable change in steering.
Oh & BTW, in many states of Australia you will need an engineering certificate to authorise the change to a larger diameter tyre. If you don't you may find that your insurance is invalid....it pays to check the details of this before you go down that track...
Anyway, within 10,000km on the MT's they no longer can hit the mudflap, you may find with a lift kit or AT's they won't touch at all.
The test is negotiating a driveway entry @ 45 wheel lock at moderate speed....compression of the suspension was also required on mine for it to rub.
MT's have now done 70,000km & are probably about 30% tread depth remaining.
Richard
AnswerID: 339881
